1. Tools needed
- T25 Torx
- 8mm, 1/2 inch sockets, ratchet, and an extension
- Pliers
- flat head
- floor jack
2. Location - The pump is located in front of the back tire on the drivers side under a plastic cover.
[IMG]
3. Steps!
- Jack up the car from the rear
- Remove the plastic cover - 2 screws using T25 torx and 1 8mm bolt.
[IMG][/IMG]
- Remove all hoses from the charcoal cansiter/leak detection pump. There are 5 or 6 and 1 wire clip. Most are very easy to remove or unclip. 1 requires pliers, all others can be unclipped or removed by pulling directly off w/care. There is 1 hose that you push in the clip/pull simultaneously the hose (white tip).
- Remove 3 bolts that secure the canister - 1/2 inch socket w/extension.
- The entire canister and pump should come directly out.
[IMG][/IMG]
[IMG][/IMG]
- Putting the new one in is just as easy - Start by securing the pump with the 3 1/2 bolts and then reconnecting all hoses along w/1 wire connection.
