Originally Posted by
derek.kritz
Has anyone tried running some long spacers and/or spark plug extensions to get to get the o2 sensors far enough away to go catless??
You will end up getting a sensor "2" rich/lean response too slow CEL.
I'm currently testing Area74 simulators on my JHM HFC set-up. It's an active simulator that takes the signal from the O2 sensor and sends a corrected signal to the ECU; essentially when a signal too rich is being sent to the Area74 simulator (higher mV), it sends a lower voltage to the ECU side. So far I've been able to pass all OBD-II readiness (but I can guarantee that I will fail an actual sniffer, thankfully no emissions in FL), I'm just waiting to see if a CEL creeps up for cat inefficiency (P0420/P0430); it corrects the rich signal (the ECU seems no higher than .83x mV), however it doesn't correct a lean signal (too much oxygen, or a lower mV reading), which will happen from time to time even with the stock cats such as when you are sitting at a stop-light or stationary. My understanding is that the ECU will only trigger a cat inefficiency if the voltage sharply spikes too fast from rich to lean, but not normal to lean, but time will tell.
With that being said, it you want to give it a shot with the Area74 simulators, the wiring harness on our O2 sensors are as follows:
Pin 4 - (black) signal wire
Pin 3 - (gray) signal ground
Pin 2 - (white) O2 heater power
Pin 1 - (white) O2 heater ground
I'll make a proper post about it with pictures of how to hook it up as soon as I can confirm that it will not trigger a CEL, I'm only 150miles into testing, but so far so good without triggering a CEL and 100% passed readiness with the HFC. It will be a nice option for those who only have OBD-II testing for "readiness" as you may not pass it with a software delete.
