Results 1 to 24 of 24
Thread: Engine build
    Senior Member Three Rings sleepwalker_gsr's Avatar
    Jul 08 2010
    Your mom, tied up.....
    sacramento CA
    Engine build
    So my Audi has just under 150k miles on it and ive been thinking of getting a built motor dropped in. Does anyone know a good place to start looking for crate motors?
    Veteran Member Four Rings blitz2190's Avatar
    Jul 31 2014
    2004 A4 1.8T Quattro, 2.7T swap Stage 3 APR 6 speed
    NH
    not really, if you don't want to build it yourself look around your area for engine builders that have experience with audi engines, in your area your likely to find quite a few, i think some vendors/builders on this forums would not be to far off from you.
    Never argue with an idiot, they'll bring you down to their level and beat you with experience.
    2.7T Swap Wiring Guide (Psst this is a link)
    New Build In progress built 2.7 STK 2004 B6 A4- Thread and pic to come
    Jul 08 2010
    sacramento CA
    Thx!
    Senior Member Three Rings Pswish's Avatar
    Mar 25 2016
    2010 Suzuki VStrom 650
    Bay Area
    JHM and 034 are "close-by" so they might have some of that info for you.
    Early 04 1.8T Dolphin Grey A4 (planning on selling), 165k miles and counting, often in bay area traffic, LED lows & HIDs fogs, ECS Snub mount, Electric systems specialist, Photographer, 2018 Q5 on order.
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    How "built" do you want it? IE sells "crate" motors albeit at a big upfront cost - compared to buying the parts over time and working on it yourself or a local builder.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Veteran Member Four Rings jubei4769's Avatar
    Feb 09 2012
    79 VW Rabbit / 09 Triumph Daytona 675
    Kailua, HI
    Quote Originally Posted by A4SoftWalker View Post
    Was just gonna say that IE is the only ones I've seen with long and short block builds you can buy
    instagram: @low_n_slo
    https://forums.vwvortex.com/showthre...le/page2&amp=1
    79 VW Rabbit 🐇
    13 VW Golf R 🚗
    09 Triumph Daytona 675 🏍
    Mar 25 2016
    Bay Area
    Integrated Engineering = IE?
    If i wanted to go this route, i would get a parts car and rebuild that one to drop in and part the rest out... but my apartment complex would complain.
    Jul 31 2014
    NH
    https://www.performancebyie.com/ie-s...wp-valve-cover damn for that price I could build one hell of a motor
    Jun 21 2005
    Milton, Ontario
    Quote Originally Posted by blitz2190 View Post
    Would your motor include a 2.7T?
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
    2014 Dodge Grand Caravan
    Jul 31 2014
    NH
    always , I'd never build a 1.8t, wast of money in my opinion, not to knock other builds as they are well done but usable power is a big thing for me. for that price I could have built a 2.7t with fully built 2.8 heads and an efr turbo and probably have some change.
    Jun 21 2005
    Milton, Ontario
    I would agree, each application has it's pros and cons., and to each person those pros and cons ebb and flow for various reasons.
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
    Veteran Member Three Rings cmiguel32's Avatar
    Aug 13 2007
    2003 A4 / 2014 S4 / 2017 Q5
    NC
    2.7 is fantastic motor, but I think you have to have a penchant for pulling engines if you want to build a fast one and maintain it. As with any build, it always ends up costing more (either time or money) than you anticipate.
    That said, if I were going bigger displacement I'd go the R32 engine route.
    Chris
    B6 A4: 2.0 stroker, IE cams, JHM 01E/Stg4 RS4 clutch/FW, SEM manifold, EFR7163, Motoza, ID1050x, Walbro 450, Garrett FMIC, 034 mounts/RSB, Koni coils, Hotchkis FSB, 18z, VFIZ, etc.
    B8.5 S4: EPL DP 57/187 (E40), 75mm TB, Ported SC, Meth, Autotech HPFP, Killer Chiller, Borla Exhaust, Merc HX, JHM SS/3R/Race pipes, Eurocode Sway, 034 springs, CR15
    429 whp/431 wtq 93 oct (stock TB)
    Insta: QuattroNC
    Jul 31 2014
    NH
    Quote Originally Posted by cmiguel32 View Post
    oh no doubt, if I could spend the money again it would be a vr swap, but I can pull the 2.7 in a few hours now, helps to have a lift. But in the next year I'm hoping the single turbo will make that a thing of the past.
    Jun 21 2005
    Milton, Ontario
    Top mounted STK on a 2.7 I imagine would remove a lot of the trouble that goes with problematic turbos that are so far down in the stock location.
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
    Aug 23 2011
    Erie
    I have a fully built engine sitting in my basement that I mite consider selling! Shot me a pm if interested!
    Engine specs!:;
    AWM BLOCK!
    2.0 crank
    83mm pistons with je pro seal rings gasped to 24-26
    New oil pump pick up tube ect...
    IE Tuscan rods with 034 coated bearings
    ARP main bolts!
    Sold the car that I had it in and took all my aftermarket parts off and was going to eventually put them in my new Audi but I could use the cash now!
    Pm if interested
    Sorry if sometimes my post are incorrectly spelled or incorrectly worded period I have a touch screen phone and clumsy fingers. Don't make fun of me because of my literature
    Jul 08 2010
    sacramento CA
    So what I'm getting from everyone is that I shouldn't waste the money on a 1.8t and I should swap to a 2.7? What would a swap entail? Would it need fab work to make it fit?
    - - - Updated - - -
    Jul 08 2010
    sacramento CA
    Quote Originally Posted by sleepwalker_gsr View Post
    - - - Updated - - -
    So I did some research. I'm just going to add the upgrades on what I have. Everything I've read is saying that it's extremely expensive to swap motors. I'd rather work with what I've got until she blows up on me then worry about a rebuild.
    Jul 31 2014
    NH
    According to who? I just picked up the last 2.7 for $300 with $500 being the average, for around $1000 you can have pick up the engine with timing belt kit and headgasket kit. Make sure it comes with the harness. about another $500 and you can get most of the small parts. Whats your budget, a stage 3 2.7t with k04's is less expensive than a built 1.8 and makes the same to more power with a much better torque curve. But it depends on your budget, just a heads up nothing done with quality parts on an audi will be cheap.
    Jul 08 2010
    sacramento CA
    My budget is around 5k with some wiggle room in the event I need something extra.
    2003 B6: GT2871R turbo, Snow Performance Water Meth, Motoza tune, FMIC, Straight pipe, ECS RA4 Stage2 Clutch, 034 fuel pump, 034 TIP, Bosch 550cc injectors, fuel rail, 008 DV, Carbonio intake, coilovers, S4 door blades, USP front bumper and painted lowers.
    Jul 31 2014
    NH
    if your willing to do the swap that would get you close to a full stage 3 setup with tune and intercoolers. or will easily get you a nice setup on the 1.8, such as an eliminator kit but not a built motor and bt. of those options the 2.7 is going to make much more power but keep in mind the swap takes time and needs wiring done (either a converted harness, or jumper harness) and a modified exhaust.
    May 13 2008
    NoCal - EBay
    At our California cost of living that will not get you far... Are you doing your own wrenching? If not and in even if you are doing your own wrenching - your instincts to stick with elim upgrades are good. Limit yourself to the 300 hp range and your engine with some input and knowledgeable care from you will last a long time. Maintenance and nickel & dime issues will eat all your savings up quickly enough as it is. A build will easily double your anticipated costs especially if you are paying for labor.
    You will need a lot of ancillary supporting parts. What do you have now?
    In addition to turbo of sorts _ _ _ _
    Tune
    Exhaust
    Intercooler
    BBK
    Clutch
    Suspension (sways optional but have a significant effect).
    If you are a go-getter you will be at the end of your money quickly.
    If you can hover over the classifieds like a vulture then you can stretch your dollar further.
    Or you can have some combination of the 2 above options. Example I got a new oil pan from the classifieds, my Ferrea valves from ebay, Stasis BBK, Stasis center diff, and Stasis suspension on Christmas sale and so on. I exceeded my estimates easily.
    Good luck with whatever path you choose.
    'SOFTWALKER MODS
    Avant>Sedan! Click
    Jan 24 2010
    Paramus,NJ USA
    The list gets big quick depending on what your goals are.IE prices are steep as shit.You can build your own do pickup a motor here:
    http://www.eurospecsport.com/products/engines/4c-5v.htm
    Short block might be the way to go.Drop in a AEB head and be done with it.Then again this is only for the internals of the engine and man power to build these.
    Ziddy Autowerks
    Oct 29 2005
    10speed
    San Francisco, CA
    find someone selling a built block on Vortex.
    - Clint
    Dec 05 2007
    Pick up a junk yard motor, tear it apart, pick up parts, drop off parts at machine shop, have machine shop put block together, pick up assembled block, place block back in motor. If not doing the work yourself, this is another cost efficient route if not taking Clint's advice.
