Results 1 to 11 of 11
    Veteran Member Three Rings endy1's Avatar
    May 04 2014
    Sweden
    Facelift retrofit headlight coding
    Just done with a Facelift retrofit and cant really find what to change in VCDS for the headlights.
    Anyone know?
    May 04 2014
    Sweden
    Found this coding and it removed all bulb errors inside the car and the coming home light started to function. Will check everything tomorrow.
    Heres the code: Module 09 -- security access -- adaptation -- channel 03 -- value 26
    Jan 15 2017
    Here's a very detailed thread regarding coding:
    http://www.audizine.com/forum/showth...rsion-Complete
    May 04 2014
    Sweden
    Quote Originally Posted by Reciprocity View Post
    That is Halogen to Bi-Xenon pre facelift ;)
    Mar 29 2011
    Denmark
    Did you go from
    xenon -> new xenon
    or Halogen -> new xenon
    Can you please write a howto
    A4 B8 Revo stage 3, CTS k04, Wagner IC, 034 HFC, BN-pipes quad exhaust.
    May 04 2014
    Sweden
    Quote Originally Posted by Testubes View Post
    Did you go from
    xenon -> new xenon
    Thought i wrote xenon -> facelift xenon. Anyway i posted the coding in my second post.
    No errors in the cluster but VCDS gives me this: Nothing to care about?
    Veteran Member Three Rings IHave2Turbos's Avatar
    Aug 17 2015
    so just to clarify what you actually did:
    B8 factory xenon ==> B8.5 factory xenon? basically you put facelift b8.5 lights in your b8?
    C7.5 S6
    Mods : OEM+ Stage3 / DS1 ECU / SRM TCU / CTS HX
    B8 A4
    Mods : HPA\\\ K04 / Manifold / HFC / Tune | CTS FMIC / DP | CR-15 | ECS Inserts
    Retrofits: MMI3G+ / RVC / AHH / Color DIS / Cruise Stalks
    Aug 17 2015
    this is probably the thread you are looking for: http://www.audizine.com/forum/showth...8-5-conversion
    C7.5 S6
    B8 A4
    May 04 2014
    Sweden
    Quote Originally Posted by IHave2Turbos View Post
    99% sure that he had halogen lights before The retrofit.
    Yes.
    Aug 17 2015
    Maybe it would help if you could post your Original Long coding for Module 9 and then post your Post-Retrofit Module 9 coding ( in text not a pic).
    For example from the post I referenced he had:
    Original Coding: 690050b10034a70100010000000005f5f001d0208040001410 00000
    now on that thread tells me to do some changing
    Module [09-Cent. Elect.]
    Byte 0: Change to 26 (for xenon lights) (I Believe on some modules 23 may also be valid)
    Byte 2: Change to 10 (enable LED DRLs)
    Byte 14: Change to 1D (bi-xenon highbeams)
    Byte 15: Change to 0D (bi-xenon highbeams)
    Then we can compare.
    Lastly, I have read that some people have had luck changing the DRL brightness value which I guess adjusts the voltage draw value and may make the computer happy.
    C7.5 S6
    B8 A4
    Aug 17 2015
    Please post what your Current Value is:
    Central Electric Module ==> Adaptation channel 3 (which is labeled as turn signal dimming)
    His default value was 9.
    I have seen people changing this to 30 (your headlights need to be on to see the actual brightness change, this doesn't affect the DRL Only brightness AFAIK)
    Source: http://www.audiworld.com/forums/s4-b...djust-2821715/
    C7.5 S6
    B8 A4
