Results 1 to 14 of 14
    Active Member Two Rings rs5nightrider's Avatar
    Jan 16 2017
    EU
    Water condensation in headlight, any fix?
    Hey guys. I have a water condensate (actually seems like dried deposits already) in one of my headlights. Has anyone encountered something like this? Any fix out there except for buying a new headlight?
    RS5 B8.5 /w Engine & Gearbox Tune, Eventuri Intake, Vorsteiner VFF-103 20x10
    Veteran Member Four Rings Sgibb16's Avatar
    Jul 02 2012
    2012 A5 & 2002 Passat Wagon
    Fredericksburg, VA
    2012 A5 P+ | Sports Package | 6MT | 35% Tint
    REVO Stage II | AWE Quad Exhaust | 034 HFC | E-Codes | FK Silverline Coils | JHM Short Throw Shifter | Eurocode HFIC Pipe | Roc Euro Intake
    TR8 Intercooler | CTS Silicone Hose Kit & Turbo Outlet | CR-15 Strut Brace | Alu Kreuz | S-line Front & Rear Bumper Conversion
    Feb 08 2006
    99 1.8T Passat, B6 S4 Noggy, RS6 01E Stg II Tune
    Columbia, Md; WPB, Fl
    Read this, different model but may be same principal if o rings are still used. If so, you can go to home depot and get a container with multiple sizes to replace.
    http://www.audizine.com/forum/showth...Code-Bi-Xenons
    Veteran Member Four Rings mopaNi's Avatar
    Aug 02 2016
    Columbus, OH
    If it's dirty moisture that dried dust on there you're screwed. If it's moisture just trapped in there you can pull all the bulbs and then hook a vacuum up to one of the sockets. Try to pull all the damp air out.
    That removes the moisture but doesn't fix the problem though. I haven't seen the back of an Audi light yet but I assume you just need new orings and or boots.
    mopaNi | 2013 S5 Premium+ 6MT Estoril
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    Ecodes
    2013 Audi S5 - EPL Stg 2 E40 ECU/TCU, AWE Track 102mm, RocEuro intake, etc.
    2014 Audi Q5 S Line
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
    Jan 16 2017
    EU
    Quote Originally Posted by mopaNi View Post
    It seems to be dried dust or similar stuff.
    I was thinking, maybe If I manage to take the headlight apart and clean it, I could place one of those moisture absorbing bags you get in shoes somewhere..?
    Jan 16 2017
    EU
    Quote Originally Posted by HazeMyth View Post
    Ecodes
    I never quite understood what the Ecodes everyone is talking about actually are. Can you shed some light?
    Double post my bad
    Aug 02 2016
    Columbus, OH
    Desiccant packs can do wonders. When I did my headlights in the TL I upgraded the pack it had with one from an iMac box that was 10x the size.
    But that DOESN'T do anything for dirt and that doesn't fix the problem at all.
    You're better off just buying a new light if it's dirt in there.
    Edit: Ecodes are euro versions of OE lights. They don't have DOT requirements so they don't have amber turn signals and the projector lenses are clear not fresnel so it's a tad brighter and a lot cleaner cutoff.
    Jul 17 2015
    Colorado
    Quote Originally Posted by rs5nightrider View Post
    Double post my bad
    Oh, I was just poking fun at the relentless ecode comments. They're euro lights. No amber markers, slightly better lighting output.
    2014 Audi Q5 S Line
    IG: @MrHazeMyth
    Jan 16 2017
    EU
    Edit: Ecodes are euro versions of OE lights. They don't have DOT requirements so they don't have amber turn signals and the projector lenses are clear not fresnel so it's a tad bright and a lot cleaner cutoff.
    I dont actually think it is dirt. Seems to be water that left deposits after it dried. Headlight is so expensive damn. I will try and take it apart once it gets warmer around here.
    @HazeMyth
    Ahh my car is Euro and dont have the ambers
    Aug 02 2016
    Columbus, OH
    Deposits = dirt. Dust, calcium, salt, whatever. You'll never be able to get it out of there unless you crack open the headlight. Which is doable.
    And I didn't see amber so that's why I didn't give the obligatory ecode comment. Glad I held back.
    Jul 25 2011
    @HazeMyth
    don't try opening them up yourself. Take it to a good shop that knows how to customize lights and seal them properly.... Would be a good time to maybe paint the insides satin black
    To the ppl saying ecodes, he's already in Europe lol
    Also if you still have warranty the dealer might replace it, this is most def a defect with your lights.
    Aug 02 2016
    Columbus, OH
    I agree. Considering the age and the trim level I imagine Audi will take care of it.
    Mar 21 2016
    2018 SQ5
    Scottsdale, AZ
    Audi has a TSB about the headlight condensation essentially only saying that its normal....
    "The headlight circulation system allows air from the outside to flow through the headlights. This open waterprotected
    ventilation system (which is needed for pressure compensation) creates different climate zones in the
    headlight: very warm areas, where the lens is warmed up by the light, and relatively cool areas, where the lens is
    cooled down by the airflow.
    Considerable differences in humidity and temperature between the inside and the outside of the headlights, even
    when the car is being driven, can create condensation. While condensation is most common in cold and wet
    weather, it can also occur after a car wash, after the engine or front end has been steam-cleaned, or when the
    temperature changes. Condensation is more visible on lenses made of clear glass than on lenses with patterns.
    The moisture does not affect the headlight function or light performance, and it does not lead to corrosion or
    damage of other headlight parts."
    "Service
    For headlights, the affected lens surface should be clear after approximately 10 minutes of light operation,
    although the entire lens surface may not clear. The clearing process depends on the outside temperature and the
    humidity.
    • When water droplets have formed on the inside of the lens or water has collected at the bottom of the light
    assembly, check for leaking seals and/or cracks in the lens or light assembly. If no damage is found, use
    compressed air (less than 30 PSI) to clear the lens.
    • On light assemblies with LED lights (such as S6 daytime running lights) the LED lights do not emit enough heat
    to clear the moisture from the lens. Only the pressure difference of the ventilation system provides the air flow
    to clear the moisture on the inside of the lens. The design of the ventilation system on these types of lights will
    ensure the lens is clear after a few miles have been driven."
    2019 SQ5 - Quantum Gray - Premium Plus - 21's - S Sport - Napa - B&O - Roc Euro Intake
    Previous:
    2018 SQ5 - S Sport - Napa Leather - B&O
    2018 Q7 3.0T - Premium Plus - 20's - Vision - Warm - Cold - Towing
    2017 Q5 3.0T S-Line
    2016 A5 S-Line
