Results 1 to 9 of 9
    Senior Member Two Rings mjames's Avatar
    Dec 21 2012
    2019 Audi Q7
    Lake Wylie, SC
    Fixing broken sun visor clip/hook
    So I broke the little clip/hook on the passenger side sun visor (on the left side of it) where it attaches to the headliner. Doh.
    I called my dealer and it seems like I've ordered the correct OEM part, part # 8W0857562A4PK. This is what I got: https://www.ecstuning.com/b-genuine-...KQ4aAsSY8P8HAQ
    It arrived and I can't figure out how to install it. Parts guy at dealer said he didn't think I'd have to remove the headliner to install it.
    Does anyone have any suggestions? The part that broke on mine is the hook.
    Edit: Found this thread in the A4 forum, but no explanation of how to DIY install: http://www.audizine.com/forum/showth...e-Part-amp-DIY
    Veteran Member Four Rings DBFL's Avatar
    Jan 01 2016
    2016 S4, 2018 Ford F-150, 2022 Audi SQ5, 1982 Audi Coupe
    Tampa Bay
    The clip is two pieces. There is a cover that you can pull off - use a small flat-head screwdriver if necessary. Then the part with the hook can be removed. No need to remove the headliner. In fact, you have to remove the sun visor hooks if you are going to remove the headliner.
    2016 S4 P+ | 6MT | Sports Diff. | Tech. Package
    S4 Build Thread
    Established Member Two Rings nevets77's Avatar
    Sep 20 2016
    Ducati Panigale V2
    Framingham MA
    I was having trouble with this repair for 10 minutes, not being able to remove the first outer cover. The trick for me was only pulling/prying under the very edge of the cover. When I inserted the screwdriver too far under the cover I was pulling on both pieces of the assembly , I thought I might break it if I used more force. Once I discovered to only pry the first 1mm edge it came apart very easily.
    2014 S4 Moonlight Blue - 6MT sport diff - Black Optic - B&O l Alcantara - APR Stage 2 & Pulley - Eurocode F&R sway bars and Endlinks
    Alu Kreuz - 034 motorsport trans insert - Luft-Technik Intake - CR-15 - JHM Short Shifter - BFI - RS Grill - Bilstein PSS10 -Llmar 35%- stop tech brakes
    2013 Allroad-RIP
    2007 A4 -SOLD
    2001 A4 -SOLD
    1997 Thunderbird SC
    1972 Datsun Z Scarab
    Active Member One Ring BABurgman's Avatar
    Jun 14 2016
    2017 GTI Sport
    New Mexico
    Wife broke mine. The outer cover contain plastic pins that lock the latch to the car. Once the outer cover is off the latch can be installed and removed easily.
    2013 S4 Prestige / 6 Speed / Red / Black-Chestnut Brown / VMR V810 19x8.5 ET35 / Michelin PSS 255/35-19
    Established Member Two Rings dean.mohr's Avatar
    May 11 2015
    '01 F150
    Toledo, Ohio
    Sounds like they beat me to it! This takes all over 3 minutes to replace. I'd avoid using anything hard like a screw driver, but it will do the job.
    Get just under the edge of the clip. The outer portion will come off and the inner portion (that actually fastens into the body) will be loose. The outer portion actually holds the two pieces into the holes in the roof.
    Remove the inner portion, install new one, then install new outer portion. Make sure you fully click it into place or it will just fall out.
    2012 S4 Prestige // Ice Silver Metallic w/Lunar Silver Interior // 6MT // Titanium Package // Chipwerke Pro // CTS Turbo Intake // AWE Track Exhaust (105k)
    2001 Ford F-150...with 265k and counting!
    I'll Always Remember You: 2013 Ford Fusion Titanium
    Veteran Member Three Rings MonSoonHell's Avatar
    Mar 17 2012
    2023 RS5 Sportback, 2018 Ford Explorer Sport, Lincoln LSC - Heavily Modded
    Long Island, NY
    I just replaced my driver's side clip. Took less than a minute. The above posts are correct. Once you take the old clip out you will see how it all works. Pretty cool design.
    2012 Monsoon Grey S4, Prestige, Sport Diff, 6 spd w/Meisterwerk ASTS, RocEuro Intake, STaSIS, KW V.3 Coilover system, AMS Alpha Intercooler, P3Cars Gauge, VAG-COM modded, RS4 Grill, Alu Kreuz, CR-15 Bar, 034Motorsports Suspension Components, Adams Rotors/Ceramic Pads, SS Brake/Clutch Cables, Eurocode Stage 3 Clutch, Summer-Niche Citrine H79 19x10s (275/30/19), Winter-CCW SP20 19x10s (275/35/19)
    "Relief has differences, I would rather shit in a toilet than in my pants"
    Mar 05 2015
    2009 A4 Cab: S-Line / 1996 Camaro Z28
    East Granby CT
    I'm guessing this is a good example of how it works: (Doesn't specifically say year - but seems like the correct method)
    https://www.youtube.com/watch?v=bMgYdXD6kSM
    Or here is another: (Looks similar - but shows use of Interior Tools vs Pick)
    https://www.youtube.com/watch?v=0sZY8Qw5-dI
    2012 Moonlight Blue Metallic S4 | Premium + | DSG | 19" Peelers |Sports Diff | MMI w/Nav | B&O Audio | Advanced Key |
    After-Market Add-Ons: Rallitek Aluminum Paddles | USP LED Interior Lighting | Phillips Xtreme +50% Headlight Bulbs
    Performance Upgrades: 034 Stage 1 ECU & TCU | | APR I/C |
    Stoptech Cryo Slotted Rotors with Porterfield R4-S Pads |
    034 Springs / Koni Yellow shocks | Tires = Michelin Pilot 4S (255/35/19)
    Veteran Member Three Rings blackjak's Avatar
    May 21 2008
    11 Phantom S4
    St. Louis, MO
    Thanks for saving me the time and effort of making this post lol and finding the part. My passenger side one has been broken for awhile and it annoys the hell out of me. Ordering. :)
    Mar 05 2015
    East Granby CT
    Shortly after I bought my car the passenger side broke - dealer replaced for free.... fast forward to 2020 - driver side broke....
    I just went with this part from Amazon: (late night search with next day delivery made it worth a try):
    RunMade Audi Visor Clip from Amazon
    2 Secs to pry off outer cover and then pull down clip easily - new one went in with zero issues.
    New one is close in color (not OEM Part - so close enough) - and seems to hold visor nicely - we'll see how this one lasts.
