Results 1 to 29 of 29
    Established Member Two Rings Goned's Avatar
    Jan 03 2017
    Oil engine for 3.0T ?
    Hi,
    What brand of oil do you recommend for 3.0T?
    I know Audi's dish of Castrol, but I've heard stories about the quality of this oil,
    Thanks for your feedback,
    Veteran Member Three Rings plat's Avatar
    Dec 19 2015
    GVRD, BC Canada
    Quote Originally Posted by Goned View Post
    Hi,
    According to your car's owners manual, any oil that meet or exceed the VW 502 oil standard is fine. Here is the Audi Technical Bulletin of Approved Oils and Oil Quality Standards for reference.
    I have used Castrol in both my VW's and my '16 Audi S5. No issues or problems otherwise Audi will not specify it as their preferred oil brand. Other owners are biased towards certain oil brands. That's their choice. Again, as long as it meets the VW 502 standards, it is OK.
    Current: 2016 S5 in Sepang Blue with Technik Package.
    Jan 03 2017
    Quote Originally Posted by plat View Post
    Audi use Castrol brand that true ?
    I would like to try Liqui Moly or Fuchs oil. Anyone have test it ? For mine i got to take 5w40 VW502 :)
    Dec 19 2015
    GVRD, BC Canada
    Aud use Castrol brand that true ?
    Says so on the oil cap...
    Dec 15 2016
    Seattle/Washington/USA
    I've been using Liqui Moly 0w-40 Leichtlauf and love it.
    Jan 03 2017
    Yes i know, but i want to test another oil brand. Castrol is correct, but i have ear Liqu Moly and Fuchs are better....it's maybe a legend....
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    I use Mobil 1 0w-40.
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Dec 15 2016
    Mobil and Liqui Moly are the best. It says "Castrol" on the cap because Castrol pays Audi millions $$$ to have it there. Not knocking Castrol, just saying... Mobil and Liqui Moly are the best.
    Jan 03 2017
    Quote Originally Posted by Ingolstadt Audi View Post
    Ok so you recommand Liqui Moly, this one for the 3.0T => SYNTHOIL HIGH TECH 5W-40 ?
    Veteran Member Four Rings riceboy22's Avatar
    Mar 26 2015
    2015 Audi SQ5, Felt F65x, Levy Electric Scooter
    New York, NY
    Current
    2015 Audi SQ5 3.0 TFSI (Build Thread | Flickr | Instagram)
    Past
    2006 Lexus IS350 | 2001 Audi S4 | 2000 Honda S2000 | 1999 Yamaha YZF-R6 | 1995 Acura Integra GS-R
    Dec 15 2016
    Absolutely... love the stuff. Here is a link for it: https://www.amazon.com/Liqui-Moly-23.../dp/B00LIC29H6
    Mar 14 2017
    Pawtucket ri
    I second this! I have been using it since I bought my car.
    Sent from my SM-G935V using Audizine mobile app
    May 21 2010
    Curious...what do you LOVE about this oil? There would be absolutely no performance difference from one brand to another. Whats the difference that makes you love it?
    Dec 15 2016
    Correct, oil is not really a performance item, it's about engine protection and reliability. I've noticed that my engine idles smoother, it's also a great company with top marks and awards, and it was designed and tested for turbocharged engines.
    May 21 2010
    Interesting. Same for Castrol. Oil does not affect idle.
    Dec 15 2016
    Agree to disagree I guess. I noticed quite the change on my car with the idle, not nearly as much ticking as before with Castrol. The only thing that was different was the oil so I'm going off that I guess. I'm obviously not a chemical engineer, but Liqui Moly is one of the most used and best rated oils in Germany that and the less ticking from my engine at idle is enough for me to run it. German car = German oil logic. Haha.
    Veteran Member Four Rings EYE4SPEED's Avatar
    Jan 14 2008
    Macan Turbo, Cayenne Diesel, Audi Jr Quattro
    West Coast of Michigan
    Sorta related - there is a tsb out since Jan for the oil level sensor.
    Came on during a road trip and had to find store that had Castrol 5w40. Filled it and next day, 100 miles into heading home and light comes on again.
    To the dealer to use their fancy measuring tool. Oil level good, sensor bad. Come back when we have the part...
    Venting that they didn't include a real dipstick. Btw, need part number so I can get one. Only way to check is MMI, which does no good if sensor is broke.
    FS: Audi TT 225Q Roadster
    May 21 2010
    Love your logic. Might be quieter but not smoother. I love German cars too! Ive had 6 Audis. This SQ5 is great.
    Jan 03 2017
    So finally i have choose this one :
    - FUCHS TITAN GT1 5W40
    https://en.wikipedia.org/wiki/Fuchs_Petrolub
    Fuchs is German oil :) for German car :P
    For the next change oil, i think can test Liqui Moly :)
    Dec 15 2016
    Quote Originally Posted by Wilbur View Post
    I'm jealous... wish I had the SQ5. Someday. RS7 in another life.
    Jan 03 2017
    For Oil filter, do you think use another than OEM filter ? Like KN or another label ?
    Thanks,
    Dec 15 2016
    I stick with OEM, they are cheap and work great. But I wouldn't foresee any issues with an aftermarket one either.
    Jan 03 2017
    For update this thread:
    I have used FUCHS and i confirm is a very good oil.
    With Castrol i need to refil with more one 1L bootle.
    With FUCHS i have used only one 1L bootle and i'm stay at full oil signal.
    I want to try LIQUI MOLY this time, just to compare....
    Feb 15 2007
    Schaefer’s 5w-40
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Mobil 1 European car full synthetc, 0w40.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Veteran Member Four Rings Das Ponto's Avatar
    Dec 20 2012
    2022 Q7 S-line
    Edmonton, AB
    Quote Originally Posted by zachf88 View Post
    Schaefer’s 5w-40
    Same Schaefers as the deck sealant? lol
    But on topic I use Mobil 1 / Elf Oil (believe they are the same.. need to check)
    Ponto
    2020 Glacier White A4 Allroad | 034 Dynamic Springs | 034 Intake | Unitronic Stage 1+ | Rotiform SGN
    2022 Daytona Grey Q7 | Quattro Magazine's Project Q7 Offroad | H&R Lift Springs | Black Rhino Volls | BFG KO2's | Rokblock Mud Flaps
    Instagram: Dasponto | Flickr
    Veteran Member Three Rings Reggie's Avatar
    Feb 27 2005
    2014 SQ5 & 2015 RS5
    Fort Collins Coloardo
    Quote Originally Posted by q5 dave View Post
    Same here on all my Audis. Best price is at Walmart. The only thing I shop for there
    Established Member Two Rings BierJager's Avatar
    Apr 28 2017
    2015 Highlander
    Michigan
    I carefully selected whatever brand the dealer puts in when they change my oil.
    Feb 15 2007
    Quote Originally Posted by Das Ponto View Post
    Schaeffer's is actually the oldest oil/ lubricant company in the US....
    http://www.schaefferoil.com/
    It's one of the very few oils out there that has a High Temp/High Shear (HTHS) Viscosity of 4.05 and it has moly in it. but I'm super geeky about my oil....
    Mobil 1 0W-40 euro has a HTHS of 3.6.
    2007 Audi RS4 - Daytona Grey - Original Owner
    1957 MG MGA 1800 - Austin Healey Spruce Green
    2020 Mercedes-Benz GLC 63 AMG - designo Cardinal Red
    2024 Tesla Model 3 Dual Motor - Stealth Grey
