Results 1 to 25 of 25
    Established Member Two Rings angrypanda's Avatar
    Feb 03 2017
    Halifax, Nova Scotia
    B8 motor rebuild options
    I've got the chance to pick up an 09 avant 2.0t with a bad motor cheap. Didn't say what's wrong, just that it would need a new motor or full rebuild.
    Around here there are no motors available for less than ~$4k (tax, shipping, USD conversion).
    Finding lots of threads for people who had to replace a motor, not so many internal build threads... Is this for good reason, or are they just not cheap enough that people are tearing into them like the B5/B6s?
    The idea would be to keep it a daily, aiming for ~300-350 hp. Is the B8 motor any good once built? Can the oil/timing issues be overcome, or is it just a fault in the design? Can the 6speed auto handle that long term?
    I've found a few threads that just sort of ended after saying to get a B8.5 motor; but that's not really an option, and apparently non US ecus do not plug and play (said one such thread).
    I will be doing my own work and am completely comfortable rebuilding the motor. I'm currently rescuing my 7th B5 A4, and am running my stage 2 B6 avant as my daily.
    Sorry for not spending more than 2 hours reading/searching, but I'll need to pull the trigger quickly or may miss my chance.
    Thanks.
    Obligatory pic:
    Senior Member Two Rings CoyneJ's Avatar
    Dec 29 2015
    B5 S4
    Illinois
    Check the compression and look through the oil fill to see if there's signs of poor maintenance, my guess is the timing tensioner failed and bent the valves but it could be anything, your best bet it to tear down the block and see if it is savable and you can get it checked out by a machine shop, integrated engineering will run you around 2k for rods, pistons, bearings, and valves if they are bent you can get in contact with them and they will help you out with the process
    Veteran Member Four Rings pierreb's Avatar
    2020 A4 allroad
    NH
    300hp you'll need k04 or better and wm. Once you fix timing tensioner and pistons the engines are very decent. Pretty typical audi to have $5 parts ruin $15,000 engines.
    Feb 03 2017
    So the oil issues are piston/ring based? (Sorry, that thread was like 60+ pages and I was not reading all that last night)
    Is there an upgraded tensioner readily available?
    Veteran Member Three Rings IHave2Turbos's Avatar
    Aug 17 2015
    can you scan it and look for codes? Timing chain tensioner failure will pop codes. You can try to take the VIN to a dealer and see if they can provide you with the service records (your results may vary). You can see if it had Stage1 or Stage2 oil consumption recalls done.
    C7.5 S6
    Mods : OEM+ Stage3 / DS1 ECU / SRM TCU / CTS HX
    B8 A4
    Mods : HPA\\\ K04 / Manifold / HFC / Tune | CTS FMIC / DP | CR-15 | ECS Inserts
    Retrofits: MMI3G+ / RVC / AHH / Color DIS / Cruise Stalks
    Veteran Member Four Rings Zach L's Avatar
    Feb 23 2010
    Austin, TX
    If I were going to hassle with any rebuild on these motors, I'd replace pistons and rods with aftermarket forged pieces. The cost difference for the better parts is negligible.
    Daily Driver: B8 A4 quattro 6MT, Aruba Blue on Black, Premium Plus, Sport Package, Bang & Olufsen
    Current Projects: 2006 Cayman S 6MT • 2006 VW GTI 2.0T 6MT • 1997 VW Golf • 1982 VW Rabbit Diesel • 1972 VW Bay Window Bus
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    Quote Originally Posted by angrypanda View Post
    It's the rings, IIRC, I read somewhere that they basically didn't make sure the gaps were 180 degrees off so oil would get through. No idea if that's true, but the fix for consumption is a replacement of the pistons and rings.
    Tensioner is DIYable, and yeah there's a new version that solves the problem. A few people have built engines and they handle power fine.
    K04s (lettuce (6AT), allroadcorbin (8AT), lambda13 (6AT)) and EFR turbos (slowone11) have the output you're after and are still DD-able.
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    May 21 2015
    Nissan R32 GTR, Ducati 659
    Melbourne, Victoria, Australia
    Isn't Slowone11's turbo a LOBA400?
    Veteran Member Four Rings Alex1188's Avatar
    Mar 10 2013
    Forest Lake, Minnesota
    Quote Originally Posted by Shaph View Post
    Yes and he is running bigger injectors, and bigger fuel pump. He has probably the highest power output of anyone on the forum if I recall right.
    May 21 2015
    Odly there's a chap here from Russia with a LOBA380 making 380whp
    Veteran Member Four Rings lettuce's Avatar
    Jun 19 2015
    Boston
    I wish someone with a Loba here would run a 1/4 so we had more than corrected dyno numbers to go off of. Always interested in seeing what options are out there and the Lobas seem like they could be great turbos.
    B8 A4 - Eurodyne-tuned F23L - 12.6 @ 107 on 93
    Apr 03 2016
    Hey Guys
    I have a B8 A5 that had a spin rod due to the oil issues it seemed. My car was being checked for Oil Consumption and during that my engine blew.
    They put in,under Warranty, at 51k miles, a new full block from Germany.
    No rebuild or anything.
    My question is do you think that was a B8.5 2.0 full block and does anyone know how I could check? It would be SOO awesome if this was the case:). I have now 96k and it's kicking a$$. Tons of mods waiting to put in after my Warrenty is up. Thanks guys!!
    VAG Love.
    Mar 25 2015
    Belgrade, Serbia, Europe
    Piston rings are the main problem. New one doesnt fit old pistons as they are 23mm instead 21mm old, so U need new pistons and conrod. Or U can cutin for 3rd ring to fit in piston :)
    May 21 2015
    You mean the writs pins?
    Established Member Two Rings b8_Jeff's Avatar
    Jul 24 2013
    2018 A3
    Alamogordo, New Mexico
    I am currently in the same boat. I emailed integrated engineering to see what my options are... hopefully built engine with k04 (or bigger).
    CURRENT 2013 Audi S6---Phantom Black---Black Optics---Avant Garde M520 Wheels---Michelin Pilot Spot All Season 4
    May 21 2015
    Quote Originally Posted by b8_Jeff View Post
    That pretty much what im doing. IE mahle Pistons. IE Rods, IE vlave springs and Ferrera Valves. along with an EFR6758
    Feb 03 2017
    And what did that package run you?
    May 21 2015
    Close to 10kusd however I had to pay postage to Australia plus I picked up a HPA intake manifold
    Feb 04 2016
    Ontario,canada
    My engine is being rebuilt right now. Replacing the pistons/rings will fix the oil consumption problem. The timing chain tensioner also fails, so you will want to replace it and while the car is dismantled you will want to clear out any carbon buildup caused by the injectors.
    After that the engine should be great, these 3 things seem to cause the most problems for us. If i were you, I would try to verify that the tensioner didn't already fail. If that happened already I would pass on the car even if you know what you are doing. It will almost certainly need a new engine.
    Regardless, It won't be cheap or easy to get 300-350HP out of it. I have a 2010 2.0 quattro with APR stage 2 and a HFC and I'm ~290HP and ~350TQ. The car is still super fun but not it's not going to get to 350HP without some significant work. I didn't want to modify my car that much so I found stage 2 a good blend between performance boost, $$$, and not heavily modifying the car.
    I know many people run K04, that will definitely get you more bang, but I don't have one so I can't comment.
    Feb 03 2017
    Quote Originally Posted by Jaydog0910 View Post
    Thank you for the concise post. I imagine it will be the tensioner. I expect to hear back shortly.
    If 290 is relatively easy to reach, that would likely be satisfactory... At least for a while. I'm not hard set on 350, but would want to be able to notice the upgrade from my stg 2+ b5 and stg 2 b6.
    May 21 2015
    Wait isn't someone here making 330whp on stock block and K04?
    Jun 19 2015
    Boston
    I would say anyone with a K04-sized turbo is pushing anywhere from 300 to 350 at the wheels, both ft lbs and hp, depending on dyno type and conditions. Almost all on stock blocks.
    Feb 03 2017
    "Yes/ will need a complete new motor broken pieces of metal were shifted through the motor and pulled through oil pump replacement is the answer"
    This is the update from the seller... Gross.
    Jul 24 2013
    2018 A3
    10k huh? guess I will have to plan for that haha. granted it will probably be 9k or so for myself since I don't have to pay for shipping to Australia. would love to see what you put down hp wise after the upgrades. any plans on dyno? custom tune as well?
    May 21 2015
    Yeah. 10k not including turbo or intercooler. Hopefully engine will be back this week. Had a delay. Incorrect wrist pin for the Mahle Pistons. Definitely will be custom tuned hopefully low 400s. I really want 420hp (blaze it)
