Looking for some suggestions here on what to prioritize...
Previously started my car... started to drive... got about 10 feet and then it cut off and died. Each time it started right back up and ran perfectly. Third time came today in the midst of torrential rain and it would NOT start back up. It sort of wanted to, but either wouldn't really fire, or fired and choked right out. It eventually did start after sitting about 10 minutes and ran fine there after. Not sure if it is relevant but each of these times I had already been driving the car and then stopped to run a quick errand and this happened on restart.
I ran VCDS for faults and had nothing. I listened for vacuum leaks and couldn't hear anything and didn't see anything (although we all know they can be hard to spot or hear).
The PVC valve had been replaced about two years ago under a recall... is there a way to tests that as a culprit? And what about crank sensors, etc.? Not sure on the age of the fuel filter, but it's probably been a while.
Thoughts on what to look for?!?
TIA
