Results 1 to 30 of 30
    Dec 29 2015
    DIY - Audi B8 S4 DIS Failure (Instrument Cluster Repair)
    Hi Everyone,
    I while back I posted a thread asking for help on this issue, and have finally resolved it.
    http://www.audizine.com/forum/showth...mation-Display
    Difficulty: 1/5
    You have two options: 1) Re-seat the screen, 2) replace screen.
    If you need to search for the screen it is made from an Italian company Magneti Marelli. The screen fits the following models and I would suggest searching something like this for the screen:
    "Audi A4 8K S4/RS4 and Audi A5/S5/RS5 Magneti Marelli instrument color display"
    If you don't feel comfortable dissembling your cluster their is a guy 'Tom' who will fix it for you @Speedo Solutions http://www.speedosolutions.com/
    Step 1) - Remove instrument cluster and disassemble (this is very straightforward)
    http://www.audizine.com/forum/showth...etrofit-for-A4
    Step 2) Remove the screen and try resetting it first. If this doesn't work then order a new screen (refurbished if you can find one or buy a used cluster and take the screen from it)
    Screen removed
    Screens metal case
    Screen removed from case
    Step 3) Reinstall and test that it is working
    My date reset to 2009 for some reason. So I updated to 2017 in the MMI settings
    Hope this helps anyone who is experiencing the same issue.
    2010 S4 | Meteor Grey | Premium Package | Audi Drive Select with Quattro Sport Differential | 6MT ||| Upgrades - SS Brake Lines | B8.5 Aluminum Pedals | VMR 710 19x9.5 ET45 w/ 255/35/19 Pirelli P-Zero |
    Veteran Member Four Rings A.C.'s Avatar
    Sep 15 2013
    2015 VW GSW TDI, 2004 GLI, 2015 Kia Sorento
    MD
    Nice write up!
    Established Member Two Rings a4efforts's Avatar
    May 15 2017
    '09 A4 B8, '17 PORSCHE MACAN & '08 BMW X5
    Atlanta, GA
    Question: Do you think I could swap in a color screen in place of my red screen? I would prefer that if it is possible. Thanks!
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    nicely done. what did the new screen run you?
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Quote Originally Posted by a4efforts View Post
    Noup!
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    May 15 2017
    Atlanta, GA
    Quote Originally Posted by Gunnark100 View Post
    Noup!
    Any reason? Pin connectors, etc?
    May 15 2017
    Atlanta, GA
    Bump! Curious to know whether this can be done. Thanks!
    Established Member Two Rings JKrups06's Avatar
    Jul 01 2014
    Chicago IL
    How does one reset the screen? Is it just disconnecting and reconnecting? When your screen goes out do your left side steering wheel controls go out as well?
    Sent from my SM-G950U using Tapatalk
    Active Member One Ring Barrenhammer's Avatar
    Apr 03 2012
    Youngstown, OH
    Quote Originally Posted by JKrups06 View Post
    That's what happened with mine when it went out. Mine started working again all by itself - but something I noticed is that all the miles I'd driven while it was off were not registered on the odometer.
    Jul 01 2014
    Chicago IL
    Quote Originally Posted by Barrenhammer View Post
    I have had this issue for about a year or two. It seems to be mainly affected by the cold weather, as temperature drops my screen goes black. In summer months it comes back (Chicago weather). I have had it go out for a month and now it's been out for almost 3 months. Looking for any help how to fix this. I never had any issues of missing miles on the odometer ... Or I never noticed.
    Apr 03 2012
    Youngstown, OH
    After driving it a bit and filling up, it seems like my trip reset, but the odo tracked everything as normal. I did buy a replacement screen and a complete used cluster, but my screen came back on the day before the parts were delivered. Go figure.
    Oct 16 2019
    Scotland
    Sorry for commenting on an old thread but can anyone confirm if any b8 screen can be used? In other words could I buy a set of a4 b8 speedo/cluster and just use the screen from it? My car is 2011 b8 s4 - currently with a blank screen. A4 clocks are cheap on eBay (£30 ish).
    Many thanks
    Oct 21 2012
    Earth...
    Quote Originally Posted by Paulsb View Post
    Many thanks
    Display is same, regardless red or color - buy correct one!
    Oct 16 2019
    Scotland
    Thanks
    Can’t even remember which mine is 🙈. I think it may have displayed some stuff in green etc??
    So I need to buy the right one colour wise but it can come from any a4 b8??
    Thanks again!
    Oct 21 2012
    Earth...
    Thanks
    Thanks again!
    B8 is same s...t, so get color one from A4B8 for example, it will work...you a bit far, otherwise i could send you one, but pointless time waste and shipping!
    Oct 16 2019
    Scotland
    Looking for a colour one online now! Thanks again .
    Thanks for the offer of sending but I’m in uk (Scotland) so a bit far lol!
    Now it’s time to carefully dismantle a set of clocks!
    Also Is there anyway of telling if it’s a colour screen from part numbers etc on back of speedo cluster? Lots of scrap/ junk yards guarantee they work but don’t know if it’s colour!
    Thanks again for your help!
    Oct 16 2019
    Scotland
    And another question will the screen from an a5/s5 also fit? Trying to find one close lol! Cheers!
    Nov 06 2019
    Melissa tx
    You guys sound informative . I’m new to Audi’s and realizing real quick they are very complicated lol. I’ve got a 13 s4 b8.5 . Am I able to just change my current black and white lcd to color ? Or will I need a whole new cluster. And if so what’s the correct cluster code I can use to have the color display. The help would be greatly appreciated.
    Oct 21 2012
    Earth...
    Quote Originally Posted by jewnbug View Post
    You probably have red/black cluster not white/black, for color one you need whole new cluster, partnumber depends what options you have, with or without acc, rest is clear as you have s4.
    Nov 06 2019
    Melissa tx
    What’s acc ? And my cluster lcd screen is in black in white .
    Oct 21 2012
    Earth...
    Aa ok, audi killed ugly red/black display on facelift without nav, so you got black/white. From one ebay ad i cant see screws holding display, but its not the best angle picture. So i guess, logic must be same like with red one, that you need whole color cluster. ACC adaptive cruise control.
    Nov 06 2019
    Melissa tx
    My car has cruise control but how can I tell if the clusters on eBay have or not .. or if they are even the color displays . That’s where I’m stuck .
    Oct 21 2012
    Earth...
    Which cruise you have - adaptive(measuring and keeping distance from car ahead of you) or old style?
    8t4 is adaptive one
    https://nemigaparts.com/cat_spares/e...q/736u/920000/
    Nov 06 2019
    Melissa tx
    8t4 is adaptive one
    I’ve just got normal cruise control .
    Veteran Member Three Rings mikedizzzo's Avatar
    Nov 03 2016
    So Cal
    Anyone able to find a replacement gauge cluster screen? Mine is scratched up.
    -MikeDizzzo
    2016 S5 Premium Plus | Florett Silver | Black Optic Plus Package | DSG | ADS | Carbon Atlas | B&O
    Mods: GIAC Stage 2 | TCU | SC Pulley | Bilstein B16 Ride Control Coilovers | AWE Touring Exhaust 90mm | Maxton V1 Front Lip | 034 Transmission Insert | Brakes - Hawks Pro with slotted/dimpled rotors | Relak Paddle Shifters | Ceramic Pro 9H | LED interior | 2 x Audizine 5' stickers | Audi All Weather Mats
    Oct 22 2018
    Grafton Twp, NE Ohio
    This instrument cluster screen in my 2012 B8 S4 just went dark for me this morning, (was on a 7 hour long pothole ridden drive yesterday). I reset the MMI, screen still dark. Then I read this excellent posting and saw the text about "Re-seating" the screen. I decided to try re-seating the screen without removing it... So I slapped the dash with my palm just over the screen quite hard, and VIOLA! Back to life. I do not know if this will last, but perhaps a healthy whack is a cheap and quick place to start. :)
    Jul 05 2015
    Lower Hudson Valley
    Quote Originally Posted by FrankP View Post
    Percussive maintenance.
    Junior Member Two Rings
    Apr 14 2019
    Northeast, NJ
    I had this problem. I think the palm slap fix, road with potholes, cold weather are all evidence of bad solder joints on the PCB.
    In my case (2010 a4 mmi high) I took the cluster out, removed the DIS and re-seated the ribbon cable. Reassembled. Screen was still dead.
    Then I removed the back cover of the cluster and saw two voltage regulators barely hanging on. I did not take pictures unfortunately but I remember there was a large one, a medium, and several smaller ones. I touched up the large and medium solder joints (little bit of flux with a qtip, dab of new solder, waited 30 seconds in between each pin, clean flux away with rubbing alcohol). I suppose you could reflow the board also but you would have to fully disassemble. I did this without removing anything from the front of the cluster.
    Not only did my DIS come back on but it's brighter and the colors more vibrant. Also my trip computers / fuel consumption menu had disappeared, they came back; an "internal communications error" with the radio module code is gone; and I could hear a high pitch noise coming from the little speaker all the time which went away.
    If you don't know what a surface mount voltage regulator looks like you probably shouldn't try this but the components look like the image below. Use common sense and disconnect the battery before beginning, disconnect BEM plug, ground yourself, use a decent low wattage soldering iron, etc. Don't overheat anything and don't burn yourself.
    Established Member Two Rings r8ders's Avatar
    Feb 15 2004
    2011 B8 A4, 01 Yamaha R1, 95 M3, 98 Ford F150
    SF Bay Area
    Quote Originally Posted by jessenepywoda View Post
    Thanks for the information. Our car just started to have this issue where the cluster display is intermitted. I'll check for cold solder/insufficient wicking on the joints before having to disassembly the front and reseating the cable.
    Feb 07 2018
    PDX ish
    This is sage advice for almost all big decisions tbh. The post whack clarity should not be underestimated. Talked my wife into a lot of stuff she would have straight up denied if she lived by this mantra...
    Sent from my SM-G973U1 using Audizine Forum mobile app
    2011 S line Prestige A4 Avant - 3.0t swapped
    EPL + 034 Stage 2+ DP ECU tunes| EPL TCU | CTS 187/57 | Roc-Euro Intake | PLM V2 Heat Exchanger | HR coilovers | Front BBK SPM Alcon 375mm | Rear BBK Voshmod 356mm| Milltek full resonated exhaust | test Pipes | 034 Endlinks | RS5 FBSW | 3g+| Deval CF Diffuser| BFI Knob | P3 Gauge| S4 Panda seats| Beaufort Aluminum Trim | RS5 Piano black MMI | S5 gauge trim
