Results 1 to 40 of 56
    Apr 05 2016
    What oil for b8 s4?
    I have a 2012 Audi S4, haven't owned it for a while, and my first oil change is coming up. I was wondering what spec I should be looking for VW 502 00, or 505 00 or am I off? Also I was going to go with Liqui Molly, has anyone been using this in their S4?
    Thanks in Advance!
    Active Member Two Rings robeeeerob's Avatar
    Sep 04 2016
    Los Angeles, CA
    Quote Originally Posted by Ks3.0 View Post
    Thanks in Advance!
    5w-40
    I like LiquiMoly, thats the one I use. Specifically, "Leichtlauf High Tech 5W-40." It's good stuff.
    Mobil 1 0w-40 is also a popular choice, and is VW 502 / 505
    Veteran Member Three Rings weagle1856's Avatar
    Dec 15 2015
    Audi TT 225, Audi A4 Avant, VW CC, BMW X5
    Denver
    Liquid moly top tech is good, Motul XCess is good, and Motul Specific is good. Go for 5w-40. Welcome to the family!
    Sent from my Nexus 6 using Tapatalk
    Veteran Member Four Rings Vogz's Avatar
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Shell Rotella T6 is one of the best performing 5w-40 oils out there and it's also one of the cheapest.
    SOLD - 2011 S4 Sprint Blue 6MT Ti - GIAC Stage 2 - Sachs XTend clutch - AWE exhaust - Bilstein B12 suspension - strat short shifter
    [email protected] 1.85 60' (stock)
    [email protected] 1.74 60' (stage 2 - 93 octane)
    [email protected] 1.71 60' (stage 2 - 104 octane)
    2020 Tesla Model 3 Performance
    2003 Porsche 911 Turbo - SpeedTech, Cobb, Bilstein, H&R and TPC goodies
    11.69@123mph 1.82 60' (RWD on street tires)
    Senior Member Four Rings
    May 20 2015
    Audi S5 Deep Sea Blue Pearl
    PA
    I have always went with Mobil 1 euro formula 0w-40 in all my Audis. Ran it in my B5 S4 that was stage 2 and when i sold it it had 205k with the STOCK K03 turbos & still pulled like hell. In my 2010 S5 with the 4.2 i run it and it doesn't burn ANY oil in between 5k oil changes which is absolutely amazing. I may have to add a few ounces getting close to 5k, only because of my OCD'ness and having the oil perfect on the dipstick and the mmi. the 0w helps a little with the really cold start mornings in PA.
    All and all all the oils mentioned above will work just find if you change every 5k. I just stick with the Mobil 1 because its always on sale at walmart in the 5 gallon jugs for like $24 each. I have always been curious to try something different, was going to try the Rotella T6 the one time but never did.
    Established Member Two Rings vanguard12's Avatar
    Jan 05 2017
    I use Mobil 1 0w-40 every 5000 miles.
    Sent from my SAMSUNG-SM-G900A using Audizine mobile app
    Veteran Member Four Rings shadycrew31's Avatar
    May 27 2013
    West Chester, PA
    Which oil to use thread # 8234897
    2010 S4, DSG, too many random parts. 2004 Mazda RX-8, was highly modified then went back to stock.
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    For some unexplained reason, these cars seem consume less oil with Mobil 1. I usually use either Valvoline full synthetic or Mobil 1 European formula. There are a wide range of products out there that meet Audi's specifications
    Dec 14 2015
    Orange County, CA
    Motul 8100 X-Cess 5w-40 here. Engine sounds happier with it compared to the M1 0w-40 I was running in it.
    Here's a 5 liter jug of it on Amazon: http://a.co/7gZRvds
    *GONE* 2016 S4, Premium Plus, BO Package, DSG, Sport Diff, Daytona Grey, CR-15 Strut Brace, EuroCode AK, 034 Trans Insert, ECS Drivetrain Inserts, 034 Rear Sway Bar, HRE FF01 19x9.5 Wheels, Brembo GT 380mm BBK, EPL Stage 1 & DSG Tune
    2020 BMW M2 Competition, M Drivers Package, White
    Veteran Member Three Rings wangshuo1989's Avatar
    Jan 09 2016
    Quote Originally Posted by vanguard12 View Post
    Same here, my car consumes about 0.2 qt every 5000 miles.
    2013 S5 Misano Red, DSG, B&O, Sport Diff, MMI+, JHM 207mm crank pulley (7PK1370 Contitech belt), APR Stage II Dual Pulley, APR TCU tune, APR CPS, CR15, IE CAI
    2018 XC90 Inscription, B&W sound, Convenience Pkg, Air suspension
    2014 Mercedes E350 rwd
    2021 BMW 540i
    Veteran Member Three Rings Jv218's Avatar
    Jun 10 2015
    15 S4, 2012 civic
    Boston
    I've been using total 9000 quartz for the last 1200 miles and so far so good. I will be getting a black stone done on it
    15 Ibis white, Dsg, P+, magma interior, F1 35% pinnacle tint, ECS RS4 grill, AWE Track 90mm tip, 19x9.5inch HRE FF01, ECS Carbon Intake
    Established Member Two Rings CraigAudiS4's Avatar
    Nov 16 2016
    Olney, Maryland
    Frequency of oil changes.
    I bought my car at about 12,000 miles and had it serviced (Audi Care). It now has 22,000 and is due soon for service again. I just bought the dipstick and WOW I was amazed how dirty the oil was. Black, really black.
    Looks like the Audi recommended 10,000 miles is not going to cut it. Guess I will have to take it to an oil place in between or change it my self ( I don't have a pump and getting to the drain plug is not easy).
    What are other people doing? And frequency ?
    2015 S4 Phantom Black with RS4 Grill, 19" stock Rims with Dunlop Signature HP Ultra High Performance All Season Tires, Painted Mirrors Black and still 100% stock Engine.
    Sep 04 2016
    Los Angeles, CA
    I prefer to do mine every 5,000 miles.
    Apr 05 2016
    Portland, OR
    I do mine every 5k.
    I have audi care as well so Audi and I alternate doing them.
    FWIW, I am able to do my oil changes with the car still on the ground pretty easily.
    If you buy some ramps or a jack it will make it even easier.
    All you have to do is remove the belly pan to get to the drain plug. Takes all of 10 minutes.
    Geoff
    Jan 09 2016
    Quote Originally Posted by CraigAudiS4 View Post
    I use a oil extractor, takes about 15 mins total, really easy and clean. I was able to get out 7.2 qts and I put back 7.2 qts.
    2021 BMW 540i
    Sep 04 2016
    Los Angeles, CA
    I have this oil extractor:
    https://www.amazon.com/Mityvac-7201-...=oil+extractor
    Well worth the purchase. Saves a lot of time and mess.
    Nov 16 2016
    Olney, Maryland
    Quote Originally Posted by robeeeerob View Post
    Thanks all. I will have to look into this.
    Is the oil clear at 5000 miles ? On all my previous cars I had the oil changed every 3000 or 4000 miles (non-synthetic) and it is always very clear, or at least similar to when it comes out of the can.
    Sep 04 2016
    Los Angeles, CA
    I wouldn't exactly say it's "clear", but it's definitely not as dark as 10k-mile oil.
    Sep 04 2016
    Los Angeles, CA
    IMO, most new motor oils become substantially darker even after just a few days or miles (whether the oil change was done through tradition oil pan drain or top extraction).
    Then again, perhaps it's perspective? Terms like "darker" and "clearer" are subjective to a certain extent :)
    Jan 09 2016
    I'm using the same oil extractor. I've never looked at a 10K oil. But after 5000 miles the oil is very dark and smelly...
    2021 BMW 540i
    Apr 30 2010
    San Diego
    Quote Originally Posted by wangshuo1989 View Post
    Same here but really you can't tell anything from the color of oil nowadays. Unless of course you see silver then you might have an issue.
    2011 Audi S4 | 6MT | Ibis/Black Silk Nappa | Nav l B&O | Sport Diff | Carbon Inlays | H&R l Strat Intake l Strat SS l Alu Kreuz l AWE Exhaust l AG M510 20x10 et35 l GIAC Stg II l DTM Lip l Eurocode Diff Mounts l SS Clutch Line
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Quote Originally Posted by Vanimal View Post
    This is me also. I used it in my Stage 3 B5 S4 then in my B7 S4 and now in my B8.5 S4. I am a live and die by Mobil One. I have always used 0w-40 euro formula and never had any issues. I did every 4K in my B5 and then with the increased capacity with the B7 and B8.5 I change every 5-7K but not over 7K. I just check the quality starting at 5K and change accordingly. Unless your tracking the car I don't see the need for all the pricey oil's. Unless there is hard tangible data proving otherwise I am a Mobil One guy
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Blackstone oil analysis done By RedRocket and others have shown that synthetic oils were still protecting at 7500 miles. So at 5k you are throwing away perfectly good oil. 7500 mile oil changes would seem to be reasonable. 10k might actually still be just fine. But I would tend to do it @7.5k unless you have had to add a few qts to top off from oil consumption. The new oil added would extend the oil change interval.
    Jul 17 2010
    996 Turbo
    Batavia, IL
    The color of the oil has zero to do with how much life it has left.
    Nov 16 2016
    Olney, Maryland
    Quote Originally Posted by Dr GP View Post
    Anyone have an oil analysis done at 10,000 miles? I think I will have it done but great if anyone else has.
    Established Member Two Rings Idtrav's Avatar
    Sep 08 2016
    Prince George, BC Canada
    Thanks...been wondering which pump to go with lately. Since installing the ECS street shield i don't ever want to have to go under the car again.
    2014 S4 6MT PBP-TITANIUM-SPORT DIFF-BLACK OPTICS
    H&R COILOVERS/VOSSEN 20X10 CV2/ROCEURO/AWE TOURING/CR-15/ECS BUSHINGS/ECS CF DECK LID/ RS4 GRILL/ECS SKIDPLATE/BFI AlCANTRA/LED KIT/3M
    Aug 05 2016
    San Antonio, TX
    So... I see the big two are the Mobil 1 0W-40 and LiquiMoly 5W-40..... what's the difference between these two? Cons and pros?
    2014 Audi S4 | Glacier White | Sports Diff
    Veteran Member Three Rings Silverbullet S4's Avatar
    Mar 10 2015
    CO - 6,200' +
    This has been posted and discussed. Based on actual analysis, the main takeaway was that changing your oil before 10K miles (if using a quality synthetic) is not needed and those that do it before that are only doing it for peace of mind.
    2013 S4 - APR Stage 2+, DP, CPS v3, BLQ 20s, Solo Werks coilovers, CR-15, EBC Rotors F&R, Deval diffuser, AWE exhaust & USP Intake - TD1 inevitable
    Apr 05 2016
    Portland, OR
    Mobil 1 is cheaper and more easily available. It is very likely you will burn some oil using it.
    LiquiMoly is the german equivalent of Mobil 1. More expensive, a bit harder to find but you do not burn oil.
    Geoff
    Mar 10 2015
    CO - 6,200' +
    Quote Originally Posted by kdn0789 View Post
    I've used both and for some reason my engine drinks the LiquiMoly where as with the Mobile 1, I barely have to add any oil between changes. I won't speculate on which is "better" but, I will be sticking with Mobile 1 for the next several oil changes simply because I stocked up on oil during a sale.
    Mar 10 2015
    CO - 6,200' +
    Quote Originally Posted by whiped View Post
    LOL I've had the exact opposite experience.
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by Silverbullet S4 View Post
    Interesting, You are the only person I've heard of.
    I've only tested LiquiMoly in my car and it does not burn any. Just have heard a lot of people burn with Mobil 1
    Geoff
    Mar 10 2015
    CO - 6,200' +
    Others in the forum have had the same problem with LM. Don't know that it burned but, it went somewhere and wasn't a drain plug leak. Learned that lesson early on and went with the oil extractor...
    Nov 16 2016
    Olney, Maryland
    What brand oil does the Audi dealer put in? Is there one that they all use or does it vary ?
    May 27 2013
    West Chester, PA
    They put in genuine Audi oil, its made of tears from BMW owners.
    Dec 14 2015
    Orange County, CA
    Pretty sure it's Castrol Edge 5w-40. I know it probably means nothing, but the oil cap on my 2016 recommends Castrol oil. The Castrol stuff is not a bad oil per say, but it's additive package is not great either. My brief experience with Mobile 1 being that it's so cheap was that I used it as a factory fill flush. Ran it for about 2,500 miles for another flush to get all the bad stuff out. My last oil analysis already showed numbers lower than the universal averages, but as expected, the Mobil 0w-40 sheared down some.
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Look at your oil filler cap. Mine has the Castrol emblem embossed on it
    Jan 14 2009
    pasadena md
    Quote Originally Posted by Lbsigman View Post
    This is true for me. The dealer did my first change at 5K for the free one and I changed it at 10K with mobil 1. Then then I left the dealer do the 15K and they put Castrol in it again. But as far as "factory oil" I wouldn't read to much into that. The only reason that its factory because the oil because the oil company probably either made the best deal with the car manufacturer or provided them compensation for them to recommend their oil.
    Any oil that has the std required by our cars or better is just as good as castrol. I wouldn't live and die by Castrol or any oil that is stamped or sticked on any oil cap unless it was a specific type of oil. Like if you look at GM's most say Dexos on them. I would live and die by that since thats a specific additive in the oil.
    And when I used mobil 1 for 5K i didn't burn anything. But then again I haven't burnt any oil with my car and it has 15K on it. But i do burn coolant that they can't find.
    Veteran Member Four Rings Seinsmeld13's Avatar
    Mar 23 2009
    2020 Porsche Spyder
    Niagara Region, Canada
    I vote motor oil.
    2018 RS5 2020 SLC 300
    Weekend and summer drive 2020 Porsche Cayman Spyder
    Dec 15 2015
    Denver
    These types of threads are hopeless. You should seriously just search what other threads just like yours have said.
