Results 1 to 6 of 6
Thread: Code P0240
    Junior Member One Ring
    Aug 07 2013
    Northern New Jersey
    Code P0240
    As I was driving to work today, CEL came on. Pulled code P0240. Car is a 2010 with 63k miles. Ran a quick search but couldn't find anything on the b8s using the mobile app. I'll do some more research tonight. Till then I'm leaning towards either 02 sensor or cat? Any feedback would be greatly appreciated
    Sent from my ZTE A2017U using Audizine mobile app
    Veteran Member Three Rings bluefox280's Avatar
    Jul 03 2005
    Broomfield, CO
    Can you confirm the fault code number?
    P0240 doesn't come up as a valid fault code for VW / Audi.
    - Erik
    PatternDraftImaging.com - "...Where Engineering Discipline and Photography Merge as One..."
    Nov 28 2015
    Flemington, NJ
    It's probably a p0420 code meaning cat efficiently below threshold. Could be bad o2 sensor or bad cat. Any mods done to the car?
    Current:
    2015 (B8.5) Q5 3.0t Premium Plus
    2013 (B8.5) A4 - 2001 (B5) A4 - 2004 (B6) S4 - 2001 (B5) S4 - 2007 (B7) A4 - 2001 (B5) A4
    Aug 07 2013
    Northern New Jersey
    My apologies, code is P0420. Took a closer look. Seems that one of my fuel injectors is leaking. I'm thinking that it was sending unburned fuel into the cylinder and down the system, and eventually burned the cat. Does that sound possible?
    Jul 03 2005
    Broomfield, CO
    Quote Originally Posted by Sotiris View Post
    If the injector was leaking into the cylinder at all times (versus leaking on the outside of the engine), it is possible.
    A emissions "sniffer" test would confirm to check for high NOx if the catalyst has failed.
    - Erik
    Aug 07 2013
    Northern New Jersey
    Quote Originally Posted by bluefox280 View Post
    - Erik
    Thanks for your feedback Erik. Much appreciated. Monday I'll find a local shop to run the emissions test and check the levels.
