Results 1 to 20 of 20
    Senior Member Two Rings mwmaroney1's Avatar
    May 08 2012
    2014 S6
    S6 Battery Replacement?
    Just wondering if anyone has been through this process themselves on C7 S6. Don't currently drive the car much but the battery seems to be on the fritz. It's covered under warranty but I'm not sure if I want to risk a TD1 for something that should be simple to replace (at least on a normal car). Just wondering if anyone has replaced theirs with an aftermarket? Also it looks like I need to code in the replacement with vagcom, just wondering how difficult that is. Thanks for anyone who can help!
    Jan 24 2012
    Tucson AZ
    Bump - think I will need to change my battery soon as well. Are the A6 instructions same as S6? I've read through the battery coding - but anyone know if Costco sells an equivalent battery? Their interstate car battery website is very confusing (requires an option code).
    Aug 04 2016
    Athens,GA
    I replaced mine with oem, took about 15 minutes in total. Coding help in available online and is very straightforward.
    Mar 26 2010
    US
    Quote Originally Posted by hanyoung View Post
    Autozone has several. ~$150 to $200
    Senior Member Two Rings aFOURstance's Avatar
    Jan 30 2011
    '04 DBP R32 PTE6266 Turbo, '01 Nogaro S4 Stg 3 & Bagged
    FAIRFAX, VA
    Make sure you get an OE battery, easy replacement takes maybe 20-30 mins, look up the diy on youtube
    Life is too short to drive boring cars.
    Jan 30 2011
    FAIRFAX, VA
    Make sure you get an OE battery, easy replacement takes maybe 20-30 mins, look up the diy on youtube.
    Veteran Member Three Rings s4nicetry's Avatar
    Nov 29 2007
    Calgary / Vancouver
    Quote Originally Posted by aFOURstance View Post
    Why does it need to be an OE battery?
    Jan 30 2011
    FAIRFAX, VA
    Quote Originally Posted by s4nicetry View Post
    For the vagcom coding, otherwise you can potentially have issues down the road. But I mean its your car so you can do whatever you want
    Nov 29 2007
    Calgary / Vancouver
    You can still code an aftermarket battery with vagcom
    Mar 26 2010
    US
    It does not need to be OEM, only OEM equivalent.
    Jan 30 2011
    FAIRFAX, VA
    I was just going by this video https://youtu.be/IJAScg6JrYI
    Mar 26 2010
    US
    Autozone battery examples:
    Price: $199.99, Duralast Platinum / Battery, H8-AGM, 3 year warranty, 900CCA, 60.76 lbs, group 49
    Price: $159.99, Duralast Gold / Battery, H8-DLG , 5 year warranty, 900CCA, 48.01 lbs, group 49
    Price: $159.99, Duralast Gold / Battery, H9-DLG , 5 year warranty, 950CCA, 63.9 lbs, group 95R
    BMW M3 Competition X-drive
    Veteran Member Four Rings OlyS6's Avatar
    Nov 22 2016
    Olympia, WA
    To add to this thread, there are several different batteries out there that are compatible with the C7 platform that have a higher cold cranking amp than the OEM battery, and more importantly, a significantly longer reserve time.
    As wwhan mentioned above, many of the size 'group 49' batteries are compatible with our cars. Sears Diehard group 49 batteries are also compatible with the S6.
    2016 S6, mythos black, RS7 turbos, MRC inlets |Akrapovic exhaust| AMS downpipes and intercooler |Eventuri intake| Loba HPFPs |Tial wastegates| Eurocode sways, end-links, and AK | Audi CCB| HRE P103, 20x10 | RS6 grille| Neidfaktor CF mirrors, diffuser, and steering wheel| Blackvue dashcams| Escort Max CI 360 | RS6 LED headlights, OEM Euro tails |Sound: Navtv Zen-v preamp, Helix DSP Ultra, JL HD900/5 driving JL10W3 sub and Hybrid Audio speakers.
    Veteran Member Four Rings digdah's Avatar
    Dec 11 2017
    DFW
    So my bloody battery is going out and I am seriously debating going non OEM and changing it out myself. How does the coding work if it is non-OEM?
    I will probably follow up with the stealership because I could swear I had them change out the battery before delivery last year so it should be under some sort of warranty.
    Nov 22 2016
    Olympia, WA
    It's simply a matter of changing the last digit in the battery code to something different than the current one so the system knows it's a different battery. It won't alter any regulatory functions or performance of the battery
    Senior Member Two Rings overclocked's Avatar
    May 21 2018
    2018 Audi S6 Sepang Blue APR Stage 2, ECU/TCU tune, SRM intake, 2015 Audi A3, Mercedes Benz GLE 350
    Washington DC Metro area
    I had mine replaced under warranty. Specifically asked them not to hookup to scan tools, and they did not. Said typically they do but did not in my case as battery seemed totally dead
    2018 S6 Sepang Blue APR Stage 2 with APR DP, TCU tune, SRM intake
    2017 Mercedes GLE 350 4MATIC Stock
    2015 Audi A3 2.0T
    Jul 30 2013
    Colorado
    My indy is getting ready to swap mine. $200 for the battery and coding. They recommend "Interstate", so works for me.
    Dec 11 2017
    DFW
    Quote Originally Posted by OlyS6 View Post
    Awesome thanks.
    Come to find out I have an unlimited warranty on my battery so they will be swapping out out on their dime. I hope they don't TD1 me since I'm going to a different (AutoNation) dealer than my standard one.
    Senior Member Two Rings nvygw171's Avatar
    Oct 29 2017
    Marin, ca
    Is there anything that would prohibit the use of a braile atm battery on these cars? I have a new brail 21lb 1400 cca battery. I know it doesnt match the specs but could it be used. I hav vagcom and obdelvin to code with
    Oct 29 2017
    Marin, ca
    Answered my own question. Braile battery installed with no coding needed. And works fine. All in saves 50+ lbs.
