Results 1 to 12 of 12
Thread: S7 Dyno Run
    Mar 29 2014
    Hampshire, UK
    2016 S7 (C7.5 Facelift) Dyno Run
    Hi Guys,
    So I decided to put my 2016 C7.5 S7 onto a rolling road today (4 Feb 2017) to baseline where it is today in the event that I go for a tune.
    There is no ECU or TCU tune on the car currently.
    I have a Roc-Euro air intake fitted, and have a modified exhaust: Front Resonators deleted and replaced with straight pipes, centre box (suitcase) deleted and replaced with an X-Pipe. The rear mufflers have been replaced by Powerflow boxes.
    The car has 18k miles on it, and it was using regular unleaded petrol. It was a cold day - around 8degC. Rolling Road was a Dyno Dynamics.
    The stock Audi power figure for the C7.5 is 450BHP, so Im not sure if my 433.1BHP @ the flywheel is good, average or bad. I didn't test it before putting the RocE and exhaust mods on, so don't have a before and after figure.
    Feel free to comment
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Jul 21 2004
    South Florida
    At the flywheel means engine hp. Your dyno is at wheels (tires actually). I realize you don't have a Baseline but generally a Dyno Dynamics reads pretty low compared to many others. I'd be pretty pleased with those results. Mike
    2018 Audi S5
    Gone-
    Mar 29 2014
    Hampshire, UK
    Quote Originally Posted by bhvrdr View Post
    Hi Mike,
    I thought the fFtLb was indicating @ flywheel on the right hand side?
    I actually forgot to ask him
    Jul 21 2004
    South Florida
    edited: i see what you are saying. shouldnt be flywheel unless he used a correction.
    edited again: I see he used "shootout mode" You're absolutely right he used a correction to try and estimate chp.
    Honestly I wouldnt sweat the results then. They are in the ballpark of what the car should be making and who knows how accurate the correction is. I'd just spend 20 on a 1/4 mile day and check your trap speeds. If they are what they should be... thats that.
    mike
    2018 Audi S5
    Gone-
    Sep 19 2014
    Newcastle
    This is crank correct? Shame he didn't do WHP but torque is V healthy. If it's crank then depedns what correction factor and DTL it added. Mine on a dyno dynamics made 373whp
    Sent from my XT1580 using Tapatalk
    Audi S6 C7.5 Avant 2016 Sepang Blue APR Stage 2, Custom Downpipes, Revo RS Intake, X-Pipe & Resonator Delete - 441WHP 528WTQ 551BHP 660 LB FT.
    Jan 22 2017
    New York
    Graph curve looks smooth and healthy up top, with a little overboost and correction down low. That's all you are going to be able to tell from this, being that it's your first dyno (at this particular facility). However, now you have a true baseline to compare future modifications against. Congrats!
    Follow bhvrdr's advise and get her out to the drags...
    Sep 19 2014
    Newcastle
    Quote Originally Posted by RAF_S7 View Post
    Hi Mike,
    We should meet at Santapod or something this year. Have a friendly run against each other and I'll let you have a go in mine
    Mar 29 2014
    Hampshire, UK
    Quote Originally Posted by pez81 View Post
    That could be fun
    Jan 09 2013
    UK
    John, SRR traditionally runs a little low, exacerbated by it being cold so because it is a wheel dyno and not a hub dyno your tyres wont have been at their best. Also 95 RON? Shame in you, that'll be where a large part of your losses are.
    Shoot 44 was originally designed for 4WD 4cyl cars (scoobies and evos) which have a diffferent power delivery, I'm always amazed Dyno Dynamics have never brought out an upgraded mode for AWD V8's.
    Wouldn't read too much into it, if you had another stock S7 there on same fuel which did more then be worried but one reading on a dyno one day means nothing if comparing to the same or another dyno on another day.
    Mar 29 2014
    Hampshire, UK
    Quote Originally Posted by P_G View Post
    Thanks for the feedback. Would running super unleaded make the car feel and run differently?
    Maybe my next tank full will be 98
    Sep 19 2014
    Newcastle
    Yes definitely. I run nothing but 99. I think dyno dynamics have upgraded their software if I'm not mistaken.
    Jan 09 2013
    UK
    I always run on either Shell V Power or Tesco Momentum, more of the latter with the odd tank of the former. Whilst it is more expensive (V power 7% more expensive that their unleaded; Momentum 4% than their 95 RON) I on average see 8-10% better fuel economy on them which offsets that increased cost plus you get better power and initial throttle pick up. I also throw in a bottle of Wynns injector & fuel system cleaner (in Halfords) every 3k miles just to keep things tip top.
