I have a 2009 A5, 3.2.
The other day i noticed an oily spot on the garage floor mostly around the front tire on the driver side. It was a substantial amount of fluid - probably half a liter i would guess. It had a sort of green tint, definately oil based.
Initially thought it was brake fuid, so i cleaned it up, took off the wheel to inspect the brake lines, which look ok. i couldn't see any evidence of a leak. In fact the brake line and other components around it were dry. The brake fluid resevoir reads full and there are no indicators lit on the dash.
My next thought was power steering fluid. I inspected around the resevoir and can't see evidence of a leak from there. The fluid in the resevoir reads full.
Any other thoughts on what it could be? The leak showed up suddenly, and i haven't seen any additional leaking in the last two days since leaving the car there.
Sent from my SM-P600 using Audizine mobile app
