I don't have any hard numbers on how pressure is skewed or if it is significant or not but based on general knowledge, oil pressure is different at different parts of the engine. For instance, the mains and rods get oil first typically and the head gets oil last, pressure will drop the farther it has to go. In other words, you need higher pressure after the filter to adequate lube the head than you need to just lube the mains. I also base this on that for oil pressure monitoring, we want to measure this against audi specs for oil pressure. If they measure at the OE switch port, that is where I want to monitor it as well. Pressure to the turbo journals / bearings is kinda useless in the grand scheme of the whole engine.
Here is what my column looks like now:
I don't have a picture of my pressure relocation but it looks the same as what Phil wrote up in the past.
The ideal location for the temp gauge should be right after the cooler. The sump is an alternative and give a very big picture of oil temp but that is the temp after running through the hot engine and sitting in the pan. I am redoing my oil housing setup now to a Setrab front mount cooler and will relocate my temp sender to the return port from the oil thermostat/cooler.
