I've been chasing a idle misfire on #4 for a few years and basically have checked everything possible except for a running compression test only due to having the fueling off the car and not wanting to reinstall it to test. At first it was not so bad with stockturbos/fueling/tune and adding load would make it stop like turning on the AC, etc. Last summer I added turbos/298 injectors/tune, etc and the problem was still on #4 but seems just a bit worse which I attribute to the new larger injectors. The car runs great under load and makes good power and no misfires at 23-25psi while we were tuning on pump gas. After more and more tuning pulls the problem was getting worse than in the past so I decided to dig in one more time as I will be pushing the stock block to the limits on e85 later on.
I have checked all the wiring for the coils/ignitors and have spares to try as well. I checked for pressure leaks up to 25 psi, etc. I Flow tested the new injectors and they are perfect, so no issues or leaks with any of those parts. Compression test is 157, 153, 154, 140, 149, 148 cold in order so you can see #4 is down a bit. Leakdown was 4-6% cold for most, but #4 still showed the most at ~8-9% and most of the air is past the exhaust valve/s vs any of the other cylinders, but again not that bad. LTFT's are also richer by 5-7% on the drivers side so that aligns with the lower compression IMHO. Cam lobes look great for 150k miles and the springs all feel the same when pressing down on the exhaust valves on the drivers side. I was sort of hoping it would be a broken spring or worn cam, but it appears to be a slightly burnt valve/s on #4 or a pumped up lifter holding the valve/s open slightly, but I guess it's so mild that the compression is decent. I'd hate to pull the head and not find an issue, but at this point it almost has to be either one or both valves on #4 or a bad lifter not adjusting correctly and holding the valve off the seat a tiny bit.
I have had the car since 2002 so quite some time and maintain it well. The engine was re-built at the dealer due to water pump failure at 30k back in 2002 also. I attribute this issue somewhat to poor machining on the head by the dealer or some other fluke, but it's hard to say since all the other cylinders seems to be ok and not have a misfire issue. I've probably diagnosed this thing to death and just need to pull the head, but I'm kicking myself for not doing it when I had it out for the turbos. At this point I'm also tempted to swap the rods out also, but then it's pulling it out again. I just wish the problem showed up more pronounced in lower compression or higher leakdown test numbers. Anyone else fought one like this? Burnt valves don't seem very common on this platform so that is why I ask for more examples.
Ed
