Results 1 to 20 of 20
    Jan 24 2016
    DC
    The Mysterious Coolant Leak
    Hello All,
    It's been about a year since I noticed a small coolant leak forming under my car after driving it and letting it sit. During the past year, I bought two gallons of coolant and topped it off (50/50) every few weeks. Here we are a year later and I still can't find where the leak is coming from. I'm at 110,000 miles and it's time to replace the timing belt and water pump. I'd hate to have it done and not get the coolant leak fixed.
    My thermostat works fine (was replaced 30K-40K miles ago). Everything in the front of the engine is dry and around the thermostat is dry also. Everything around the CTS in the back is dry also. I noticed a small puddle/wet area right behind the oil filter on the block. I took it to a mechanic to see if we could find the leak. He pressurized the coolant reservoir tank and lifted up the car but no leaking/dripping. I assume because the car was still warm. I'm attaching few photos of my situation. What is the metal box #43 in the diagram?
    Thank you
    Veteran Member Three Rings deusilan's Avatar
    Aug 17 2012
    '89 E30 325i; 2011 Police Interceptor
    Stinky Island, NY
    That's your oil cooler.
    Currently: 2005.5 A4 2.0 (Red)TQ 6-spd, WORK IN PROGRESS 2011 Police Interceptor
    Previously: E30 325i, donated for track purposes
    Veteran Member Three Rings wding2000's Avatar
    Jul 04 2015
    08 A4 Quattro Avant; 16 Golf MK7
    My guess is: if it is not oil, then it may leak coolant from oil cooler or its gasket.
    08 a4 2.0t quattro avant | eng bwt 200hp | tip 6-spd zf 6hp19a | akebono ceramic | andros 18x8 et35 cb72.2 72-57 centric rings | pirelli p0as+ 235/40r18 | hu xtrons px5 mtce_gs_3.40 android 8 | rev d dv
    Jun 17 2013
    jersey city nj
    That is your oil cooler. most likely the gaskets are toast.
    Here's the
    https://www.europaparts.com/oil-cool...06d117070.html
    Feb 15 2016
    Cambridge,Ontario
    I think there are two gaskets.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Jun 17 2013
    jersey city nj
    The other gasket is the oil adapter to the block. That does not need to be ed unless you remove the whole oil housing adapter. The oil cooler itself can beed without the housing from the block. But the oil adapter housing gasket is this https://www.europaparts.com/oil-filt...06f115441.html. I would both since it makes since due to age of the gaskets
    Jan 24 2016
    DC
    Thank you all for the replies, appreciate it a lot. I took the car to a second mechanic who also let it sit and he also failed to find the coolant leak. I think you guys are correct that it might be a gasket or gaskets. He did say that he noticed an oil leak. Looks like there is a small oil leak and a small coolant leak. Is this an expensive repair?
    Thanks for the help
    Senior Member Three Rings miA4's Avatar
    Jul 17 2015
    miami
    Why not pressurize the coolant system to see if it'll leak?
    Jan 24 2016
    DC
    We did twice and nothing leaks. I think it's only while car is cooling down and once completely cold there is no leak. I let the car sit 3 or 4 days and small puddle doesn't increase and coolant level in reservoir stays the same
    Established Member Two Rings Cobra351's Avatar
    Feb 22 2013
    NY\C
    Quote Originally Posted by b7a408 View Post
    Just a reminder as I had this happen recently- did you check the coolant flange? Leak on the passenger side of the motor, near the exhaust manifold.
    Veteran Member Four Rings papadelogan's Avatar
    Jul 31 2011
    1999 F250 7.3 Powerstroke
    Gulf Coast of Florida
    Quote Originally Posted by Cobra351 View Post
    Is there a thread about that, some pictures, or ideally, both?
    2013 Phantom Black A5 P+ Cabriolet (2.0T quattro) mods4cars, mesh grill, gunmetal VMR 701, HFC "Boudica"
    2007 Ibis White B7 A4 Ti Avant 6MT quattro JHM Stage 2, HFC, Milltek CatBack, GFB DV+ "the YETI" sold
    2005.5 Black B7 A4 6MT quattro sold
    Veteran Member Three Rings Low and Behold's Avatar
    Feb 21 2015
    Rip City
    Quote Originally Posted by papadelogan View Post
    Tons. Search rear coolant flange.
    Casey | @cshore | B7 A4 Avant 2.0T | B8 Q5 2.0T
    Jan 24 2016
    DC
    I think I've figured it out. Diagnosis: there are two issues:
    1) I looked again yesterday and noticed dried coolant on the bottom of the engine oil pan. The coolant trickles down from behind the thermostat. I was able to see some coolant and took few photos. Thermostat works fine and has been for a year since the leak appeared.
    2) Small leak (oil and/or coolant) most likely coming from the oil cooler gasket area. This leak is the one visible in the photos I posted earlier in this thread.
    My goal is to remove this small puddle and see if coolant fills the little hole again.
    Veteran Member Four Rings 4rings5stars's Avatar
    Jul 31 2011
    Dollar to the dime, if you pull the alternator you'll see coolant residue in and around tstat fittings. Just redid mine(Had a crappy Wahler) and the residue was there and it leaked exactly like yours. Remember, fluids love to travel obfuscating their origin.
    The fleet
    2000 S4 EPL tuned Stage 3 -- Silver/Panda -- Latest fun project
    2002 S4 Avant 6spd -- Nogaro/Silver -- Long term rehab project
    2012 A8L -- Night Blue Pearl/Nougat
    2013 VW Touareg VR6 Lux -- Flint Grey/Black
    2001 BMW 540iA Sport -- Steel Blue/Grey
    2001 BMW 750iL -- Night Blue/Ivory
    2004 Jaguar XJ8 -- British Racing Green/Tan
    2005.5 A4 Avant 6spd -- Quartz/Black -- Sold
    Jan 24 2016
    DC
    Thanks for the info. Looks like my oil leak is exactly the same as this thread http://www.audizine.com/forum/showth...-behind-filter
    Luckily, I'm not losing much oil yet (adding half a quart between oil changes) but I'll keep an eye on it.
    Jan 24 2016
    DC
    I finally got a chance to take out the alternator and take a closer look at the thermostat. The process isn't hard but I wasted some time on two things. One, I didn't want to break the connector on the alternator and took my time trying to push it down and out. It wasn't working so I settled on using a pair of pliers to apply pressure down on the clip. Two, right before I was about to put the accessory belt back on the alternator it came off the vibration damper. There wasn't enough space to get it back on with my hand. So, it took me a while but I came up with a solution to insert a thin black cord and pull the belt in place. It work and I put everything back together.
    As for the thermostat/coolant leak, I used some paper towels to soak up all the liquid. I'm sure it will come back and when it does, I'll go in and replace the thermostat.
    Sep 21 2016
    1984 f-250 inline 6
    Washington
    Besides the T stat leak, i had same problem 1 week after i replaced the t stat saw leak rolling down and followed it up. Ended up pinching a small part of the o-ring. The other small leak i had was a plastic fitting behind your engine. Connected to the CTS housing that ran to the heater core. This thing leaked good only when heat was on. One way i was able to round it down. The plastic parts all had small cracks from heat and such. That was a pain to find.
    Jul 04 2015
    Quote Originally Posted by StanShepel View Post
    That is coolant flange.
    Sep 21 2016
    1984 f-250 inline 6
    Washington
    Quote Originally Posted by wding2000 View Post
    Well that was one part, the other is the plastic tube farther back behind the engine. More to the right if looking from the front.
    Jun 15 2011
    08 A4 Q Stock, '58 Porsche 356A, '73 BMW 2002
    Exiled.......
    I have a very slow, drip, drip.....maybe 1 drip every 0-30 sec--its coming from the oil cooler area. I will have time after the holidays to address it. In the meantime I planned on using this stuff. OldGuy on here used it for a time with a radiator leak......https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Aluminum Bars Leak.
    Anyone else used the stuff for a slightly larger than pinhole leak? What was your level of success.
    Not worrying about introducing it into the car. Have no reservations about using it--I dont think it will harm anything. I'll flush later.
    Anyone else use?
