Results 1 to 15 of 15
    Aug 31 2015
    California
    Secondary Cabin Air Filter Install
    For those interested in a secondary filter solution, I found the part on AliExpress for $10 shipped. I had to shave a hair off the plastic tabs, but otherwise, the install was simple and fitment is good.
    https://www.aliexpress.com/item/cabi...608.0.0.YqeFLR
    [IMG][/IMG]
    [IMG][/IMG]
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Any pics of it installed? Does the grill not go back on?
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Aug 31 2015
    California
    Last two pics are of it installed. The filter frame clips onto the housing and replaces the grill.
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    Not bad for $10. When I first bought my car I noticed that there was something 'missing' under that grille. I searched and searched and finally found a thread on the subject.
    It appears that it's only for high smog areas and that's why we don't get a filter in North America. Not sure how true that is tho.
    For anyone who wants the OEM part, I've had this bookmarked for about a year now lol https://www.ecstuning.com/b-genuine-...le/8kd819441a/
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Veteran Member Four Rings shadycrew31's Avatar
    May 27 2013
    West Chester, PA
    That looks like a clogged filter waiting to happen.
    2010 S4, DSG, too many random parts. 2004 Mazda RX-8, was highly modified then went back to stock.
    Senior Member Two Rings Quidproquo's Avatar
    Aug 06 2015
    2013 Audi S4, 2007 Nissan 350Z Enthusiast
    Morris County, NJ
    That's quite the markup for the OEM part.
    2013 B8.5 S4 DSG (034 Motorsports intake tube | air box mod | aFe Pro Filter | CTS+183mm Iabed Pullies | EPL Dual Pulley 93 Pump Tune | SunTek 35% Tint | 19" S5 Rotor Wheels)
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Quote Originally Posted by shadycrew31 View Post
    ^^ this. Not sure anything beyond the one under the dash is necessary.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Nov 11 2010
    2023 S8, 2020 Range Rover
    Minnesota
    Quote Originally Posted by pdqgp View Post
    I cut the foot off of my wife's nylons and wrapped the lid with it. While it doesn't filter the small particles it captures quite a bit of leaf particles and "fuzzies" . I suppose if you lived in China where these filters come from you might want double filters for all of the smog.
    May 27 2013
    West Chester, PA
    Or you can just put it on recirculate and avoid the entire process.
    Jan 04 2013
    Phoenix, az
    Based on the junk that gets in there I see the point. Also living in the desert south west were it is super dusty I see the value. I leave mine in circulate "ALWAYS" because of that. But keeping junk out of the fan makes sense as well. K&N has a pre filter that you can put on the filters to keep rain and extra dirt out, perhaps something like that might work as well.
    Veteran Member Four Rings fmzip's Avatar
    Aug 21 2017
    what do you mean? It's easily replaced, I don't follow?
    BMW M850i
    Oct 06 2014
    Cleveland, OH
    I just got this secondary filter off Amazon and plan on installing this weekend,along wit a new cabin filter as well.
    https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
    https://www.europaparts.com/frecious...k0819439b.html
    Veteran Member Three Rings Dorny1's Avatar
    Feb 06 2010
    2010 Audi A4
    North Eastern, IA
    concern I would think is that there is a posibility with a wet filter chunks ending up in the car. I just wrapped mine in pantyhose and called it a day.
    2010 Audi S4 GIAC Stage II, H&R Sport springs/Koni Yellows, USP Intake, AWE Track exhaust.
    (SOLD) 2001.5 Audi S4 Stage III
    "I love my mullet exhaust...Quiet in the front, Loud in the back"
    Senior Member Two Rings steampunkjunker's Avatar
    Jun 21 2017
    NorCal
    I would highly recommend the Mann FreciousPlus cabin filter:
    https://www.ecstuning.com/b-mann-par...er/fp2450~man/
    Junker’s 2013 B8.5 S4
    • Suspension: H&R ARBs, CR-15, H&R 10/12mm wheel spacers
    • Braking: Endless MX-72 & RF-650 fluid, StopTech cryo slotted rotors, Tyrolsport brake lines & caliper bushings
    • Motor: GIAC - Stage 2, Redline oil
    • Coming soon: GIAC - TCU, Bilstein B12 Pro-Kit
    Veteran Member Four Rings isles1's Avatar
    Oct 24 2012
    2013 S4, 2022 SQ5
    Nassau County, NY
    Installed one today. Just search eBay for 8KD819441 and you will have a bunch of options under $10. I do not see the harm or how water would end up in the filter to cause concern about it falling apart.
    Thanks for the suggestion OP.
    2022 SQ5, P+, Daytona Grey, S Sport, B&O, Black Optic, Black Badges, Dynamic Steering, OEM Sport Exhaust, Black/Black Dinamica.
    2013 S4, P+, DSG, Ice Silver Metallic, Black/Silver Alcantara, Sport Diff, B&O, 19" Peelers, Pilot Sport 4, SC Badges, Alu Kreuz, Endless MX72 brake pads, StopTech slotted rotors (front), APR Carbonio Stage I & II CAI. Winter shoes: OEM B8 S4 18" Wheels w/ Nokian Hakkapeliitta 7 Studless. Original owner; custom ordered.
