Originally Posted by
spacecadet
Did you install it the right way? Dot up at the top?
Yes I have done several 2.7t timing services, no problems.
alphaVR
I would likely start with a full empty/fill of the coolant system again using the vacuum tool to ensure it's full. Afterward you can also check for air by opening the relief port on the coolant line just to the right of the power steering pump, forward of the afterrun coolant pump. Its a 6mm hex nut with a copper washer. Crack it open and make sure coolant comes out as thats the highest point of your coolant system.
I am going to do this next, full drain and fill. Last time I tried to suck with the vacuum tool the coolant that was in there. I go thru coolant with these audis like it is free. I have never touched the 6mm bleed nut on the block, it is not however the highest point on the cooling system, the heater hose is. I don’t understand the benefit of bleeding from here but it is well worth the try…
Tiluleshpingen
how is you coolant diluted? 50-50 am hoping. are you using stealership pink g12
Oh yea, one gallon at a time from the dealer. They give us “forum member” discount so it comes out to like $17.50 which I think is hella cheap.
