Results 1 to 40 of 62
    Established Member Two Rings Probmxstyle's Avatar
    Dec 19 2015
    Powered Sub w/ B&O System
    I've been thinking about installing a powered sub in the storage area behind the spare tire. Does anyone have experience running the leads going to the stock amp to a powered sub? Is the signal filtered by the amp or by the headunit?
    This is the sub I've been thinking about installing:
    https://www.crutchfield.com/S-KQ92Wc...ne-PWE-S8.html
    Deactivated Two Rings
    May 08 2016
    Northern VA
    Are you looking to install an additional subwoofer to the factory sub, or replace the existing sub?
    I'm working in a fiberglass box that will mount to the passenger side tail light access cubby. I've also considered the spare tire area but I do enjoy the extra storage space for "crap".
    I've tested a simple unit by tapping the leads from the factory amp to the factory sub and the performance is great. Will have bass control up in the cockpit area and still retain minor bass control within the MMI system.
    Also Alpine makes great drivers however I've always used JL products. I've done plenty of sub installs and JL has yet to fail me or the vehicle owner. I've had a handful of Alpine amps sh*t the bed.
    Check out JL's drivers and compare with the Alpine you have selected. Either would be a great choice.
    http://www.jlaudio.com/car-audio-subwoofer-drivers
    Veteran Member Three Rings cmoore86's Avatar
    Nov 11 2014
    2018 SQ5
    San Jose, CA
    I put this in mine a while back. Super easy install and sounds great. A more integrated sub box like above is probably better as I had to lose my spare tire. I don't care about that as I can't really use it with the wheels I run anyway. From what I remember that Alpine unit should fit and you can keep the spare.
    2018 Audi [] SQ5: Navarra Blue | BBS | AWE | 034 |
    Sold - 2015 Audi RS5: Sepang Blue My Sepang Blue RS5
    Sold - 2015 Audi SQ5: Sepang Blue cmoore86 2015 SQ5
    Dec 19 2015
    Quote Originally Posted by connoisseurr View Post
    My plan is to unhook the factory sub and run the audio leads to a power subwoofer. I really wanted to get a powered JL setup, but they don't seem to have a unit small enough to fit in the storage area while keeping the spare tire.
    Dec 19 2015
    Quote Originally Posted by cmoore86 View Post
    That is my train of thought as well. You put yours exactly where I want to place mine, but I would like to retain my spare tire.
    Veteran Member Four Rings freesole's Avatar
    Oct 30 2011
    Looks great! Do you have more info on your install? I would like to read more about it in case I do make that upgrade in the future
    Current
    '22 RS6
    '22 X3M Comp
    Gone
    '19 SQ5
    '18 S5 Sportback /// Build Thread
    '16 Q5 3.0 /// Build Thread
    Insta: @frees5ole
    Nov 11 2014
    2018 SQ5
    San Jose, CA
    Quote Originally Posted by Probmxstyle View Post
    That Alpine should fit. I only need about 1" to get mine to fit with the spare. But install is really easy. Just tap the OEM sub speaker wires for the sound like you said. Then I used the power socket on the passenger side of the trunk for remote turn on as I didn't want to rely on the auto turn on from the amp.
    Nov 11 2014
    2018 SQ5
    San Jose, CA
    Quote Originally Posted by freesole View Post
    Thanks! Need to tidy up the wiring still. What info do you need? It's super easy with the battery back there. That's a powered sub I put in (10" w/400 watts @.25 ohms). Used the OEM sub speakers wire for sound, positive from the battery, ground from right below the trunk latch in the middle. Then I tapped the positive wire from the power outlet in the trunk for remote turn on. I actually found a way to keep the spare tire back there but I needed to remove the handle to pull the cover up as the bottom of the handle was hitting the grill of the speaker.
    Dec 19 2015
    If that is the powered 10" model, do you think the powered 8" box would fit with the spare?
    http://www.jlaudio.com/acp108lg-w3v3...-systems-93330
    Nov 11 2014
    2018 SQ5
    San Jose, CA
    I think so. I don't remember seeing the 8" model when I got mine but then again I was aiming for the 12" at first. The dims look good on the 8" but what I had to do was wedge the box in with the spare. They were completely pushing against each other. But it worked except for the cover closing. So my concern would still be that possibly the same problem might happen. I think you should good though.
    Mar 07 2004
    2025 Q7, 2018 TTRS, 2022 Q5
    Charleston, W.V.
    Someone did a DIY on swapping out the OEM subwoofer with an aftermarket one. They used the OEM box and had to cut it a little bit, but they said it worked well.
    http://www.audizine.com/forum/showth...work-required)
    Feb 15 2007
    Quote Originally Posted by BarryT82 View Post
    This was not B&O system though
    2007 Audi RS4 - Daytona Grey - Original Owner
    1957 MG MGA 1800 - Austin Healey Spruce Green
    2020 Mercedes-Benz GLC 63 AMG - designo Cardinal Red
    2024 Tesla Model 3 Dual Motor - Stealth Grey
    Veteran Member Four Rings jomama229's Avatar
    Jun 07 2013
    orange county, ca
    wow!
    just did a quick search on this pic from post #5 by spijun and found it's source to be from this thread on AW: http://www.audiworld.com/forums/q5-s...2845644/page2/
    that looks like a nice install - reading up on it now.
    2014 Q5 3.0T Glacier White Metallic - 034 Stage 2 / TCU - Bilstein B8/H&R
    Sep 12 2016
    Natick/MA
    Awesome ... dude can u give me details on this I want the exact setup ..... please
    Feb 25 2014
    Arkansas
    Use JL TW5 thin woofers under there and you won't be disappointed.
    Sent from
    Established Member Two Rings Choiboy's Avatar
    Dec 27 2016
    Jersey City NJ
    Is there anyway to turn up the volume or level of the base B and O subwoofer in the trunk? I hate the bass is so low even when i crank up the bass on the stereo.
    Sep 12 2016
    Natick/MA
    Quote Originally Posted by Spacemonkey View Post
    Sent from
    Ok am kinda a noob at this sound stuff ... so please pardon the dumbness ... it's not intended.
    1) do I need a new amp
    2) what cables will be needed
    3) can I fit this in the original sub box or should I get a new box for it
    4) can u point me to a setup guide for this if possible please
    May 08 2016
    Northern VA
    Quote Originally Posted by TITAN_Q5 View Post
    1) I would 100% use a dedicated mono amp for any subwoofer installation.
    2) You will need an amplifier power kit (contains positive and negative leads, remote turn on wire, and RCA cables)
    3) the JL TW5 is a 13" subwoofer driver and will require some sort of new enclosure. Factory enclosure cannot be retained.
    4) I have seen a setup guide for the Q5 non-BO but wiring to the BO system will be easy peasy since everything you need is already in the trunk area. No crazy long wire runs needed (unless you wish to run a remote bass knob up to the driver area.
    Feb 25 2014
    Arkansas
    Before I picked up my Q5, I ran the TW5 in my A4 powered by a JL HD 900/5 which has 500 watts for the mono sub channel. I bought the TW5 in the JL prefabbed enclosure, but I hear that bigger enclosures sound better. Nevertheless, it was more than enough power and definitely sounded awesome.. I actually considered using the TW5 in the Q but decided to run an Image Dynamics IDMax 12 with the more available space. Sonic Electornix has a NVX amp kit for a good price.
    https://www.sonicelectronix.com/item...l-Amp-Kit.html
    https://creativeaudio.net/mobile/enc...edge-sealed-2/
    This is the TW3 and I had this installed as well. It's plenty.
    If you sign up for the newsletter for Creative Audio, you get 10% off. You can call them too and they might come off the price. They sold the TW5 to me for around $450.
    Sent from
    Dec 21 2015
    SF
    Quote Originally Posted by jomama229 View Post
    wow!
    This is super clean!
    Active Member One Ring Jonathan S's Avatar
    Mar 08 2016
    Vancouver BC
    I did a custom install with a 12" sub -- 8" and 10"s don't go low or loud enough for my ears
    http://www.audizine.com/forum/showth...ight=subwoofer
    [IMG][/IMG]
    Jonathan S
    Vancouver BC
    2012 Audi Q5
    2012 Porsche 911 Turbo S
    Sep 12 2016
    Natick/MA
    But is the trunk usable after this ?
    Mar 08 2016
    Vancouver BC
    This is what is looks like with the cover on it -- trunk is fully useable
    Jonathan S
    Vancouver BC
    2012 Audi Q5
    Jan 25 2017
    Richmond, VA
    So has anyone confirmed if the Alpine (PWE-S8 or PWE-V80) or the Kicker box https://www.amazon.com/dp/B007LQWSYC...ing=UTF8&psc=1 will fit in the space behind the factory spare if you remove the plastic tray insert? (please post pics!) I am not interested in losing my spare or paying $600-1000 for a custom box (very nice work above though with the JLs built around the spare!). I looked at the dimensions of the JL 8" Micro Sub and I do not think it will fit (18-1/2"W x 11-1/8"H x 5-1/8"D) with the spare in place - the height is the problem and is the same as the 10" power wedge....
    Apr 14 2014
    Quote Originally Posted by IRogue View Post
    Kicker TCWRT82 will fit perfectly with spare tire inside
    https://www.amazon.com/dp/B00FAUGDRY
    That's what i use before my current setup
    And sounded good.
    I got that enclosure for sale
    Used for few hours in perfect condition and very cheap
    Pm if You are interested
    Subwoofer dia (in, cm) 8, 20
    Impedance (Ohms) 2
    Power Watts (peak/RMS) 600/300
    Sensitivity (dB 1w/1m) 85.5
    Box Top Depth (in, cm) 4-3/8, 11.1
    Box Bottom Depth (in, cm) 5-3/8, 13.5
    Box Height (in, cm) 16-1/8, 41
    Box Width (in, cm) 9, 23
    Recommended Amplifiers
    12CX3001 or 41DXA2501
    My current setup:
    amp and two-channel processor
    [IMG][/IMG]
    [IMG][/IMG]
    sub new
    [IMG][/IMG]
    sub old
    control unit
    Veteran Member Four Rings tcm glx's Avatar
    So Cal
    What's the story on that Rockford fosgate box. Looks great!!
    2013 Audi Q5 2.0T Premium Ibis White/Chesnut Brown
    2022 Audi Q8 3.0T Glacier White
    Jan 25 2017
    Richmond, VA
    xpspc, any chance you have a pic with the Kicker box installed? The dimensions are 18x10.5x7.5 which is bigger than -
    Alpine PWE-S8 ($299) 13.5 x 9 x 2.75
    Kicker 11HS8 ($299) 14.25 x 9.5 x 3.25
    Rockford PS-8 ($299) 14.5 x 9.5 x 3.5
    Both of the JL Audio boxes (8" and 10") ($429-449) are 11.125 wide and doubtfully will not fit (missing by 1" or more)?
    Apr 14 2014
    look at post #18
    http://www.audiworld.com/forums/q5-s...2860447/page2/
    not my install but same placement
    Jan 25 2017
    Richmond, VA
    ^ thank you!
    So Cal
    Quote Originally Posted by tcm glx View Post
    Any info? Is that a custom box?
    Apr 14 2014
    Yes-custom, MDF board sealed subwoofer enclosure
    P3SD2-10 10" Punch P3S Shallow 2-Ohm DVC subwoofer because of shallow mounting depth (3.5inch)
    P3SD2-10 features Dual 2-Ohm voice coils for wiring flexibility and 300 Watts RMS power handling
    A sealed box is the easiest to design and build, and protects the woofer against subsonic bass that can affect its performance.
    Two main challenges — making sure it contains the proper volume of air, and controlling the cabinet resonances.
    Jan 25 2017
    Richmond, VA
    reposting a few pics of the Kicker box installed with spare. (so the 3 powered boxes above should all fit).
    The Kicker 8" CompRT specs -
    ◦Box Top Depth (11.1 cm): 4-3/8"
    ◦Box Bottom Depth (13.5 cm): 5-3/8"
    ◦Box Height (41 cm): 16-1/8"
    ◦Box Width (23 cm): 9"
    Jan 25 2017
    Richmond, VA
    Quote Originally Posted by xpspc View Post
    pm'd
    Feb 25 2017
    Edmonton Ab. Canada
    And sounded good.
    Impedance (Ohms) 2
    My current setup:
    [IMG][/IMG]
    [IMG][/IMG]
    sub new
    [IMG][/IMG]
    sub old
    control unit
    Could you provide some more info on the sub level control, is the panel custom as it looks that way and what is the switch below the level knob? more detailed pics available?
    Thanks
    Veteran Member Four Rings Perry01's Avatar
    Jan 22 2016
    Touareg V8 FSI 8V A3 - B8.5 Q5 - MKVI GTI
    Hawaii and Utah
    To improve my base I added a 10” powered sub yesterday. I wasn’t expecting window shaking base but mainly deeper lows. The install took all of 20 minutes. I removed the stock sub in the spare tire and used its inputs for the powered sub and since the battery is just inches away, it made for an easy way to supply power and ground.
    CPMA / CTS K04-0064 / IE custom tune / Wagner FMIC / Custom ZF8 TCU tune
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    Does it have the automatic on/off?
    Jan 08 2016
    Los Angeles, California
    Quote Originally Posted by Perry01 View Post
    Just curious, why was it necessary to remove the stock sub when you added the powered sub? Is it not possible to have both connected?
    '14 Q5 TDI Premium Plus S-Line w/ Black Optics: APR ECU Tune, DTUK TCU Tune, Magnaflow 3" Catback, SQ5 BITDI Intercooler, Hi-Flow CP4 Metering Valve, AFE Dry Flow Air Filter, Full ECS Drivetrain Inserts, AG M610 Wheels, 034 RSB with Moog Endlinks.
    Jan 22 2016
    Hawaii and Utah
    Quote Originally Posted by SQive View Post
    Yes it does.
    Quote Originally Posted by Pittdawg View Post
    The stock sub was small, thin paper and couldn’t handle much power. This one is 10”, 200 watts RMS and fits nicely under the rear compartment.
    Mar 21 2018
    Raleigh
    FYI Cerwin Vega now makes a spare tire subwoofer and JBL is releasing one soon. I was going to order the Cerwin Vega one but a local car audio shop said he heard it at CES and said the JBL one sounded better. He sells JBL products so not sure if it's biased or not. This car audio shop also said he can use a LOC and make the sub sound better with b&o. He said the LOC prevents the system from adjusting bass volume when you turn it up.
    Jul 07 2015
    19RS3
    Ontario, Canada
    So I just got my 10” box same as yours but I can’t seem to fit it under the floor. Did you have to remove the grill to get the floor down or modify anything to make it fit?
    Thanks
