Results 1 to 11 of 11
    Nov 20 2016
    Toronto, Ontario
    Window Tint - Can the sliding window sealing mechanism on our cars ruin new tints?
    Might be a stupid question but I know they advise you not to roll down your windows when you get new tints however I was just thinking about how our windows roll down a bit when we open our door and then roll up to create a good seal due to the frameless design. I was wondering if this could possibly ruin new tints?
    I was wondering if I should be looking into letting my car sit for about 4 days if this is the case. Also the shop tinting my car said they don't remove any panels to install tints in the A5 because of the frameless design - is this consistent with whoever you guys got your tints from?
    2013 Audi A5 S-line Daytona Gray - Gloss Black RS5 Grille - Gloss Black Window Trim - H&R DRA Spacers (20mm front and 25mm rear) - Burnt Copper Calipers - B&O + 10" Alpine Type S Subwoofer w/ JBL 500W Amp
    Active Member Two Rings th3hawaiian's Avatar
    Aug 24 2016
    Dallas, TX
    Quote Originally Posted by Audi-6ix View Post
    Might be a stupid question but I know they advise you not to roll down your windows when you get new tints however I was just thinking about how our windows roll down a bit when we open our door and then roll up to creates a good seal due to the frameless design. I was wondering if this could possibly ruin new tints?
    I didn't have any problems with mine at all. Drove away with mine immediately after they were done installing. No rips, no nothing. HTH
    Veteran Member Three Rings PEM's Avatar
    Jul 17 2014
    NoVA
    No issues with tint in my car. The most risk would be the first day or two so I had mine done on a Friday so I could have it sit all weekend in the sun to dry up. They didn't have to remove any panels either. I wasn't aware tint shops had to remove panels to do tints.
    Veteran Member Three Rings Strong Man's Avatar
    Jan 24 2017
    Quote Originally Posted by PEM View Post
    +1
    2013 Audi S5 3.0T: Custom Audison with B&O, Quattro Sport Differential, ADS, 7-speed dual-clutch DL501
    Mods: ||ST2: Unitronic ECU + TCU + Ported SC & Throttle||Intake: ESC Kohlefaser Luft ||Exhaust: AWE Touring with Resonated DPs 102mm tips||Susp:CR15, Alu K, H&R OE, H&R R Sway Bar, ECS Drv Mnt Insert Kit ||H&R Spacers: 15F/20R || Brakes: ECS SS Lines, StopTech BBK Creo Slott Rotors F/R, HAWK 5.0 F/R, Motul 600 || etc.
    Mar 18 2015
    2015 GL450
    IL
    No issues with mine at all. The drop when opening the door is minimal. I think that the bigger danger would be rolling the window down and stripping off a large area.
    Sent from my iPhone using Tapatalk Pro
    2016 S5 6MT - Brilliant Black, P+, High Gloss Black, Sport Dif, B&O, Tech, Nappa
    Engine: GIAC Stage 2 & SC Pulley / ECS Carbon S-Flow Intake
    Suspension & Wheels: H&R Street Performance Coilovers / Vorsteiner VFF-103 (Carbon Graphite)
    Cosmetic: OEM RS5 Grill / PPF & CQuartz Finest Coating / 35% Pinnacle Tint
    Veteran Member Four Rings mopaNi's Avatar
    Aug 02 2016
    Columbus, OH
    Moleskin?
    mopaNi | 2013 S5 Premium+ 6MT Estoril
    Veteran Member Four Rings Ajp428's Avatar
    Jan 12 2013
    1999 Mercedes E430 SOLD
    Long Island
    Quote Originally Posted by RVJ View Post
    This. mine turned out just fine as well. Just don't put down fully.
    Monsoon Gray 2013 Audi S5 Premium Plus
    Ibis White 2010 Audi A4 Premium SOLD
    instagram: @s5auce + eurograde_
    EUROgrade
    Established Member Two Rings Scalways's Avatar
    Nov 16 2016
    Carlsbad
    Shouldn't be a problem. I don't have the windows that move but I've had and done tint since I've been driving. I don't see that minimal movement affecting anything. I've had new tint rolled down by a passenger it didn't do anything. And honestly if it did your shop would fix it and then I would say don't drive the car. JMO
    Nov 20 2016
    Toronto, Ontario
    Quote Originally Posted by mopaNi View Post
    Moleskin?
    Didn't think we needed moleskin on our cars. Can someone else confirm?
    Jul 25 2011
    I've never had a problem with tint on this platform. You will be fine.
    Aug 02 2016
    Columbus, OH
    I haven't had issues either. Just saying what I know to be a product to fix it.
