Results 1 to 13 of 13
    Veteran Member Four Rings pw211's Avatar
    Dec 14 2008
    Bay Area
    SportShifters Review
    So I have been through a number of shift knobs in my car (Stock->BFI->BFI #2->SportShifters), the current one is the SportShifters one you guys may have seen posted on here. When I saw their ad I wanted one desperately and ordered it the same week, having not seen one even installed on a car. I promised a review to peeps, so here it is!
    Company
    SportShifters has been genuinely fantastic to deal with. They are prompt to answer questions and are super flexible about customizing the shifters and doing different configurations. I dealt basically entirely with Roy, and he was awesome. We had some delivery delays due to a shipping company's difficulties and he was on top of it, calling them every day to get it sorted. I could keep going, but it would be redundant: I put a lot of value in how a company is to deal with. I've had some really bad or just neutral experiences with plenty of the companies that advertise on here or sell products for our car, this is not one of those.
    Product Quality/Fit
    What you guys are probably really here for! Overall product quality is fantastic. In the kit, you get the aluminum block, the boot, the aluminum shaft, and the shifter which is a multi-piece setup. It's all really straightforward as far as install/how it all goes together. Everything fits well and install onto the car was a breeze. For reference, I have one of the taller shafts you can put on the knob, so you wouldn't have to make yours sit as tall. I have a shorter shaft, so I'll try to put that on and take pictures eventually.
    A couple notes on install:
    • You will have to remove the chrome trim that surrounds the boot on your shifter surround. If you are careful, you can remove this without destroying the tabs that hold it in place and only bending them
    • IF you have vinyl wrapped your shifter surround, you will likely have to re-wrap it. The chrome piece mentioned above left an imprint on my vinyl wrap, so I decided to re-wrap it. If you haven't vinyl wrapped your trim, you will just want to clean this area well.
    • The pictures on the website can be a bit confusing, because they use a generic black plastic mount to display these on. This plate doesn't come with the shifter, instead the aluminum block attaches to YOUR shifter surround, so it will be surrounded by whatever your trim is.
    The shifter feels great in use. No play/wobbling, and the set screws have held without issue (no loctite or anything like that). The way the boot descends adds so much depth to the whole shifter assembly, it's pretty fantastic.
    Product Customizability
    This is probably what I hold SportShifters in the highest regard for: I bought this kit right when it released, and there were already tons of options. Months later, and they've added so many more levels of customizability it's hard to wrap your head around. You can check out their website for some of the stuff I'm talking about, but you get to choose everything including:
    • Shift knob style/shape
    • Letter coloring on shift knob
    • Material for shift knob
    • Length of shifter shaft
    • Material for shift boot
    • Color for stitching for boot
    • Weight of the knob (I think they have 2-4 levels of weight)
    To me that's pretty cool, meaning you can tailor your setup to exactly your interior theme.
    Product Comparison
    So how does it compare to the BFI knobs? It's kind of a difficult comparison. The price difference I believe is around or a little over $100 in favor of the BFI knobs. But then with SportShifters, you aren't JUST getting a shift knob. You're getting an entirely new shifter setup really, and it drastically changes the look of the car.
    Physically, the BFI knob is a decent amount thicker/larger in diameter. I don't think this is good or bad either way, but more of a preference thing. I was always very fond of my BFI knobs; I went with two because I wanted to switch colors. But this is an important difference too. The SS knobs are modular. You can remove the top disk from the material/grip part of the knob. So if you wanted to switch out your lettering for a different color, or wanted to switch from leather to ultra-suede, you can do so rather easily without buying a whole other knob (I actually did just this, and am switching to red lettering and stitching to better match my interior). So if you are wishy-washy or like to change a lot like myself, the SS knob makes this easier on the bank
    BFI Knob in my car:
    SS knob in my car:
    And a before/after picture of my interior:
    Let me know if you guys have questions. I'll be taking more pictures eventually so will add those here when I do.
    Roy if you're seeing this, thanks again for all the help!
    Pat
    F.T.W.L.T.B.D.W.I.C.T.W
    P.I.I.T.B
    IG: pwwhite
    "I bet if Sean posted a picture of toast it would get 50 likes. And more than 3 people would say 'specs?'" - Solarsuplex
    Veteran Member Four Rings kurupt_hawaiian's Avatar
    Oct 13 2007
    2017 Toyota Tacoma TRD Off-road
    Waianae, Originally Molokai
    Where did you order from?
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    2018 Audi A6 Mythos Black
    (SOLD) 2007 Audi A4 Quartz Gray 2.0T 6MT
    Follow me on Instagram- @Kurupt_Hawaiian
    -Elias
    Dec 14 2008
    Bay Area
    Quote Originally Posted by kurupt_hawaiian View Post
    I ordered it directly through them, shot them a message on here.
    Pat
    P.I.I.T.B
    IG: pwwhite
    Veteran Member Four Rings thenofjboy's Avatar
    Oct 08 2007
    08 S-line QMT6 , B5 KO4 & my german sheppard
    Jersey City
    Good review - I was hoping you would post this soon
    Sean
    The New
    B7---GIAC--BBS--DDM--JHM+S4Exhaust--StaSIS SS--034--AudiUP--USP--RedEBC--IE--DrakesVC#12--B7S4 Brakes--StopTech--GFB DV+--
    The Old
    B5---GIAC-K04--RACETEC--APR--DEPO--AUTOTECH--VMR--FORGE--034--H&R--BILSTEIN--FUJITA
    Veteran Member Four Rings QuattriumMT6's Avatar
    Aug 24 2013
    1991 Toyota Mr2 Turbo
    Stockton, CA
    Looks really good but wonder how hard it'll be to shift once the car has been sitting in high heat for a good amount of time.
    Deactivated Four Rings
    Jun 23 2011
    Aug 24 2013
    Stockton, CA
    Golden! I've always wanted a branded 6 speed pattern in my palm 😂
    Dec 14 2008
    Bay Area
    Quote Originally Posted by QuattriumMT6 View Post
    Hard to say. I never had many issues with my BFI knobs and the knob is similar enough, having non-metal around the sides makes it easier if it gets crazy hot to just avoid touching the metal.
    Pat
    P.I.I.T.B
    IG: pwwhite
    Aug 24 2013
    Stockton, CA
    Either way looks badass (reminds me of the gated shifter found in Italian exotics) and it's definitely on my wish list. Mind PMing me the options you chose?
    Dec 14 2008
    Bay Area
    PM sent man!
    Pat
    P.I.I.T.B
    IG: pwwhite
    Dec 14 2008
    Bay Area
    Got some more photos:
    Pat
    P.I.I.T.B
    IG: pwwhite
    Feb 19 2015
    Florence, AL
    Regarding the knob getting hot in the sun. I don't have this knob, but have had other metal knobs. I keep a drink can koozie in the under seat compartment and stick it over the knob when I'm going to be leaving the car in the heat. Has always worked perfect for me.
    Dec 14 2008
    Bay Area
    Quote Originally Posted by jp_pearce View Post
    If it becomes a problem I may steal this idea!
    Pat
    P.I.I.T.B
    IG: pwwhite
