Results 1 to 8 of 8
    Feb 19 2016
    B5 S4 Avant e60 m5
    Bethlehem pa
    Front fender removal
    How's it going guys. I'm in the process of removing my front fenders to replace them. I got the front bumper off, all the t20 bolts for liner r off and also the t30 for the fenders. I now need to drop part of the side skirt to get at the remaining 2 bolts. I do not want to break anything to drop the front nor have I found any write ups on how to remove this. Anyone have a write up or could let me know how to get at those bolts.... thx guys also the write ups for the front bumper removal were spot on and made that part simple!
    Veteran Member Four Rings LJS's Avatar
    Apr 08 2013
    15 VW GTI S-Very WHITE
    Connecticut
    These may help--
    [IMG][/IMG]
    [IMG][/IMG][IMG]
    [/IMG]
    Aug 24 2014
    Newport Beach, CA
    Here's a video DIY as well.
    2024 M3 Comp xDrive
    Feb 19 2016
    B5 S4 Avant e60 m5
    Bethlehem pa
    Christian thx for the video. I've watched that a couple times but that's an a4 and the lower 2 t30 screws are already exposed I think bc they don't have the side skirt. I was wondering how to take off the side skirt to get to them. I'm gonna go look around when I get home from work. Thx
    Veteran Member Four Rings Euromike's Avatar
    Oct 03 2008
    what garage?
    Pittsburgh
    Quote Originally Posted by blackslc5 View Post
    Remove inner fender well. There is another black plastic peice you need to take out underneath the inner fender liner to get at 2 bolts in the door jamb. There is also another bolt inside the door jamb you get from the inside of the car. There are little black clips that you give a quarter turn and pop out underneath the side skirt. Sounds like you got all the other bolts already (under bumper, under hood)
    01' B5 S4 Pearl White Stage 3+
    01' B5 S4 Laser Red [For Sale - ish.]
    16' Silverado HD
    12' Tornado Red GTI DSG
    99' Laser Red B5 A4 QM SOLD
    98' Santorin Blue B5 A4 QM SOLD
    Feb 19 2016
    B5 S4 Avant e60 m5
    Bethlehem pa
    Thx mike yeah I already had that other black piece out and the bolts from the door jam out. I had to remove the little trim piece from my fender to get to the 2 bolts for the side skirt. then I had to remove 3 nuts under the skirt to get enough drop on the side skirt to get at the bottom 2 t20/30 bolts of the bottom of the fender. Overall it wasn't a bad job. Toughest part was removing that black emissions box to get at the last bolt. Took me about 2-2.5 hrs but I did not put my bumper back on yet. Trying to see if I can source a passenger side fender first so I don't have to take it off twice. Thx for the help guys
    Oct 03 2008
    what garage?
    Pittsburgh
    What color is your car? i actually have a spare perfect passenger side fender sitting around.
    16' Silverado HD
    Feb 19 2016
    B5 S4 Avant e60 m5
    Bethlehem pa
    Silver
