2006 A4 Stage 2+, about 130k, (<---recipe for disaster.... I know
When installing the gauge I noticed my filter housing gasket leak had gotten significantly worse, saw some oil on the bottom of the pan from running down the side of the block. At this point I am assuming the oil pump is on its way out but just want to gather your guy's opinion on any other possible solutions. I have always used Motul 8100 excess with Ceratec additive and K&N or Mann filters on oil changes @ 4k intervals give or take. Also run the ECS aluminum filter housing.
Here is my plan of action:
-Run some Motul engine flush tonight, and throw some fresh oil in and maybe some Lucas stabilizer to try to minimize any damage to the cam/valvetrain (probably already toast
-Will have some free time this weekend and plan to replace oil filter housing and oil cooler gaskets, inspect filter housing for anything out of the ordinary, will probably drop the pan while I'm at it and inspect/replace pick up tube. Probably pull valve cover also to check things out up top.
-Given that does not fix the issue, which I assume it probably won't I am leaning toward a 1.8T pump conversion, really do not have the coin to tear down the entire engine until tax return season when I can reassemble it with forged pistons/rods, arp head studs etc etc. Or just scooping a BPY engine and swapping the whole thing.
I am probably forgetting to mention something here but any insight is greatly appreciated. Have a friend selling a B8 A5 3.2 6MT that I am now starting to plan to buy since I do not see this oil pressure getting resolved anytime soon. Working full time and being in school and having a 5 month old does not allow much time anymore to do
