Results 1 to 25 of 25
    Sep 05 2013
    Ottawa, Ontario
    Has anyone ever tried this 02 spacer?
    Has anyone on here ever tried a spacer like this one and have successfully set readiness for CAT?
    Thanks
    http://germanoem.ca/parts/exhaust/o2...11619-vib.html
    Veteran Member Four Rings yxri's Avatar
    Dec 27 2016
    Ford Lighting
    Ohio
    Yup those work magic.
    Established Member Two Rings EuroEnduro's Avatar
    Nov 01 2015
    2008 BMW 335xi
    Ottawa, ON, Canada
    If you want a cheaper option, you can buy spark plug anti foulers from Napa (I might be able to find the part number). The pack comes with 2, and you need both.
    What you do is drill the one out so the 02 sensor fits inside, then cut a 1" x 1" square of steel wool. Then, put the steel wool in, and screw the two anti foulers together, then put into your exhaust. Worked in my 2004 1.8t throwing a P0420 code
    2003 Audi A4 Avant 1.8t Quattro - 6 speed swapped - RNS-E - k04 - 386cc Injectors - RaceTec FMIC - Forge 007 DV - Unitronic 2+
    Check out my Build Thread! http://www.audizine.com/forum/showth...t-Build-Thread
    Veteran Member Four Rings blitz2190's Avatar
    Jul 31 2014
    2004 A4 1.8T Quattro, 2.7T swap Stage 3 APR 6 speed
    NH
    Quote Originally Posted by EuroEnduro View Post
    this^, also you may have to play with the amount of spacers, angle, etc. Sometimes it just works others may have to make adjustments until it does, typically with no cats you have to pull it out more then if you have HFC and then it depends on how much those HFC's flow.
    Never argue with an idiot, they'll bring you down to their level and beat you with experience.
    2.7T Swap Wiring Guide (Psst this is a link)
    New Build In progress built 2.7 STK 2004 B6 A4- Thread and pic to come
    Sep 05 2013
    Ottawa, Ontario
    Would you insert the wool in-between the two foulers so that the wool sits directly under the 02?
    Jul 31 2014
    NH
    Quote Originally Posted by K04-B6 View Post
    basically yes, you may need to stretch out the wool with the 02 by pressing it in a little before you tighten the two spacers together, also sometimes you don't even need the steel wool, try it and drive for a week or so and see if your code comes back.
    Sep 05 2013
    Ottawa, Ontario
    Quote Originally Posted by blitz2190 View Post
    That's the thing. I never got a code. I just can't set readiness for CAT.
    Jul 31 2014
    NH
    you have a bad tune then, its just turning the check engine light off and associated code without setting readiness, If I remember right you were having issues with this in another thread right?
    Mar 05 2013
    CA
    Quote Originally Posted by yxri View Post
    yes I heard they work
    Sep 05 2013
    Ottawa, Ontario
    Yes you’re right. My 02S is finally setting now but it’s just the CAT readiness that’s not setting. It used to set with my stock cat with the tune, Ever since I installed the HFC it hasn’t passed readiness.
    Nov 01 2015
    2008 BMW 335xi
    Ottawa, ON, Canada
    Yes, insert the steel wool right beside the 02. I tried it without the steel wool and still had the code pop up.
    It's weird its not setting the readiness code. Sometimes it can take a lot of km to set it. However, I believe I was told you can have one readiness check that's not ready. But the catalyst is a pretty essential one, so not sure if it applies to that one.
    How many km have you driven with the HFC? Do you have any pending faults?
    Sep 05 2013
    Ottawa, Ontario
    I can have one readiness not pass and still pass emissions but I removed my Sai and I was hoping to have that readiness to be my "1" failed. I'd like to have my cat to pass as I feel it's essential like you stated. I have a pending code after I hit the highway for p0171 "lean" that I still haven't been able to rule out. I'm still trying to figure out if it's the tune or not. Since I've been having this issue for 4 years and it comes up more often in the winter time.. I'm going to be doing a smoke test hopefully this week and determine if I have any leaks. Everything is basically new as for vacuum lines and tip.
    Jul 31 2014
    NH
    you have a small vacuum leak somewhere it comes up more in the winter as your car takes in more air when its cold and that probably pushes you just over the limit. Start with a boost leak test.
    Sep 05 2013
    Ottawa, Ontario
    I've done multiple boost leak test with no leaks detected. Hopefully this week I can build my EVAP smoke testing machine and smoke test the whole system to be 100% certain. I keep burning up my turbo to cat gasket so that's probably throwing my readings off a little as well. I have parts coming this week to fix that and then i'll know for sure.
    Dec 25 2004
    Earth
    My N75 was leaking internally...and it was new from Audi...
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Sep 05 2013
    Ottawa, Ontario
    Just an update, I installed the spacer with the middle sized restrictor and I am now happy to say that I pass readiness for my CAT. Definitely a good product!
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    That's nice that you are "fixed" and came back to report your success for others to benefit from.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Jun 21 2005
    Milton, Ontario
    Quote Originally Posted by MikTip View Post
    I think that should be fine since the atmosphere part of the N75 just gets routed back into the turbo inlet pipe as the stock configuration. That air then gets re-metered by the MAF and ingested into the intake tract.
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
    2014 Dodge Grand Caravan
    Sep 05 2013
    Ottawa, Ontario
    Quote Originally Posted by A4SoftWalker View Post
    Thanks man! It's about time I have this figured out. It was a combination of needing this spacer and having the right gasket (FELPRO) to seal my tiny exhaust leak I had on the turbo to CAT flange.
    Veteran Member Three Rings Andy_FL's Avatar
    Mar 01 2004
    South Florida
    Just for anyone searching the archive in the future..... I figured I would try just about the cheapest O2 sensor spacer there was. Can't really beat $8!! And so far, so good - no MIL.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Sep 05 2013
    Ottawa, Ontario
    Quote Originally Posted by Andy_TN View Post
    I have the same one at home and I didn't have a CEL either but I couldn't pass readiness for CAT for emissions. I took that spacer out and placed the one that's in post #1 and I now pass readiness for CAT.
    Mar 01 2004
    South Florida
    Emissions.........what's that?
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    What I run on my car so I don't smog out the guy behind me in traffic.
    Dec 12 2009
    Riverside, CA
    The catalyst sensor readiness comes with just driving the car. When i reset it takes roughly 40 miles before i have the readiness set for catalyst. The one thats stubborn for me is the "secondary air" readiness
    Sep 05 2013
    Ottawa, Ontario
    Quote Originally Posted by Spades View Post
    Yes it normally does, but with my HFC the readiness wouldn't set since there was too much flow. The spacer I installed fixed this. Are you running a High flow cat? your readiness might not set for SAI if you're running a test pipe or HFC.
