Originally Posted by
EuroxS4
Copper spark plugs have a solid copper core, but the business end of the center electrode is actually a 2.5mm-diameter nickel alloy. That’s the largest diameter electrode of all the spark plug types. Remember, the smaller the diameter, the less voltage required to initiate the spark. Nickel alloy is also softer than either platinum or iridium, so the sharp firing edge you get right out of the box tends to wear out quickly. Despite those shortcomings, copper spark plugs are still a good choice for certain applications. Copper spark plugs are best for older (pre-‘80s) vehicles with low voltage distributor-based ignition systems. But don’t use copper spark plugs in high-energy distributor-less ignition systems (DIS) or coil-on-plug (COP) ignition systems. They’ll wear out too quickly.
There’s one exception to that advice. Some late-model high-performance engines were designed specifically for copper spark plugs. In those cases, copper spark plugs are considered to be high performance spark plugs. If your owner’s manual calls for copper spark plugs, don’t upgrade to platinum spark plugs or iridium spark plugs.
Good luck!!!
Is that why when you give them your car details at Autozone, copper isn't the first thing that pops up in their system, if at all?
I installed NGK Iridium somethings, which I believe OG and someone else use. Hopefully gap is correct. Car is stock. I think I picked the right heat range version.
MPG on the cluster stays around 25, not sure why. One thing I DO know needs doing, is the fuel filter.
Otherwise the car is stock (coilpacks, etc.)
The tank seems kinda small, not sure if it actually is, or something else is causing that impression.
jacobsen
The Denso plugs are the best it's better for your cylinder head spark plug threads not to change them all the time, it's easy to chew them up that soft aluminum.
This is what I was scared of. Torquing threads is repeated stress, and it's aluminum.
NGK claims their threading is coated in some thin metal layer that breaks away when you loosen them, to act as anti-sieze, rather than super old iron plugs where you have to smear anti-sieze paste on it.
Maybe this means they're not the best to re-use over and over again, and if I pull them out, I guess I could spend a few bucks to put new ones back in their place. Unless I'm checking/reading them or something? Or a compression test? You get what I'm referring to.
eljay
55mph is a good sweet spot for fuel economy. On our highways, I'm cruising at 70mph and with cruise on, unless the road is perfectly flat, the cruise control always adds/backs throttle and I keep jumping from vacuum to boost and back, which doesn't help, so I tend not use cruise control. :(
Same. I have to look and think ahead while I'm driving, at how the road goes. Chris Harris said this is how his Renault 2CV was, adding excitement, compared to his E9X M3 V8 (high-revving, N/A). That's right. I just compared the B6 to an old farm car that got patio furniture for seats. Maybe if Audi gave us TDI's, 2.7T's, or I5T's.
Maybe speed up first, or down-shift to have higher RPM and mechanical advantage helping me out. Maybe I'm to afraid to use the revs. I hear that with 1.8T, (when it's warmed up assume), it doesn't really matter where you rev, for economy.
Whereas in an S4 (V8), I bet you'll notice a difference.
02X GJW and this rev behavior seem to like it around 70. Maybe 01A 5MT differs.
But if you hit a hill like that, now you're struggling to get up, the car is bogging, and I assume trying to boost (I don't have a boost gauge)
I don't use cruise control in times like that. And when it's off, I can also feel what's going on through the pedal.
Like if my pedal input remains the same, but the speed and RPM starts to drop, this means the hill is bigger than I anticipated.
I guess momentum helps but it's still a heavy car.
This probably wouldn't happen in a Bentley, where you could probably take off from a stop sign in 4th gear.
