Results 1 to 23 of 23
    Oct 29 2016
    CA
    Oil change question? B8.5 s5
    Hey guys, just wondering what motor oil I should be using? Was thinking to get castro gtx full synthetic. What numbers should I be using? Also how many qts does our cars take? Thanks in advance.
    Junior Member Two Rings JacksonA3S5's Avatar
    Dec 06 2016
    2009 S5 4.2 V8. 1978 Porsche 911 SC air cooled. 2010 Audi A3 2.0T
    Lake Tahoe Ca
    best oil you can get is Liqui Molly synthetic SAE 5W-30 or 40 depending on how cold it gets where you live. (40 for colder places, 30 for warmer places) regardless I'd run 30 in the summer
    Sent from my SAMSUNG-SM-G890A using Audizine mobile app
    Oct 29 2016
    CA
    Live in California, should go with the 5w30 I guess. Castro gtx full synthetic any good?
    Jan 12 2011
    2016 Q5, 2018 S90
    I use Motul specific and I haven't had any issues.
    Oct 29 2016
    CA
    Hmm.. so a 5w30castro gtx do it's job? And also how many qts does our cars eat?
    Dec 06 2016
    Lake Tahoe Ca
    Castrol is good, but it's American made, so not the best for euro cars, I have an oil change regulator which tells me the exact mileage that a new oil change is needed on, I got 3k more mileage off of the oil from the Liqui Molly than the next closest.
    Veteran Member Three Rings ip428's Avatar
    Jan 01 2015
    B8.5 S4 6MT, B8/.5 A5 6MT, 996 C2 6MT
    ATL
    Motul or Liqui Moly
    B8.5 S4 6MT - KW V3/JHM/Magnaflow, etc etc
    B8 A5 6MT, SR66 Widebody, Unitronic Stg II+, HPA K04, Etc etc - SOLD
    IG: @infamous_m0
    ACNA Member
    Oct 29 2016
    CA
    Ill probably get motul, so motul 5w30? Also how many quarts do I need?
    Veteran Member Three Rings plat's Avatar
    Dec 19 2015
    GVRD, BC Canada
    Quote Originally Posted by Westea View Post
    Any oil that meets or exceeds VW 504/507 standard is recommended. Castol is the recommended factory brand. You cannot go wrong with it. Just make sure is meets the VW/Audi standard. Here's the Audi Technical Bulletin Audi/VW Oil Standards and approved oils.
    Current: 2016 S5 in Sepang Blue with Technik Package.
    Established Member Two Rings Drew0u812's Avatar
    Apr 02 2014
    1998 3000gt VR4
    Poplar Grove, IL
    Quote Originally Posted by JacksonA3S5 View Post
    You have that backwards.
    Sent from my XT1585 using Tapatalk
    2018 Audi A5 Sportback Prestige
    Dec 06 2016
    Lake Tahoe Ca
    right sorry, thicker in warmer thinner in colder... my bad
    Veteran Member Three Rings wangshuo1989's Avatar
    Jan 09 2016
    As long as it's certified by VW 502 00, I used mobil 1 0w40 and never had a problem.
    2013 S5 Misano Red, DSG, B&O, Sport Diff, MMI+, JHM 207mm crank pulley (7PK1370 Contitech belt), APR Stage II Dual Pulley, APR TCU tune, APR CPS, CR15, IE CAI
    2018 XC90 Inscription, B&W sound, Convenience Pkg, Air suspension
    2014 Mercedes E350 rwd
    2021 BMW 540i
    Oct 29 2016
    CA
    Hnm so thicker in warmer, so 5w40?
    Jul 21 2004
    South Florida
    If you are going with US Spec oils you're almost guaranteed to need a 0w40 or 5w40 as the 30 weight oils in US formulations are few that meet VW502.
    There is no evidence your engine will last longer by purchasing a 9 dollar per quart vw502 oil versus a 4 dollar per quart vw502
    oil.
    Here...
    https://www.amazon.com/Mobil-120760-.../dp/B00HG76A9A
    Walmart also has deals...
    https://www.walmart.com/ip/23636902?...&wl13=&veh=sem
    https://www.walmart.com/ip/Castrol-E...FpNfqIeGY1g4hQ
    2018 Audi S5
    Gone-
    Oct 29 2016
    CA
    Quote Originally Posted by bhvrdr View Post
    There is no evidence you're engine will last longer by purchasing a 9 dollar per quart vw502 oil versus a 4 dollar per quart vw502
    oil.
    Here...
    thanks man, gunna get a 5w40 castro gtx
    Veteran Member Four Rings ak_siberian's Avatar
    Jan 30 2015
    992C4S, T2 Touareg V8, Porsche Macan S, & Gehl turbo bobcat;
    20 miles NW Fairbanks, Alaska
    I use Mobil1 0-40w year round on all my vehicles (Touaregs and RS5). I don't scrimp in summer.
    Oil changes are twice a year irrespective of mileage due to huge temp variations and condensation in the crankcase. Spring and Fall I order 26 quarts (6.5 gals.) for the three vehicles from Wallyworld.
    Oil is drained the old fashioned way via the drain plug and not sucked out. Plug is checked for metal filings or other crap.
    siberian
    The best long distance runners eat raw meat, run naked and sleep in the snow
    Oct 29 2016
    CA
    Came to a conclusion to get the 0-40 castrol edge, was one of the oils that was on the list.
    Apr 02 2014
    1998 3000gt VR4
    Poplar Grove, IL
    Amsoil is very good oil also, they have a 0w40 European car formula that meets the 502.00 specifications.
    Senior Member Two Rings Tomieg's Avatar
    Aug 20 2016
    Great oil. I've been using the European formula in mine.
    Veteran Member Three Rings ColtS5's Avatar
    Aug 18 2013
    2022 Kia Telluride, 2024 Jeep Grand Cherokee, 2018 Porsche Cayman S
    Indianapolis
    Quote Originally Posted by wangshuo1989 View Post
    Huge 2nd. Long time user of 0W40 M1, and I've never had any issues. With my '09 S5, I never had carbon issues, all the way to 73K when I sold it for my '15.
    Junior Member Two Rings tuna79's Avatar
    Mar 04 2016
    S5, C5 Allroad, cooper se
    Brevard, FL
    As long as we're comparing oils I've been using Rotella T6 with zero complaints.
    Senior Member Four Rings
    May 20 2015
    Audi S5 Deep Sea Blue Pearl
    PA
    I've always been a Mobil 1 synthetic guy in all my performance & V8 cars. I've used their Euro formula 0w40 in all my German cars. I currently use it in my B8 S5 with zero problems, in fact I don't even burn any oil with 88k on the dial, amazing being it's a 4.2 V8. I may need to add the "tiniest" bit when I get close to the 5k change mark but only sometimes. That's just because I'm OCD and like the dip stick to always be at the same level.
    I also ran it in my 2001 B5 S4 I used as a spare car 2 years ago. Which when I sold it had 210k on ORIGINAL K03 turbos to my knowledge. Let that sink in! Car was mint for the mileage, wish I just kept it, made a great grocery getter.
    It's 502 spec Audi or whatever. And you can always get a 5 gallon jug on sale at Walmart for like $24. Helpful since the B8 S5 takes like 9.5 quarts! Helps in PA as well when it gets in the single digits temp wise.
    Established Member Two Rings jpatterson's Avatar
    Mar 16 2009
    Trussville, AL
    Quote Originally Posted by Vanimal View Post
    Same here---- Mobil 1 0/40 European Formula. I get it from Wal Mart too. It's a 5 QUART bottle though 😉.
    My old Mk 1 TT has 150000 miles on it with this oil and burns zero between changes. I replaced the valve cover gasket last year and it is as clean and sludge free inside as a new engine.
    J. Patterson
    Alabama
    2015 S5 Prestige 6 spd manual
    2015 Q7 TDI Premium Plus (with the emissions fix)
    2001 TT 225 Quattro Coupe (some mods and track time :-) )
    2001 TT 225 Quattro Roadster ( pure stock)
