Results 1 to 7 of 7
Thread: P0190 code
    Senior Member Two Rings TurboNate's Avatar
    May 15 2015
    El Cajon/CA/San Diego
    P0190 code
    So this code popped up after a routine oil change. It's for the fuel rail pressure sensor. Does anyone know where this is located?
    2009 A4 Premium+ Quattro
    APR Stage 2 | CTS Turbo High Flow Cat | Custom Intake System | AG 19x9.5 m580 w/ 10MM Spacers In Rear | RS Mesh Grill | 5% / 20% tint
    AKA: NathanMansoor
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    From Ross-Tech:
    16574/P0190 - Fuel Rail Pressure Sensor (G247): Circuit Malfunction
    Possible Causes
    Wiring and/or connections faulty
    Short to ground in of near G247
    G247 faulty
    Control Module faulty
    The G247 sensor i believe is on top of the high pressure fuel pump.
    Stage 1 more than you RS3
    Jun 26 2009
    Bremerton WA
    Any signs of running rich, has gas smell to exhaust. Often low fuel rail pressure is due to injector stuck open and the pump cannot keep up. There should be a pressure sensor Midway down the fuel rail and the is built into the fuel pump. Using torque app, I normally have 560 psi at idle. If you cut the engine off but leave ignition on it should stay around this level, I haven't tried this last part.
    May 15 2015
    Quote Originally Posted by van462 View Post
    So the fuel rail sensor is built in to the fuel pump? In other words I'll have to replace the whole pump? A buddy of mine actually sent me this picture but my pump does look like that at all. (The white connector harness is the fuel rail sensor)
    AKA: NathanMansoor
    Jun 26 2009
    Bremerton WA
    Looks like I left out some words. The Fuel pressure regulator is on the pump. The rail sensor is on the rail after the pump. This picture above is of the FSI motor in the B7 I believe. The fuel rail leaves the pump in a hard metal line on the bottom of the intake manifold and the sensor I believe is near cylinder 2...maybe. Its been 2 years since I have had my intake manifold off so not really sure. The regulator sends data to the ECM and the ECM controls it by actuating a solenoid that meters fuel into the pump chamber. The ECU uses data from the fuel rail sensor to "see" if it is satisfing the fuel request. A leaky injector causes more fuel flow than the ECU expects. It generates a fault as its out of acceptable limits. A failing regulator solenoid could also cause this. Troubleshooting would involve looking at fuel trims to see if they are negative numbers (reducing fuel as the O2 sensor "sees" a fuel rich mixture) or positive numbers (ECU adding fuel as O2 sensor reads a lean condition)
    VMR 710's, APR software, Eurocode HFC
    May 15 2015
    Is this the sensor located between cylinders 1 and 2 under the manifold?
    AKA: NathanMansoor
    Jun 26 2009
    Bremerton WA
    That should be it.
