Results 1 to 37 of 37
    Mar 17 2008
    Removing Passenger Catalytic Converter (Failed) - 2014 B8.5 S4 (pictures for views)
    Hi Everyone,
    It appears that my OEM catalytic converter on the passenger side had snapped at the flange.
    Is it possible to replace the cat without dropping the engine or removing the transmission ?
    Car is 2014 B8.5 S4 6MT 25k Miles with AWE Exhaust Non Res with EPL stage 1 tune.
    Anyone had similar issue in the past ?
    Thanks
    Veteran Member Four Rings B18b1ex's Avatar
    Jul 02 2004
    FL
    Your car should be under warranty, why did it snap? If not your doing why not have the dealer fix this? Isn't flashing at home by EPL not it's main selling point?
    Mar 17 2008
    The car will be fixed under warranty through the dealer i have purchased the car from. However, I would like to know if there is an easier way to get to the cat other than dropping the drivetrain.
    I am not sure why it snapped but i have found couple other people with same problem.
    Thanks
    Veteran Member Four Rings Vogz's Avatar
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Quote Originally Posted by Antekaudi View Post
    Thanks
    99% sure you have to remove the trans.
    EDIT: Apparently some people have swapped cats without pulling the trans, but after doing an trans R&I on my own car, I really can't see how this is possible.
    SOLD - 2011 S4 Sprint Blue 6MT Ti - GIAC Stage 2 - Sachs XTend clutch - AWE exhaust - Bilstein B12 suspension - strat short shifter
    [email protected] 1.85 60' (stock)
    [email protected] 1.74 60' (stage 2 - 93 octane)
    [email protected] 1.71 60' (stage 2 - 104 octane)
    2020 Tesla Model 3 Performance
    2003 Porsche 911 Turbo - SpeedTech, Cobb, Bilstein, H&R and TPC goodies
    11.69@123mph 1.82 60' (RWD on street tires)
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    You do not have to remove the transmission, cat replacement is a fairly simple job, you just need the right tools and a tech that has some experience.
    Mar 17 2008
    Interesting, any more details on how can this be done without removing transmission ?
    Thanks
    Nov 20 2014
    New York
    Thanks
    I'm one of them. The flange snapped clean off the header on passenger side, had my guy pull it out and gave it a nice weld around
    Nov 20 2014
    New York
    Thanks
    Lower subframe and wiggle it out, I'm pretty sure that's what he told me he did
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    You have to lower the subframe and let the trans sag and it'll wiggle out with some finesse. It's a complete pain in the ass.
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Mar 17 2008
    Thanks. I will have them try that, worst case drop the whole drivetrain.
    Mar 17 2008
    Car is all fixed.
    Had to take out the transmission to get to it.
    Here is the catalytic convert failure:
    Jul 28 2009
    Philadelphia PA
    The flange broke off?!? I hope you did a clutch too if the shop "had to" take the trans out (which you don't cause I have done it twice myself)
    c8 a6 allroad
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Quote Originally Posted by rtl5009 View Post
    That's how a lot of these have been failing lately. Crazy.
    Veteran Member Three Rings MerkurRS's Avatar
    Oct 04 2012
    Four Passat W8's, 2003 allroad 2.7t , Ford Excursion Ltd V10, 1989 Merkur Scorpio, 1987 Merkur XR4Ti
    Berthoud, CO
    YES!!!
    I broke mine on the 3rd run at the track (after two previous horribly slow runs at 12.01 in the quarter).
    I spoke to several Audi tuners/ mechanics and no one has "heard" of these breaking. I am glad to see I didn't break something that no one has ever broken before. I ended up welding up myself. Not my best welding, but I began to remove the cat at 5:00 PM (after work) and had it installed and running by 4:00 AM.
    2012 Audi S4 Prestige Glacier White, Alcantara Leather, Titanium/ Black Optics Pkg, Auto/ Driver Assist/ Drive Select/ B&O/ Carbon Inlays, UltraCharger, APR Carbon Intake, Flat-bottom Wheel, 3G+Google Map conversion, Passport 9500ix red/carbon limited edition, Michelin A/S 3's, Armytrix/ Custom Exhaust, Spulen Diff Mount, 034 Trans. Insert, Eurocode Alu-Kreuz, ACNA Member
    Jul 28 2009
    Philadelphia PA
    That's a straight manufactures welding defect. HAZ was too shallow. Nice job getting it to line up!
    c8 a6 allroad
    Jul 28 2009
    Philadelphia PA
    Do you guys have your dp spring hangers hooked up properly to your exhaust and trans case?
    c8 a6 allroad
    Nov 20 2014
    New York
    Mine sheared off exactly the same. Had the same issue, but my guy got it out without dropping the tranny. He did my clutch a few months prior to that
    Oct 14 2012
    Empty...for now...
    SE PA
    What symptom(s) occur when this happens? CEL, loud noise, both?
    SOLD 2015 Daytona Gray S4
    Mar 12 2014
    Long Island, NY
    That happened to me the dealer repaired it under warranty because its an emissions part.
    2013 B8.5 S4| APR Stage 2+ w/ UltraCharger on E40 | APR Dual Pulley | APR DSG Update | APR CPS | Awe Non-Resonated Downpipes | JHM Test Pipes | AWE Touring Exhaust 102mm | Alu-Kruez | JHM 2-Piece F&R | H&R Sport Springs
    Jul 28 2009
    Philadelphia PA
    Federal law covers cats to 80k mi/ 8years.
    c8 a6 allroad
    Jul 28 2009
    Philadelphia PA
    It's seems awe exhaust are a common theme with this failure. They are also really popular so it could be correlated but non-causal.
    c8 a6 allroad
    Mar 17 2008
    Hangers, spring loaded bracket and the exhaust are properly installed. We could probably get to the driver side cat without removing the transmission but on the passenger side with the manual and differential in the way it was way too tight.
    The shop has seen couple failures like that on other models such as stock Audi A7.
    I wonder if having AWE or any aftermarket exhaust makes this issue appear quicker.
    Thanks
    Nov 20 2014
    New York
    I have stock exhaust and mine failed the same way so I don't think it had anything to do with the exhaust. It's just a lot
    Of back pressure on that side. I was also running a lot of E85 at that time on the race map so that probably accelerated the failure
    May 17 2012
    Houston, TX
    I am another victim of this. Passenger side flange broke off clean. Absolutely a manufacturing issue. Didn't bother with dealer because of all my mods. But after having it fixed I found I have loose and missing bolts at the DP to cat connection.
    I am looking for a DIY to drop the subframe to reach these bolts. Anyone have anything. Nothing available after searching.
    Nov 20 2014
    New York
    Quote Originally Posted by AKPS4 View Post
    Passenger side broke off clean on mine too, I have a funny video from my mechanic that I don't know how to attach of him spinning the flange on the cat pipe and it's spinning by itself lol
    Veteran Member Three Rings KnewJack's Avatar
    Apr 28 2016
    Had a similar failure. Passenger side separated at the weld on the cat itself. Replaced under warranty. Now I think my drivers side cat is slowly gutting itself. Exhaust has taken on a slightly deeper and more raspy tone.
    *2013 B8.5 S4
    APR Stage 2+ ECU/TCU 100oct Tune, JHM 187mm CP, Injen Intake. Stasis Touring Exhaust/ Springs & Rear Sway Bar, PLM HX.
    11.468 @ 122.06mph. 90ft DA. *Totaled* RIP
    2016 B8.5 S5 Prestige - APR Stage 2+ ECU/TCU 100oct Tune, JHM 187mm, modded stock air box (Loe mod!), PLM HX, OE Springs, Stock Exhaust.
    11.264@ 124.46. Best MPH 11.269 @ 125.13
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    Gutted a set on an S5 yesterday. Dropped a little over 2lbs of catalyst material from each one. They weighed 9lbs 6.4oz before starting, car was stage 2 going to ultra, but they didn't look to be in terrible shape.
    Veteran Member Three Rings jachien's Avatar
    Nov 12 2012
    Cerritos CA
    not exactly a DIY but process is similar, but try and follow 034 Motorsports install guide for their replacement motor mounts.
    https://store.034motorsport.com/blog...s4-a5s5-q5sq5/
    2013 B8.5 S5 - Dual Pulley 189mm/57mm. EPL E85 Dual Pulley/DSG flash. Autotech HPFP. APR B8 Heat Exchanger. Injen Intake. Deleted Mufflers. 034 Street Motor Mounts. 034 Driveline Mount Inserts. KW HAS + H&R F:20mm/R:25mm wheel spacers. S6 Brake Conversion
    May 17 2012
    Houston, TX
    Thanks this is helpful. Doesn't sound like anyone has attempted a cat replacement themselves so not finding any info on if subframe just needs to be lowered or if completely removed.
    Anyone have access to a factory manual for full procedure ?
    Jul 25 2010
    WI/IL
    Only have to lower it, also dip the back end of the trans. That's how we did it 2 days ago. Removed the false firewall to get access to the top bolts, then lowered subframe, disconnected axles/shields, remove downpipes, and then finagle them out.
    Active Member One Ring jwye120's Avatar
    Feb 17 2017
    2007 HD Nightster
    Milwaukee, WI
    Quote Originally Posted by jachien View Post
    Thanks for this info. I've been searching for anything I could get on the easiest way to get the cats on my b8.5. Plenty of people respond to the question but much like this thread it's not until the 28th or higher post that someone offers some real information. Instead you get a plethora of people with 5th hand information they learned from reading other posts but have no real world experience. Sorry for the rant, its just getting really frustrating having to sift through so many posts without useful information attempting to answer questions that weren't asked. It's almost like people just want to see their name on the message board.
    I'm not referring to the people posting about their actual experience. More the people saying it's super hard don't bother attempting yourself, or actually its fairly simple you just do blah blah blah.
    Nov 12 2012
    Cerritos CA
    Quote Originally Posted by jwye120 View Post
    There was a thread for some Mertop Chinese headers somewhere. I documented it as much as i could for diy’ers to be able to follow. Hope it helps.
    Edit: found it for you
    https://www.audizine.com/forum/showt...4#post12586664
    Feb 17 2017
    2007 HD Nightster
    Milwaukee, WI
    The link you already posted was exactly what I was looking for. I was ranting because your post was #28 and pretty much the first post that actually responded to the original posters' question. I'll check that other thread out though, thanks again.
    Nov 12 2012
    Cerritos CA
    Lol a lot of side commentary that’s for sure. Not just here but in other threads as well. I think the link i just provided you is a bit more specific on removing the cat, unless you plan on dropping the engine completely. Pretty much though, the subframe needs to be dropped a lot in order to squeeze the passenger side cat out without dropping the engine/transmission.
    Established Member Two Rings DankFX's Avatar
    Jul 07 2014
    My car is in the shop for this same problem, I was told they would need to take out the trans.. I did find this video showing that you might not need to but, they don't show themselves removing the cat, so not sure how "easy" it is.
    https://www.youtube.com/watch?v=eXuP7ZBkkVs
    2013 b8.5 Audi S4 DSG Estroil Blue | no tune | CTS intake | AWE Touring exhaulst |
    Solorwerks Coilovers| CR-15 | 034 Xbrace | 034 rear sway | 034 Trans mount insert |
    Jan 10 2022
    Washington, Des Moines
    Hey there I know this post is old, however, I'm wondering how long those welded cats lasted? Will it be ok to weld them back on, noting I'm getting CTS turbo motor mounts?
    Jan 10 2022
    Quote Originally Posted by MerkurRS View Post
    YES!!!
    Hey I know this is an old Post Just wondering if those welded cats lasted, Mine snapped of aswell. I'm assuming all the vibration from my failed mounts caused them to snap, would you recommend welding it back on.
