I thought only race-track shops did shaving.
Not sure if the emergency wheel can be kept in rotation to decrease wear.
But if it's 10 years old maybe it should be replaced. Who knows what condition the ~$2 valve stem is in at this point, which can also be replaced on its own if you want.
I've got a few spare ~7/32" 235 Conti DWS.
Continental claims their tire lifetimes to be 5yr, and Michelin 10yr.
Maybe at that point they dry out, among other things, and braking distance (grip) gets worse.
I guess coincidence, I've rarely used grip so far. Only once, I was flowing with traffic straight in my through lane. To the right, was a turn lane, sitting traffic (speed differentials are dangerous, especially for motorcyclists going through parking lots where someone might reverse fast without looking). The car jumped in front without signaling and ABS kicked in (meaning the tire locked up by reaching its limit of grip), maybe a dashcam would help. But my point is, it was close. And a fresh new 18" probably grips better than a stale 10 year old tire.
Can't track McLarens stop at a ridiculous 130mph-0 in 4.5 seconds or something? I doubt it uses the same tires as a Corolla.
Originally Posted by
deyrag
If the 3 remaining ones are so worn as to be outside the tolerance then they are probably almost due to be replaced anyway. Two things never to try to be cheap with is tires and brakes.
I just read someone with a newly-purchased B6 ordered brakes for it, $80 for everything on RockAuto
$100 eBay turbo, and more
vs. ECS Geomet slotted, Zimmerman Coat-Z, Ate PremiumOne, Brembo, Adams
Hawk HPS, Pagid, Akebono, etc.
Gin+
I've been down this road with a mismatched front/rear set on two separate occasions
. Car immediately drives weird with odd steering pull over uneven road especially. I know a lot of people seem to be able to get away with it but for me it just hasn't worked out.
You sure that's not just a defective tire itself?
