Results 1 to 29 of 29
    Established Member Two Rings Goned's Avatar
    Jan 03 2017
    SQ5/Q5 3.0T - Launch control ?
    Hi,
    I think we don't have a launch control system but anyone confirm me if i'm wrong ?
    Thanks,
    Mar 21 2015
    Did you read your manual?
    Jan 03 2017
    Yes
    Senior Member Three Rings rgvsq5's Avatar
    Feb 03 2015
    Texas
    Make sure car is up to operating temperature, steering wheel is straight and you're at a dead stop > turn off traction control, put in S (sport) mode, press brake, mash gas pedal, let off brake.... Haul a$$.
    Launch isn't super impressive, but the shifts are insane. "Launch Control" vs. not using launch control is about a .20-.30 second difference from 0-60 according to P3 gauge.
    SQ5 | APR Stage 2+ : APR CPS v2 : AWE : Bilstein : H&R : ECS Tuning : 034Motorsport : P3Cars : Adam's Rotors : E-Code : XPEL
    Mar 21 2015
    Quote Originally Posted by Goned View Post
    Yes
    Must've missed that page
    Veteran Member Three Rings soul strong's Avatar
    Mar 03 2009
    joliet
    Wait.. really we have launch control in a SUV?! I have the 3.0t 8 speed.. I just figure suv and it is what it is..
    IG: q5chris
    Mar 21 2015
    I think it's just the 7 speed sq5
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Quote Originally Posted by soul strong View Post
    Yup!
    No such thing
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Mar 03 2009
    joliet
    Awe yeah time to go fast take chances
    IG: q5chris
    Mar 21 2015
    Quote Originally Posted by q5 dave View Post
    No such thing
    I couldnt remember if it was 7 or 8 in the sq. So both models have 8 speed and LC?
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Yes
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    Some say there is no launch control because it is not a DSG. For those of you subscribed to that notion, you can call it "race-start-mode" or whatever blows your skirt up. The fact is launch control is described in the owners manual and when the sequence is followed correctly, it works like a champ. Shift points are at redline and they are hard and fast. Call it what you like, but it is the ZF8's version of launch control. It's good for about a half-second on your 0-60 time. Try it!
    Jan 03 2017
    I have check again the manual and nothing....please specify the page :)
    Veteran Member Four Rings riceboy22's Avatar
    Mar 26 2015
    2015 Audi SQ5, Felt F65x, Levy Electric Scooter
    New York, NY
    I don't think it's in the manual. Here's a link to what @spijun has posted previously about it.
    Launch Control Program
    Current
    2015 Audi SQ5 3.0 TFSI (Build Thread | Flickr | Instagram)
    Past
    2006 Lexus IS350 | 2001 Audi S4 | 2000 Honda S2000 | 1999 Yamaha YZF-R6 | 1995 Acura Integra GS-R
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Jan 03 2017
    I have read several forums and the subject is varied, half said not to do because the ZF is not intended for this and others gives the same link with the procedure ... who or what to believe .. .I have a doubt ... is it only with the Stronic?
    Senior Member Two Rings Jay337's Avatar
    Oct 24 2014
    Montreal
    this is not a launch control like dsg, it is more like a Torque converter that we use as a launch control.
    Sent from my SM-N920W8 using Tapatalk
    Current
    2018 Audi SQ5 Navarra Blue
    Past
    2015 Audi SQ5 Sepang Blue
    2012 BMW S1000RR Tricolor
    2009 VW GTI Candy White Unitronic Stage 2+
    2003 VW GTI 1.8T Reflex Silver Unitronic Stage 1 +
    Mar 13 2013
    Chicago Western burbs, Il
    Quote Originally Posted by Jay337 View Post
    Old school, brake torque the converter bu the ZF 8hp also changes its upshift program and really tightens up the shifts otherwise they're a lazy sunday drive where you lose a ton of time.
    '21 Atlas 2.0 AWD, Stg1 93/Stacked JB4 E25, Eibach Springs, AFE Catback
    '18 mk7.5 Golf R STG 2 E30, TCU, IC, Milltek DP/HFC, AW SwitchPath
    '12 Golf R APR S2 93 HPFP W/iABED RCF, IC, UM Haldex, Milltek HFC, SMF STG2, Fluidampr, RVC, PSS10, PolarFis
    '08 R32 UM ECU/DSG, Schrick 268/264,Milltek Headers/HFC, Corsa Catback , RNS 315/RVC, PolarFis
    Oct 24 2014
    Montreal
    Quote Originally Posted by tmoe View Post
    true that!
    Current
    Past
    Established Member Two Rings poncho@home's Avatar
    Oct 22 2014
    17 Mustang GT, 04 BMW 330Cic ,11 Subaru Legacy
    It holds the RPMs at 2500 or a little more and then lets you launch harder. When not enabling the torque converter can't be held past 1500, maybe even less.
    2013 Audi Q5 3.0T Quattro S-line, Nav/MMI, B&O, Pano
    2017 Ford Mustang GT 6 spd manual
    2004 BMW 330Cic 6 spd manual
    2011 Subaru Legacy 6 spd manual
    Feb 03 2015
    Texas
    Mine only revs to about 22-2300...
    Also, even when following exact instructions above, sometimes it doesn't work.
    Mar 28 2013
    Chicago
    Quote Originally Posted by rgvsq5 View Post
    I read this somewhere, but can't find it now... It requires a certain brake pedal pressure to be applied and maintained before it will activate. I can keep the car from moving even while brake torqued with quite a bit less pedal pressure than is needed to put it in "LC" mode. FWIW
    2013 Q5 3.0T Phantom/Black
    APR Stage2 | APR CPS | 034 Inlet Hose | ECS 12.5/20mm | 255/50-19 DWS06 | 034 Inserts | P3 | ...
    2020 MB GLC63, Black,
    2019 BMW M2 Competition, Black, 6MT (sold)
    Jun 17 2016
    Florida
    Quote Originally Posted by BlackSVT View Post
    is this from a 2018 sq5 or 2013? cant get it on the 2018 i tried 6 times...dont want to break the car lol
    Veteran Member Four Rings BG SQ5's Avatar
    Feb 21 2016
    '07 CBR1000RR
    PA
    The B9 has to have it. Every Audi ZF has had it this far, and the B9 S4 with the same engine/trans combo has it.
    You're not going to break anything loading the TC or launching the car. You'll increase the wear and tear, but all of Audi's advertised acceleration data was acquired using AMAX. It's designed to do it.
    '15 SQ5 Daytona Gray
    APR stage 2 104 oct (e40) - BG TCU (via HPT) - CTS s/c & FD 187 crank - Autotech HPFP - aFe filter/034 tube/modified box - MercRacing h/x - AWE Touring
    21" Forgestar CF10s w/295s - KW Street Comforts - 034 mounts, RSB & end links - ecodes - deAuto LEDs - P3 w/ECA - VCDS
    11.340 @ 120.63 (673 DA) - street trim
    11.012 @ 124.22 (-1346 DA) - track trim
    Instagram: @bg.sq5
    Veteran Member Four Rings arjun90's Avatar
    Dec 27 2014
    2013 Audi Q5 3.0T
    I shouldn't have stumbled across this thread
    Current:
    | Audi Q5 (B8) 2013 (3.0T, Quattro) |
    70,xxx Miles
    | Audi A6 (C6) Avant, 2010 (3.0T, Quattro) |
    182,xxx Miles
    Gone But Not Forgotten:
    | Audi A6 (C5) Avant, 2004 (3.0L, Quattro) |
    221,386 Miles [April 2014 - March 2022]
    New genuine Audi/VW parts for cheap within the US - audiusaoemparts.com
    New genuine Audi/VW parts for cheap if you can afford the wait - oemVWshop
    Veteran Member Four Rings spijun's Avatar
    Oct 10 2010
    Audi Q5 2.0TFSI S tronic
    Sarajevo, BiH
    Launch control exists in all models and with different gearboxes, Q5, A4, A5, S5 A6, S6
    Veteran Member Three Rings 4-ring-sleepers's Avatar
    Feb 17 2018
    2018 SQ5/2021 SQ8
    Central FLorida
    Like stated. In the B9 SQ5 you hold the traction controll button for atleast 5-10 seconds. mmi will notify traction is OFF. Next you put the car into D and down again into "S" (you can also do this when already in "S" mode by disable traction control). Press the brake pedal ALL THE WAY to the FLOOR. Next Press the Gas pedal ALL THE WAY to the FLOOR. the car will rev up to about 3,500 rpm and then hold its rev around that point. after a second or two, release your foot off the brake and hold onto the wheel tight. the car will take off. I have track slips of 12.69 1/4 in my B9 Sq5 using launch control everytime flawless on the 3rd yellow light!
    Jan 08 2016
    Los Angeles, California
    A bump to this old thread just to confirm this works with the TDI as well. I hit a wide-open stretch which is quite rare in these parts so I followed the launch control procedure exactly as described in the screenshots above. It was like a night and day difference. Almost zero turbo lag but perhaps even more pronounced was the ferocious gear shifting. You can really feel each and every gear change strongly reverberating through the drivetrain, they are that fast and hard.
    '14 Q5 TDI Premium Plus S-Line w/ Black Optics: APR ECU Tune, DTUK TCU Tune, Magnaflow 3" Catback, SQ5 BITDI Intercooler, Hi-Flow CP4 Metering Valve, AFE Dry Flow Air Filter, Full ECS Drivetrain Inserts, AG M610 Wheels, 034 RSB with Moog Endlinks.
    Launch control
    Hi,
    Thanks,
    Perhaps your note is dated, but I’m making comments on a 2021 SQ five from the owner manual. There is launch control section that describes how to use it.page 102.
