Results 1 to 15 of 15
    Veteran Member Three Rings Teamnct4's Avatar
    Aug 06 2010
    2015 S4 & 2022 S4
    NY & SC
    Sirius radio stuck on "LINKING", No sound coming through.
    Hello all, I am having a problem where my sirius radio just says "LINKING" and will not play any music. Once in a while it will play for a few seconds, then immediately cut out and go back to "LINKING", has anyone had this issue before? I'm guessing it might be the antenna or the module itself. Thanks in advance.
    2015 S4 Premium Plus, Mythos Black, Black/Magma Red Interior, Black optics package, Aluminum Mirror Caps, Carbon Atlas Inlays, Airlift 3P, Airlift performance front and rear shocks, AWE touring with 102MM Tips, E-Codes, 20X9 HRE FF01.
    2020 RS3
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    Couple of things you could try:
    1. Refreshing the unit as described here on the Sirius website.
    2. Try resetting the cable connections on the unit in the trunk. That's mentioned in this thread as a possible solution. It's the lower unit with the green and white connectors.
    Let us know what you find out the problem is!
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Aug 12 2013
    Lexington KY
    I'd try the three finger solute for MMI. It's the hard reset option for the radio/MMI. You'll need to look it up, but depending on what year your car is, you'll hold, 'menu', the top right action key and the main button all at the same time and it will turn off/on your MMI, resetting it.
    That's what I'd try first actually before unplugging replugging a bunch of wire harnesses in the back of the car.
    Make sure you have a clear line of site to the sky as well. Don't try and do it in an underground parking garage or anything like that.
    O
    Aug 06 2010
    2015 S4 & 2022 S4
    NY & SC
    Thanks for all of the replies. I tried everything mentioned and it still says "LINKING". It will cut in and out every once in a while, then stay on LINKING for a while. I called SiriusXM and they didn't really help me at all. They were trying to get my to buy a subscription. Why would I buy a subscription if the radio isn't even working. I may have to go to the dealer.
    2020 RS3
    Senior Member Three Rings MS203's Avatar
    Apr 09 2011
    '15 S4
    Newport Beach, California
    Quote Originally Posted by Teamnct4 View Post
    If you have already tried everything I would just take it into the dealer at this point. Super annoying but I had to do this for mine last summer. You probably have the same issue that I faced. I was in your shoes and tried everything under the sun to fix this problem.
    I took it into Audi and it turns out the receiver/shark fin connection was bad. That's what is wrong with yours too I'd bet, since everything else has been ruled out. IIRC it is a pretty labor intensive job but it was all under warranty and they replaced a few wires and the antennae itself.
    –Matt
    2015 S4: Brilliant Black, hardwired V1, Roc Euro intake, H&R Street Coilovers, CR-15, SPC Adjustable Upper Control Arms, 034 Rear Sway Bar w/ Moog Endlinks, 034 Rear Subframe Mount Inserts, AG M510's 19x9.5 on Michelin PS4S (255/35/19), AWE Track w/ 102mm diamond black tips, Chipwerke Pro-S.
    Aug 06 2010
    2015 S4 & 2022 S4
    NY & SC
    Quote Originally Posted by MS203 View Post
    Did you have to leave your car for a few days or were they able to fix it same day?
    2020 RS3
    Jan 16 2007
    I don't think it's the car, I had the same exact problem yesterday. Started on my morning commute and happened on the way home as well. 16 Allroad
    Mar 18 2015
    San Diego, CA
    I have a 15 S4 and it was working fine.
    It started doing the exact same thing about 1 week ago.
    When I look at timing the following have happened before that timeframe:
    1 I had the ECU recall done right before this started
    2 I'm in San Diego and we have had a lot of rain in the past couple of weeks. I was wondering if water got into the antenna?
    Aug 06 2010
    2015 S4 & 2022 S4
    NY & SC
    We had a lot of rain here in NY also. I made an appointment with the dealer, hopefully it's an easy fix. It's only the Sirius that doesn't work, AM, FM and the CD player work fine. Sirius has been permanently stuck on "LINKING" now for a few days.
    2020 RS3
    Active Member Two Rings Bmil128's Avatar
    Jun 26 2014
    Mine did it last week one day as well and then stopped, I think it was a signal issue
    Bmil128
    2014 Glacier White PP+ S4
    BBS LMs
    APR Stage 1
    ECS Intake
    APR Supercharger Cooler
    034 Motorsport Rear Sway Bar
    H&R Front Sway Bar
    Eurocode Alu Kreuz
    CR-15 Strut Brace
    Mar 05 2015
    2009 A4 Cab: S-Line / 1996 Camaro Z28
    East Granby CT
    Quote Originally Posted by Bmil128 View Post
    Yeah - I'm closer to NY than TX (CT) - and no issues with my Sirius at all recently - so could be a signal issue - but more likely a hardware issue.....
    FYI - I have Sirius in multiple vehicles without any issues as well....
    EDIT: Good plan to have it checked out by dealer....
    2012 Moonlight Blue Metallic S4 | Premium + | DSG | 19" Peelers |Sports Diff | MMI w/Nav | B&O Audio | Advanced Key |
    After-Market Add-Ons: Rallitek Aluminum Paddles | USP LED Interior Lighting | Phillips Xtreme +50% Headlight Bulbs
    Performance Upgrades: 034 Stage 1 ECU & TCU | | APR I/C |
    Stoptech Cryo Slotted Rotors with Porterfield R4-S Pads |
    034 Springs / Koni Yellow shocks | Tires = Michelin Pilot 4S (255/35/19)
    Apr 09 2011
    '15 S4
    They fixed it in one day. But IIRC it was a morning drop-off and a 6PM pick-up
    –Matt
    Jan 16 2007
    Resolved itself after a week. Last Wednesday I had zero reception and decided to make an appointment to have it looked at. Magically, the next morning it started to work again and had been solid ever since.
    Aug 06 2010
    2015 S4 & 2022 S4
    NY & SC
    Quote Originally Posted by jtdbsr View Post
    Mine also, but then went out again for a day, now its back again. I've reset it a few times, unplugged everything twice and had sirius re-send the signal 3 times. I have an appointment for next week. If it keeps working, i'll cancel it.
    2020 RS3
    Aug 21 2014
    Boston
    Had this happen to me, dealer wound up replacing the entire roof antenna
    2015 Ibis White S4 DSG
