Originally Posted by
AFAndrew
So it powers on with just the immobilizer light and the epc light on but the displays don't work
That's fine, as long as it powers on you should be fine. Just check connection on the cluster and wiring if it got damage somehow.
If you have generic diagnostic cable (cheap eBay one) you can search and download VAG commander V 1.4 and run it on XP, go to instrument cluster option hit ECU reset and after it cycles hit read, wait more until it cycles again and that could take a minute, SKC will be four digit code under mileage which will be displayed in kilometers. You'll need to add 0 before that 4 digit code.
If you get code 1952 (I think or something like that) and if the mileage doesn't reflect your original mileage on kilometers it didn't work.
Try clearing codes if you have any and do it again.
