Results 1 to 4 of 4
    Jan 16 2017
    Niagara Falls, Canada
    P0011 Generic Intake Camshaft Position Timing-Over-Advanced (Bank 1)
    Hi all,
    I have an '07 A4 2.0T with a code reading P0011 Generic Intake Camshaft Position Timing-Over-Advanced (Bank 1). I've since unplugged the sensor at the front of the engine, cleaned it out, removed the whole sensor from within the engine, cleaned the oil from it and put it back in. Still get the same code. are there checks for Voltage or Ohms I need to be aware of or is it just a simple sensor replacement?
    Please help.
    Thanks,
    Edit / Delete Edit Post Quick reply to this message Reply Reply With Quote Reply With Quote Multi-Quote This Message
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Stage 1 more than you RS3
    Oct 24 2015
    Perth, WA
    My respray thread
    Veteran Member Three Rings 3g_bishi's Avatar
    Mar 03 2016
    07 a6. 13 A7, 13A6, 08 A8LW12, 16A3, 15RS7
    DFW
    Oil change, if not than timing solenoid. If not then timing chains
