Results 1 to 27 of 27
    May 17 2012
    Houston, TX
    budget coilover experience needed.
    So it's time to make a few upgrades. First, I ha e cracked bushings confirmed by dealer. Second, hit a nasty hole on the road because the dumb m$:&27&;!:$ ahead of me didn't care and smashed right into it as well. Didn't bother to move to suggest a road hazard. Anyways, now I've got s constant vibration. Could be bent rim but hope not - flow forged wheels. Maybe bent control arms? Who knows. Lastly, tires are starting to rub fender on deep dips at high speed.
    Using this as excuse to upgrades the upper control arms I have. Get all new lower arms. New bolts all around.
    Current suspension is all bolt on typical upgrades but H&R OE springs with factory shocks. Can't spend 2k on bilstein coils so, do I go budget coilovers OR keep springs and go with bilstein shocks? Looking for experience from those with the budget coils (<$1k). Live in Houston TX now so no snow or salt. Just high humidity and water. Looking for 50k miles+ out of whatever I go with. No track use. Just performance on streets.
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    I'd suggest Bilstein b12 pro kit instead of oe springs + Bilstein shocks.
    At the same time, I've heard st x performance coilovers are as good as kw v1's. Just a different material. If your location doesn't have salt water, st x might be as well a good choice.
    Personally I'll go for Bilstein since I don't really need height adjustability and for their monotube design.
    Current: '18 M3 ZCP
    Mods: | E85 | BMS Intake | MPE | BBS Fi-R | Brembo GT F+R BBK |
    Sold: '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL 179/57+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | ECS RS5 Front BBK | Macan Ducts | Brembo GT Rear BBK | AWE Touring | IE Intake | Bilstein B12 | USP Led kit | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    Veteran Member Three Rings AudiKerl's Avatar
    Jul 07 2012
    MN
    I'd go with ST Coilover's had them on on prev B8 S4 for 3years had they rode perfectly and comfortable ride wasn't harsh at all
    Mods: Cool Audizine license plate frame.
    Apr 05 2016
    Dallas, TX
    I can second the ST's. Ride is very good and quality seems up to par. I do hear a creak every now and then, but not enough to annoy me.
    Veteran Member Three Rings toastsauce's Avatar
    Apr 08 2014
    Jersey City, NJ
    Anyone have any experience on the B12 kit vs coilovers? If you get non adjustable coilovers, what's the difference between them and the B12?
    2014 Audi S5
    034 Stage 2+ ECU & TCU | 75mm TB | Ported SC | Roc Euro CAI | Merc Hx | B12 Pro Kit | 034 Rear Sway + Links | 034 Motor Mounts
    JHM Test Pipes | EC Alu Kruez | CR-15 | EC T&B Diff & Trans Mounts | USP SS Brake Lines | EBC Yellow Stuff Pad | BP Slotted & Drilled Rotors
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    Vogland hands down. Or step up a bit and get h&r street.
    If you want higher spring rates in rear get the vogland avant coilover. B12 is good too but I like to adjust to my desired height
    Nov 21 2013
    Texas
    No question. H&R streets. Had them on my '13 and loved them! Not too firm and not too soft. I debated the vogland, STs and the others that are < $1k but at the end of the day I read too many "I wish I spent more $ on more reputable coilovers" that I waited to find a killer deal on a used H&R setup and it was perfect.
    2013 Brilliant Black S4 - SOLD :(
    Navi / Advanced Key / B&O / Sports Diff / Carbon Atlas Inlays / SC badges / Black Alcantara
    Modifications: AG M510 19x9.5 +40, Black optic grill, H&R Street Coilovers
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    Quote Originally Posted by toastsauce View Post
    unless you spend $2k+ on a set of nice coil overs, the bilstein b12 kit is the best option.
    b12 are eibach springs + a matched set of bilstein b8 sport dampeners. i bought my set from Ajusa.com for $600 shipped. it was cheaper than buying the 4 shocks separately.
    ST's are way too cheap for my liking and living in a cold weather climate i worry about rust and corrosion on the shock body. i also feel like i would forever be fiddling with the ride height.
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Aug 05 2016
    San Antonio, TX
    Solo Werks
    2014 Audi S4 | Glacier White | Sports Diff
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    Quote Originally Posted by AKPS4 View Post
    I had ST coilovers in my S5 and loved them. Very comfortable for a daily with some spirited driving. Never tracked the car so I don't know how well they'd do if your into that.
    Also, I'm curious as to why you called the person in front of you a "dumb m$:&27&;!:$" for not moving around the pothole to alert you of a road hazard, when you didn't move around the pothole yourself to alert the person behind you. Im thinking this is 100% your fault and you have no business blaming the guy driving in front of you.
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Veteran Member Three Rings Silverbullet S4's Avatar
    Mar 10 2015
    CO - 6,200' +
    Quote Originally Posted by kdn0789 View Post
    Solo Werks
    I can't comment on the other recommendations but can second this recommendation. Very happy with mine!
    2013 S4 - APR Stage 2+, DP, CPS v3, BLQ 20s, Solo Werks coilovers, CR-15, EBC Rotors F&R, Deval diffuser, AWE exhaust & USP Intake - TD1 inevitable
    Veteran Member Four Rings AudBoost's Avatar
    Apr 05 2005
    Tampa, FL
    Quote Originally Posted by tar View Post
    I definitely recommend the Vogtland CO's on a budget. Like mentioned above I would get the avant springs as the rear spring rates are higher. The sedan springs are a little soft in the rear.
    2016 S6
    Jul 07 2009
    Socal/IE
    Quote Originally Posted by AudBoost View Post
    H&R Street VS Vogland avants? which would you choose? i think the spring rates are rather similar. i know the vogland are higher front 740? 440rear? and h&r are 450/450 if i remember right.
    Aug 10 2016
    Ohio
    I was looking at solos for my a3.
    May 17 2012
    Houston, TX
    Quote Originally Posted by DannyDeez View Post
    Not really blaming fault on anyone since it was impossible to avoid. But I always avoid any road hazards all the time. This just shows the person in front is in the 99% majority of the world that doesn't care. They ran through anything and then ask themselves why they get car problems while in the shop. End rant but the person in front is still a moron period.
    Veteran Member Three Rings AvusPdx's Avatar
    Jan 17 2015
    Portland, OR
    There are a group of coil overs that comes from the same factory in Taiwan. They just change the color of the struts/springs to make it "your brand". They are not good, and its all the same. Anything under $800, I would assume its coming from that Taiwanese factory.
    Current - Audi B8.5 S4 2013, Mercedes Benz GLE350 2016, Volvo XC60 T5 2015
    Mods - H&R RSS Clubsport, APR stage 2 + pulley, Roc Euro intake, AWE Touring 90mm, ECS RS4 Gloss Black Grill, VMR V705 19x8.5 matte black, Blizzak LM32 225/40/19 (winter) OEM Q5 Peelers 20x8.5 et33, Dunlop Sportmaxx 245/35/20, EBC Slotted/Drilled rotors F/R, EBC redstuff brake pads, Motul RBF 600 brake fluid, Enlaes rear CF spoiler, LED interior light swap, LED fogs, H&R rear sways,
    Oct 08 2015
    Quote Originally Posted by AvusPdx View Post
    Not sure if what you said is true, but major venders here don't carry many coilovers under $800, except for the b12 pro kit, which doesn't belong to coilovers, technically.
    Current: '18 M3 ZCP
    Apr 05 2005
    Tampa, FL
    I can't personally speak for the H&R Streets but I have the Vogtland sedan CO's and they have been great. Vogtland advertises .75" to 1.8" drop and I can tell you they can lower more than that. My car sits about 25.75" from GTF and the CO's still have more than half of the threads exposed for lowering.
    2016 S6
    Dec 20 2016
    OC, CA
    I've heard (from a vendor) that the biggest complaint with the b12 is the ride is too harsh? Can anyone confirm? From my reading on here, most people say they love the way the car feels after going with them.
    Veteran Member Three Rings Batman0424's Avatar
    Dec 11 2015
    2020 SQ5, 2020 Audi Q3, and 2010 Mini Cooper S
    Hopewell, NJ
    Quote Originally Posted by jlaudio View Post
    How do the Eibach springs compare to H&R OE?
    2020 Audi SQ5
    Apr 08 2014
    Jersey City, NJ
    ajusa.com has a sale going on on the B12's...lowest price I've seen right now at $662 (for my S5). Thinking of pulling the trigger
    2014 Audi S5
    Jul 07 2009
    Socal/IE
    If you could do it over would you go with sedan or avant.
    Mar 26 2009
    SLC, UT
    i bought from them and had no problems. great communication and customer service. you won't be dissapointed with the b12 kits.
    Quote Originally Posted by Batman0424 View Post
    i think they are the same height wise. eibach is a progressive rate spring making it ideal for a DD car.
    here is a good thread on the b12 kit, h&r oe springs with bilsteins, etc
    http://www.audizine.com/forum/showth...ade-over-stock
    '21 SQ5
    Veteran Member Three Rings G_Wagon's Avatar
    Jan 21 2017
    Cabbagetown, Atlanta, GA USA
    Heads up...ECS has several coilovers on major sale...
    I just bought a pair of H&R coilovers for my c5 a6 Avant and they were $888! Looks like this was the last pair for at that price bc right after I bought them the price went up to $1200...
    I know for sure there is at least 1 more pair for the c5 a6 sedan on sale over there and haven't looked much more...hope someone can use this info to save some cash
    Apr 05 2005
    Tampa, FL
    Avant for sure
    2016 S6
    Jul 07 2009
    Socal/IE
    Avant for sure
    Gonna order today. Don't see any reason to go higher end stuff and only ever heard great things about vogland. Doing avant setup so thanks for the advice.
    Established Member Two Rings SprintBluStasis's Avatar
    Dec 19 2016
    Statesville NC
    OP, if I'm not mistaken, ST is an "off-brand" of KW. Might be worth a look
