Originally Posted by
CJ_
I did it! This is my information from that thread you posted. Been running them for over almost 2 years now. One of my favorite mods by far
I should have put two and two together lol. I've been reading all night about the conversion and knurl Dia. And the size of the hole.
That thread made me think too much lol. There's a number of studs that would have worked, and I narrowed it down to a few Dorman ones and ARP 1007708. Didn't really want 3" studs, simply because I didn't ever plan to run over 15mm spacers.
julex
press fit studs are awesome.
After years of fighting with wheel bolts I initially purchased screw in set a while ago and run it with spacers. Eventually I figured out a formula for rim, its offset and wheel size, settled on OEM audi R8 rims 8.5x19 for front and rear (This is for 01 Allroad) and at that time I purchased bolts-to-studs wheel adapters (H&R Trak+ I think it is called).
Adapters attach with bolts to hub and present press in studs for wheel side.
There is simply no comparison in comfort when changing wheels between bolts and studs especially if you also have a loose spacer sandwiched in there.
After pricing it out, it would have been almost $150 for press in studs, vs the thread in type. I'm going to tap the bolt hole first and see what happens, if not I'll helicoil it and be done. Eventually, press fit studs would be the way to go. Easy to replace if you ever need to
Sent from my SM-G935W8 using Tapatalk
