Results 1 to 30 of 30
    Junior Member Two Rings
    Mar 09 2017
    rear lower control arm bushings?
    Hello all i'm new here just picked up an 07 s-line titanium few months ago after turning in a TDI .
    I'm having the common rear suspension squeak, the upper arm bushing are clearly bad so ill replace the arms the outer bushings on the lower are a looking bad as well ( not the one on the knuckle ) iv'e been searching for days for bushings but can only find the complete arms almost $300 a side ! no one makes bushings? i see a kit for the b6 but none for the b7? is getting new arms the only option ? why wont the b6 bushings work ?
    thanks!
    Mar 09 2017
    just so were were clear i'm talking about this guy here : https://www.ecstuning.com/b-genuine-...t/8e0505311af/
    Veteran Member Three Rings Luis_Heineken's Avatar
    May 28 2012
    Bayamon, Puerto Rico (USA)
    fcpeuro.com
    Mar 09 2017
    Quote Originally Posted by Luis_Heineken View Post
    fcpeuro.com
    I have checked fcp as well no one makes the bushings .
    i ordered the b6 bushing kit and will try them on my b7 arms. the last rev letter changed between the b6 and b7 arms so i hope it had noting to do with the bushings . ill post back with my findings .
    https://www.fcpeuro.com/products/aud...s4-1005051008s
    Mar 09 2017
    I received the bushing kit today and every thing looks and measures the same for the b7 arms .... any one see a reason not to use them?
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by skyway001 View Post
    Id say go for it......
    Veteran Member Three Rings JayDog747's Avatar
    Mar 10 2010
    2007 S4,2015 Silverado,2023 WRX
    WI
    Let us know how you get the "toe" bushing out.
    Veteran Member Three Rings panman142's Avatar
    Jun 21 2015
    V8_4Runner
    Akron, OH
    Subscribed, my rear LCA bushings are getting toward the end of their life
    2006 6MT, PTE 5557, Fully built engine, too many extras to list
    Mar 09 2017
    Quote Originally Posted by JayDog747 View Post
    Which bushing are you referring to ? If your talking about the two piece one that was the easiest one to remove.
    I ordered a used arm from eBay for $25 to measure before taking the car apart it got broken in shipping so I removed the bushings. I'll take pictures and do a write up in about 2 wks when I get time to take her apart but so far it looks promising!
    Mar 10 2010
    WI
    Yep. That's the one. Good luck Sky, I know what you're going through. I just did a complete front and rear setup including shocks. Car drives like its brand new again. Time to start saving up for those speeding tickets again.
    They used to sell just the bushings for the b7 about 5-6 years ago. I'm unfamiliar with what the revision was for that we have to buy a complete arm. Oh wait, yes I do...It's phuck'n greed
    Mar 09 2017
    Yes there's a difference between the b6 and b7 arms ... it's probably a bolt hole or two why they don't market bushings for the b7 is weird .
    Unfortunately I'll be doing the front arms this weekend.
    Jun 21 2015
    V8_4Runner
    Akron, OH
    Maybe Powerflex could make bushings for the rear control arms. I can shoot em an email and see what I can find. Can't imagine it'd be terribly hard to make something like that. Then again I know next to nothing about the process for making poly bushings.
    Mar 09 2017
    Well I found akmotorsports makes a complete poly bushing kit that it made to fit the b6 AND b7 which is what got me thinking about buying the b6 bushings.
    I don't want poly due to the slight increase in stiffness and the maintenance of poly is the other issue. But if one wants poly ak makes a complete kit at a decent price .
    Oct 24 2015
    Perth, WA
    My respray thread
    Jun 21 2015
    V8_4Runner
    Akron, OH
    On the B7 page on ECS's site they only have 1 replaceable LCA bushing, there is a total of 3 bushings on the control arms.
    https://www.ecstuning.com/b-genuine-...t/8e0505312af/
    That akmotorsports kit does not look bad. $414 is super fair considering 1 replacement control arm is like $280. I just had my rear upper c/a bushings done too...at least they'll come back out easy.
    Mar 09 2017
    Ecs has a kit that includes both lower arms and hardware kit at a good price compared to buying everything separate. Yes if I wanted poly ak is the way to go.
    Mar 09 2017
    Hi guys it’s been a while , I put this off in hopes of just selling the car and moving on but I just couldn’t part with it and ended up taking the entire rear subframe out getting a good used one and rebuilding the entire rear suspension.
    I’m at the point of putting the subframe back in it’ll probably get bolted up Thursday but I can’t find the torque spec on the subframe mounting bolts.
    I have new bolts and I believe they are TTY bolts I can’t find the rear subframe bolt spec in the Bentley manual found the front but not the rear can anyone supply the specs from a good source?
    Thai has been a heck of a journey had to make a handful of tools for removing and installing bushings I’ll post up some pictures when I get a chance to upload to my drive account.
    If anyone has specific questions I’ll be happy to answer them while it’s still fresh .
    Veteran Member Three Rings wding2000's Avatar
    Jul 04 2015
    08 A4 Quattro Avant; 16 Golf MK7
    Hi, Sky,
    Does Meyle B6 bushing set fit B7? Could not get it from the thread.
    08 a4 2.0t quattro avant | eng bwt 200hp | tip 6-spd zf 6hp19a | akebono ceramic | andros 18x8 et35 cb72.2 72-57 centric rings | pirelli p0as+ 235/40r18 | hu xtrons px5 mtce_gs_3.40 android 8 | rev d dv
    Mar 09 2017
    Yes the “ kit” fits but the bushing that’s goes in the knuckle is different. That’s why it’s not listed as fitting the b7.
    Jul 04 2015
    Thanks for response. There are three, which one is different? or all three? Does the difference affect usage? Did you end up using them?
    Mar 09 2017
    Quote Originally Posted by wding2000 View Post
    The kit I used is part number 1005051008S ,
    Yes I used it except for the knuckle bushing .
    The one that does not fit is the one that does not have an aluminum shell on the outside.
    Not sure I know what you mean about three different ones .
    EDIT
    To be honest the knuckle bushing is the one bushing I didn’t replace , so I can’t confirm that it won’t fit .
    If I remember correctly there are two different knuckle bushing for the b7 . again I’m doing this from memory so bear with me .
    The bushing was I good shape and it looked like it was going to be pain to change ,it was a pick you battle situation .
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    Verkline makes a poly kit for the rear control arm
    Sent from my SM-G981U1 using Audizine mobile app
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
    Mar 09 2017
    The bushing in question is VW part number 8E0505203D according to ecs it fits both b6 and b7 I’d confirm with dealer and if so then the kit I listed above will fit the b7 .
    The b6 and b7 lower control arm are a different part number and I think that’s my meyle lists it as a b6 only fitment .
    It’s all coming back now ....
    Hope this doesn’t make it more confusing , if you need more information I’m happy to help .
    Jul 04 2015
    Got it. 203D is the one called Outer. It is available for B7, and can be purchased separately, eve if not fit. But I only look for replacing some (tearing) ones, not necessarily all of them. The kit seems a good one. I might give it a try. Thanks a lot.
    Jul 04 2015
    Quote Originally Posted by vvenom800tt View Post
    This?
    https://www.verkline.com/shop/all-pa...it-audi-b6-b7/
    It is pretty expensive. I might just buy the rear lower arm instead.
    Dec 04 2011
    Kansas City, KS
    This?
    Maybe email them and see if they can sell just bushings for the lower arm?
    If not, then Find a cheap used lower arm and buy new bushings. Should be cheaper than a whole new one
    Jul 04 2015
    FCP has it Meyle B6 set for $47, and would get it if were to decide to do this job. I did bushings for front, it worked but could not say like it. Maybe I was not using correct tools or cups. Rear ones are even bigger ....
    Dec 04 2011
    Kansas City, KS
    I installed powerflex black bushings (95A) in my front uppers and it was a fight to get them in.
    Even with a shop press and all sorts of cups and spare bearings to play with it took a while.
    Having the right tools makes these jobs so much easier for sure.
    Jul 04 2015
    Not shop press, I had bearing / bushing tool set. Some metal rings are so thin and it is hard to get cup stay on them without slipping (especially under pressure). That is why I am hesitating Or I do not need to be so meticulous - it is not that bad anyway
    Dec 04 2011
    Kansas City, KS
    You can probably ask an indy shop to help you press them in. They'll probably charge you $25-50 or something. My shop charged me $50 to press in all 6 in my lowers yesterday.
