Results 1 to 24 of 24
    Active Member Two Rings flyeyes's Avatar
    Mar 11 2016
    Fenton, MO
    2013 - 2016 Audi S5 V6 3.0T Oil Change Info
    Here is the DIY list for the 2015 S5 (B8.5) V6 3.0T, OIL CHANGE info.
    (3.0L 2995CC 183Cu. In., V6 GAS DOHC Supercharged)
    Years: 2013-2016
    Engine Code: CAKA, CCBA
    HP: 333hp@5500-7000
    Torque: 325*lbf·ft@2900-5300
    Parts List:
    Oil Filter OEM - 06E-115-562-C (FILTEREL - Paper element & 2 Rubber O-Ring gaskets)
    Oil - 0W/40 (AUDI uses CASTROL, my personal preference is Mobil 1 0w-40)
    Oil quantity: 6.6 Quarts
    14mm Crush washer (Audi/VW used copper metallic crush washer)
    Tools List:
    36mm Socket (To remove oil filter cover. Can also use 1 1/2" Standard socket, equal to 36mm socket.)
    6mm Allen Wrench -OR- Allen Socket (To remove oil pan drain plug, if draining oil from under car)
    phillips head screwdriver - (To remove plastic skid plate, 12 phillips screws that are "quarter turn" threaded)
    Additional "helpful" Parts List & Misc Info:
    Oil Dipstick OEM style (AUDI & Aftermarket Part: 06E115611H/06E-115-611H This part is 100% PROPERLY FIT AUDI V6 3.0T, "Supercharged", TFSI Engine
    Audi Engine Code: "CAKA", "CCBA".
    Mann Oil Filter - Part: 06E115562A
    Oil brands - Castrol GTX, Mobil 1, Motul, Liqui Moly, Total Quartz 9K
    Helpful links:
    https://en.wikipedia.org/wiki/Audi_S5
    https://www.google.com/#q=audi+oil+dipstick+06E115611H
    http://www.castrol.com/en_gb/united-...duct-page.html
    *Models covered in this thread Audi S5 2013, 2014, 2015
    **OEM Oil Filter part number 06E-115-562-C was purchased at local St. Louis Audi Dealership. It is manufactured by "MANN" for Audi & VW, and SHARES the MANN Brand Part number 06E115562A.
    "Speed is a disease cured only by poverty" - unknown
    2015 S5 3.0 Supercharged (Daytona Gray)
    2015 A5 2.0T S-Line (silver)
    1992 Acura NSX 3.0L Comptech Supercharged (Berlina Black)...
    1992 Supercharged/Meth Acura NSX
    Established Member Two Rings Twotonicnite's Avatar
    Mar 21 2016
    NW Indiana
    Nice write up, and thank you!
    Twotonicnite
    *2015 S5 Prestige, black optic, manual, GIAC Stage II Tune, Vorsteiner V-FF 104s, Bilstein B16 w/ IRC Ride Control coilovers, Milltek exhaust, 034 rear swaybar, endlinks, differential, & transmission mounts, ECS carbon intake
    *2016 Q5 Premium Plus 3.0T, S-Line, Exclusive Derby Green Pearl
    *2019 A6 Prestige, Mythos Black, Night Vision
    *2008 Toyota Tundra SR5, bone stock
    Junior Member Two Rings
    Jun 28 2016
    Wichita, KS
    As he said. Thanks
    Veteran Member Three Rings wangshuo1989's Avatar
    Jan 09 2016
    I used oil extractor once and love it, I got out 7 qts, which is more than I could get out by draining the oil.
    2013 S5 Misano Red, DSG, B&O, Sport Diff, MMI+, JHM 207mm crank pulley (7PK1370 Contitech belt), APR Stage II Dual Pulley, APR TCU tune, APR CPS, CR15, IE CAI
    2018 XC90 Inscription, B&W sound, Convenience Pkg, Air suspension
    2014 Mercedes E350 rwd
    2021 BMW 540i
    Established Member Two Rings DJT's Avatar
    Apr 23 2016
    Thanks for posting. I buy my own oil (7 quarts) and OEM filter, washer, plug and take it to my dealer for $30 in labor. I went last month and they told me my 2013 S5 takes 7.2 quarts, which was the first time i had heard this...can anyone confirm?
    TIA,
    -DJ
    2019 S5 Cabriolet | Prestige | Quantum Grey Metallic
    TRADED: 2013 S5 Cabriolet | Prestige | Misano Red
    Veteran Member Four Rings xuandatou's Avatar
    Oct 17 2012
    NoCal
    Quote Originally Posted by DJT View Post
    TIA,
    -DJ
    7 QT would be all you need! I've been doing DIY for the past 5 oil changes with the oil extractor
    2013 S5 Build Thread
    2001 S4 Avant
    2017 Ducati Monster 821
    Instagram
    Gone but not forgotten:
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Jun 28 2016
    Wichita, KS
    Got my oem dipstick. Level on MMI says 80% full, yet on the dipstick it only reads about 50% (midway between add and max). This is after I let oil run back down to the pan for about an hour after car shut off. Perhaps minimum level on the MMI is below where the add line is on the dipstick? Just curious.
    Sep 18 2016
    Windsor, CT
    Quote Originally Posted by xuandatou View Post
    Any tricks to get the oil out of the extractor? I'm probably doing something wrong, but it takes me 3x as long to empty the extractor than it does to empty the engine oil pan.
    Oct 17 2012
    NoCal
    Quote Originally Posted by justcallmeblade View Post
    Just open the lid on the top and dump the oil into the recycle... Oil change itself took me about half an hour, while cleaning the extractor would probably took the same amount of time....
    BTW, which kind of extractor are you using?
    2001 S4 Avant
    Instagram
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Sep 18 2016
    Windsor, CT
    Mityvac 7400
    Jan 29 2017
    DE
    You can use the electric pump, dumping used oil directly into any container you wish. Clean. If you are lucky, no drops anywhere.
    Good pumps can be bought on ebay for $18-20.
    Veteran Member Three Rings mikedizzzo's Avatar
    Nov 03 2016
    So Cal
    that dipstick fits 2016 S5 for sure?
    -MikeDizzzo
    2016 S5 Premium Plus | Florett Silver | Black Optic Plus Package | DSG | ADS | Carbon Atlas | B&O
    Mods: GIAC Stage 2 | TCU | SC Pulley | Bilstein B16 Ride Control Coilovers | AWE Touring Exhaust 90mm | Maxton V1 Front Lip | 034 Transmission Insert | Brakes - Hawks Pro with slotted/dimpled rotors | Relak Paddle Shifters | Ceramic Pro 9H | LED interior | 2 x Audizine 5' stickers | Audi All Weather Mats
    Nov 23 2016
    Colorado
    Quote Originally Posted by mikedizzzo View Post
    I bought the dipstick with that part number from Amazon.com for $25. It fits my 2016 S5 perfectly, no modifications required. I just removed the black winged plug on the top right front of the engine and slowly inserted the dipstick to make sure there were no problems with binding or interference. The dipstick seated itself properly in the dipstick tube. I used it to confirm the oil sensor level display. The dipstick showed oil level at MAX, as did the display on the MMI.
    Sep 18 2016
    Windsor, CT
    J.H.C., I always thought that top came off the spout!! Needed a pair of pliers to get it off, like there was a dab of glue holding it in place. Embarrassing!! Glad I asked or I'd keep trying to empty 7 quarts like I was shaking the last bit out of a catsup bottle.
    Mar 21 2016
    NW Indiana
    The new Audi filter came with 2 O-rings, a large one with a tab, and a same diameter but much thinner one. I replaced the larger one in the oil filter housing, but I'm not seeing the thinner one anywhere on the car or the filter housing. Am I missing something?
    Twotonicnite
    Veteran Member Three Rings Brozee's Avatar
    Oct 12 2009
    Oxford, MI
    Quote Originally Posted by Twotonicnite View Post
    No, however sometimes oil filters come with the washer that is needed to be replaced when removing the oil drain plug. This is not the case with this filter, the washer is too small.
    2013 S5
    APR Stg. 2+ Ultracharger, DSG, CPS | Full AWE Touring Exhaust | Roc-Euro Intake | H&R Coilovers | MRR GF6 | 034 Trans + Diff + Subframe Inserts | Apikol Rear Diff Mount | CR-15 | Full Eurocode USS Suspension | DEVAL CF Rear Diffuser | Adams Rotors / Akebono | Stoptech SS Lines | RS5 Grill | Tint | LED Interior, Reverse + Turn | HID Fogs | Escort Max 2
    Sep 18 2016
    Windsor, CT
    been a few months since i changed mine, but i think the thinner one (no tab) is up by the threads on the cap housing. Google images shows it better than i can describe.
    Jul 21 2004
    South Florida
    This is correct.
    I also changed mine via draining last weekend and I was able to get the full 7.2 qts out. I did have to use a 5qt jug and then 3 of the 1qt bottles.
    Mike
    2018 Audi S5
    Gone-
    Mar 11 2016
    Fenton, MO
    Quote Originally Posted by wangshuo1989 View Post
    Can you (or anyone for that matter) post the Manufacturer and Tool part number for the Oil Extractor tool that you used.
    I'll update my posting according to the responses. Feel free to PM or email me.
    Sep 02 2016
    In north America does audi still use Castrol?
    What's equivalent brand to factory oil filter .?
    Sep 02 2016
    Does the oil need to meet any spec ?
    Quote Originally Posted by flyeyes View Post
    Years: 2013-2016
    HP: 333hp@5500-7000
    Parts List:
    Tools List:
    Helpful links:
    Sep 02 2016
    I just did oil change with schwaben extractor . I pulled out just over 6 liters. I filled with 6.4 liters and mmi still forms t show at max. Its 3/4's of the way .... ??
    Sent from my SM-G950W using Audizine mobile app
    Jul 21 2004
    South Florida
    Quote Originally Posted by Wantboost View Post
    Dont keep adding. The mmi wont read instant changes. Check on a warm engine later itll probably read full. Same thing happened to me. Ended up overfilling .5 qt and still read low at first
    Btw, you missed some if thats what you pulled out
    2018 Audi S5
    Gone-
    Sep 02 2016
    Quote Originally Posted by bhvrdr View Post
    Just over 6 litres, Not quarts. And my marker wasnt full before I drained
