Everyone has a different break in procedure. There are probably as many variations as there are shapes of snowflakes BUT that being said there are a few basic principles to follow during a turbo break in period:
1) Use new oil and coolant. A full oil and oil filter change goes almost without saying. I personally only replaced the coolant that drained out when replacing the turbo as my coolant was fairly new. Added about 60oz back in of 50-50 coolant distilled water mix.
2) Warm up and cool down turbo a bit more extensively then normal. Not only will this allow your bolts and all your mechanical bits to settle in but also to allow your ECU to adapt to its new role and the information coming to it from the sensors.
3) Check for leaks and loose bolts. It's not uncommon for these to manifest themselves within the 1st 1-3 tank fulls of gas. Be alert and in touch with what is going on under your hood.
4) Ensure all boost hoses are tight to avoid annoying hose blowoffs. Happens to the best of us. I would get all the way to the freeway ready to have some fun and be impressed and BOOM... darned boost hose blows off. I usually do my 1st pulls closer to my place and with a full set of tools and a jacket stand in the car. This will allow me to quickly pull over and reattach any potential hose that comes loose.
5) No need to avoid max boost but I usually drive the car in traffic for a good half hr to allow install oils to burn off. Last time when I installed my elim the smoke was coming out pretty steady for the whole duration I drove through traffic and slightly longer there after.
6) Only once I have done all of the above will I attempt the 1st full boost run. Another point of caution is to not attempt this without a boost guage intalled. Possible damage to turbo, engine or both could occur if something like the wastgate... etc is not properly set or malfunctioning.
7) Finally enjoy your new turbo but also plan for your 1st oil change to be a little sooner than normal by approximately 15-25% of your normal miles. Then feel free to resume your normal oil change schedule. This will give you 2 benefits: a) You can check out your turbo and engine bay for any strange leaks b) You can get rid of any debris or installation contaminants, or particles of who knows what - circulating about in your oil.
Happy boosting fellow Audiziners.
Edit...
P.S: Adding this even though it is not related to the actual turbo break-in process due to personal experience.
Check and double-check the locknut on your wastegate before install. Add loctite to secure it in place. If the nut breaks loose everything is coming off again to take the turbo out and fix that problem. Dont ask how I know...
