Originally Posted by
q_dubz
The scoring you can't really address. Nor should you. The rings wearing are 90% of your problem.
+1. i have always been skeptical of the dogma that wall scoring causes oil consumption; it's a symptom, at best, not a cause. i've scoped my cylinders and seen minor scoring, but nothing that seems to match with my 1qt per 1000mi consumption.
kevinye77137
MMO should help out the stuck piston rings. So im guessing the gas smell on my fresh new oil is from my piston rings am I correct?
they might be stuck or they might be worn. i'm not sure MMO will help; i did a Kreen treatment & in-place piston soak (far more aggressive than MMO) and it did not seem to affect my oil consumption. if mine are stuck then it's nothing the Kreen could help, otherwise it's not because they're stuck at all - it's because they're worn.
i'm still unclear on the
exact mechanism by which oil disappears, but by now i've been convinced to re-ring and hone when i'm able to.
tsk, i wonder how many people chucked serviceable engines with bad valve seals, just because they thought the cylinders were shot. the combination of Audi's tight lips and internet forum mouth-frothing hasn't done us any favors.
- emilio
