So Ive had two scares with the S7 over the past month, both of which have resulted in reduced engine power, very obvious misfires, EPL warning light, and notice to stop ASAP and turn off the engine. Not easy when your on the outside lane of the freeway and traveling at 75MPH
Anyway, managed to get home today in Limp-Home mode and run some diagnostics, as shown below.
Will take to dealer tomorrow and see if they can run some diagnostics. Im not tuned, but have done the exhaust modifications, so should be an interesting conversation!
10203 - Random/Multiple Cylinder Misfire Detected
P0300 00 [039] - -
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 32996 km
Date: 2017.03.06
Time: 17:47:16
Engine speed: 3186.00 /min
Normed load value: 13.3 %
Vehicle speed: 95 km/h
Coolant temperature: 95 ∞C
Intake air temperature: 32 ∞C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 12.651 V
Unlearning counter according OBD: 80
Engine status: COENG_RUNNING
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
10593 - Cylinder 3
P0303 00 [039] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 32996 km
Date: 2017.03.06
Time: 17:47:16
10205 - Cylinder Disabling
P130A 00 [167] - -
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 32996 km
Date: 2017.03.06
Time: 17:47:30
Engine speed: 3346.00 /min
Normed load value: 17.6 %
Vehicle speed: 99 km/h
Intake air temperature: 30 ∞C
Voltage terminal 30: 12.816 V
Unlearning counter according OBD: 40
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Revision: -------- Serial number: --------------
Coding: 65B6DE4BA66D7BD29B00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESP9BOSCHAU57X 004018
ROD: EV_ESP9BOSCHAU57X_VW51.rod
VCID: 418F29A4D09DC049AD-8014
1 Fault Found:
36352 - Function Restricted due to Insufficient Voltage
U1400 00 [040] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 32397 km
Date: 2017.02.26
Time: 13:07:46
VzRef: 00
Bit Info 1: 40
Bit Info 2: 0F
Bit Info 3: 22
Bit Info 4: 1F
Uz: 6B
Unlearning counter according OBD: 12
Address 13: Auto Dist. Reg (J428) Labels: 4H0-907-561.clb
Part No SW: 4G0 907 561 B HW: 4G0 907 561
Component: ACC3 H21 0053
Serial number: 00000000000000
Coding: 7E04010101
ASAM Dataset: EV_AdaptCruisContrAU57X 002014
ROD: EV_AdaptCruisContrAU57X_002.rod
VCID: 295F910448ED280995-807C
2 Faults Found:
105472 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 2
Mileage: 32397 km
Date: 2017.02.26
Time: 13:07:47
Control Module temperature: 8 ∞C
Voltage terminal 15: 11.531 V
Velocity_vehicle_reference: -0.01 m/s
Longitudinal_acceleration_vehicle_reference: 0.00 m/s≤
140288 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 2
Mileage: 32397 km
Date: 2017.02.26
Time: 13:07:48
Voltage terminal 15: 13.640 V
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G8 907 468 F HW: 4G8 907 468
Component: J533--Gateway H14 0083
Revision: -------- Serial number: 00000001943179
Coding: C0ED07481C
ASAM Dataset: EV_GatewPkoUDS 001028
ROD: EV_GatewPKOUDS_VW51.rod
VCID: 3B735B4CB271AA99F7-806E
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 2951487403
Voltage stabilizer:
2 Faults Found:
12290 - Quiescent Current
U1406 00 [008] - Too High
Freeze Frame:
Fault Priority: 7
Fault Frequency: 77
Reset counter: 25
Mileage: 31086 km
Date: 2017.02.07
Time: 17:10:32
Voltage terminal 30: 12.2 V
Voltage terminal 15: 0.0 V
Control Module temperature: 22 ∞C
System status: LIN_active
IN ESP_standstill flag: no standstill detected
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status via CAN: OFF
Terminal 15 status: OFF
Datenfeld: 0
12291 - Energy Management Active
U140B 00 [008] - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 29
Reset counter: 23
Mileage: 31128 km
Date: 2017.02.08
Time: 01:18:10
Voltage terminal 30: 12.1 V
Control Module temperature: 15 ∞C
System status: Awake_Timer_active
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 1
Address 8B: Adaptive Cruise 2 (J428) Labels: 4H0-907-561.clb
Part No SW: 4G0 907 541 B HW: 4G0 907 541
Coding: 7E04010101
ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
ROD: EV_AdaptCruisContr2AU57X_002.rod
VCID: 275B973C5EF91E7983-8072
2 Faults Found:
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 2
Mileage: 32397 km
Date: 2017.02.26
Time: 13:07:47
Voltage terminal 15: 11.932 V
Velocity_vehicle_reference: -0.00 m/s
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 2
Mileage: 32397 km
Date: 2017.02.26
Time: 13:07:47
Voltage terminal 15: 13.631 V
Address 8E: Image Processing (J851) Labels: 4H0-907-107-V2.clb
Part No SW: 4H0 907 107 H HW: 4H0 907 107
Component: BV-SG H33 0090
Serial number: 005000623007157
Coding: 03C23B1A1111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
VCID: 2C516810471F3D216E-8078
1 Fault Found:
0028 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 2
Mileage: 32397 km
Date: 2017.02.26
Time: 13:07:47
Outside air temperature: 9.5 ∞C
Voltage terminal 15: 10.8 V
Control Module temperature: 0.0 ∞C
