2011 Audi A4 dead at 290,232 miles, most reliable car I have ever owned. Died of a blown turbocharger 14 days shy of 6 years in operation. I do drive a lot annually.
The only parts replaced other than oil/air filters, oil, brakes, tires, and spark plugs as follows:
17,730 mi HVAC powered vents replaced, covered under warranty.
90,765 mi Replace 1 ignition coil, $216
94,962 mi Replace piston due to oil consumption, covered under extended warranty then by class action settlement.
111,622 mi Replace drivers side front wheel bearing, $712.
117,162 mi Replace 1 ignition coil, $288.
165,807 mi Replace rear struts, $1,252.
175,953 mi Replace breather valve, $199.
265,879 mi Replace passenger side front wheel bearing and 1 ignition coil, $712 for both total.
Nothing else was changed. Original water pump, radiator, battery, front struts, etc. still running till the end. Never changed the transmission fluid. Only changed the radiator fluid once at 94,962.
