Just curious to see how others solve this problem. I don't have Audi's special little tool to raise it or compress the top links into the knuckle.
Generally when I do this the car is on jack stands at the normal jack points on the side rails. When it is time to tighten anything on the suspension it is required to have it at "ride height" which involves compressing the suspension/strut and raising the assembly enough to simulate vehicle weight.
How do you all do this safely and reliably?
I usually use a floor jack under the side of the steering knuckle but it always seems very sketchy as there is no good spot because of the lower control arms. Also it always wants to pivot out or around since the upper control arms aren't connected yet... making it damn near impossible to get them into the knuckle. It is always a frustrating and sketchy time and I'm nervous getting in there to tighten things because it feels so haphazardly supported.
Any tips or tricks? I'm currently in a situation even more complicated now because I replaced the axles and bearings and don't want to jack it up at the hub at all since the axle bolt is not tight.
