Results 1 to 16 of 16
    May 18 2016
    PDX Metro/OR/USA
    Engine swap 8V a3/s3 w/ RS3 engine?
    Is there even a remote possibility that one might be able to swap in the rs3 motor into an a3/s3?
    Obviously with in reason...as pretty much anything can be accomplished with enough money.
    The rs3 is built on the same chasis and still uses haldex, so I would assume the drivetrain doesn't change much?
    Again, just thinking outloud.
    Sent from my SM-N920P using Tapatalk
    Veteran Member Three Rings 13allroad's Avatar
    Sep 26 2013
    2018 BMW x2 xdrive
    PHX, AZ
    From everything I have read, the engine yes. Audi has said that the engine they developed if modified further would not fit in the vehicle. Seeing that the engine compartment of the vehicle should be the same as the A3 and S3 I see no reason why it would not fit.
    The real question is matting a transmission and electronics, Quattro and such.
    Current: Quantum Gray Metallic SQ5 / JB4 / Carbon Mirror covers
    Old:
    2014 A6 tdi prestige, HRE FF01 wrapped in Conti, black optic, sport package, LED package, RS7 Pedal Kit, 034 Trans mount, Alu Kreuz, Eurocode sway bars/end links, rear spoiler, Vag Com Mods, piggy back tune.
    2013 allroad tuned and modded.
    Weekend rider - 2015 BMW R Nine t - custom
    May 18 2016
    PDX Metro/OR/USA
    Quote Originally Posted by 13allroad View Post
    I figured the electronics would be the biggest hurdle.
    Sep 02 2016
    You want that exhaust note huh ;)
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
    '17 Nano / RSe102 / MPS4s/ UM st.2
    May 18 2016
    PDX Metro/OR/USA
    Quote Originally Posted by 5l33P3R View Post
    Lol...obviously...but it's just such a better platform to start from as a base.
    Oct 30 2012
    Arizona
    Quote Originally Posted by Arrested_Decay View Post
    It should plop right in and mate up to the mounts, tranny and chassis. The only issue would be electronics/harness/computer/dashboard etc.
    The engine alone is about $12K used if you can find one overseas.
    I figure about $20K all in parts and labor = not worth it, just buy the real thing from the get go.
    May 18 2016
    PDX Metro/OR/USA
    Quote Originally Posted by A20V200 View Post
    Right now maybe. However, when it hits US soil and people start wrecking them the price may come down.
    However 8k just to have it installed and running correctly is steep, for sure.
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    i think they were already using that motor in the ttrs for the last few years. there could already be some that were salvaged?
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Sep 26 2013
    2018 BMW x2 xdrive
    PHX, AZ
    Quote Originally Posted by diztek View Post
    It's a different motor for the 18 RS3 and TTRS. Aluminum and 60lbs lighter plus different internals
    Old:
    Jan 15 2010
    Santa Barbara, CA
    You also basically make your car worthless at resale when you do that, except maybe to a tiny handful of people. Just get a real RS3 once they come up used in a few years. :)
    May 18 2016
    PDX Metro/OR/USA
    Quote Originally Posted by forbiddenbeat View Post
    I don't buy cars for resale....so that is no concern.
    Apr 11 2016
    US
    I dont think it will fit - I think the front end was widened to help facilitate the engine length.
    May 18 2016
    PDX Metro/OR/USA
    Quote Originally Posted by agpatel View Post
    Unless frame rails moved over. Which is unlikely, it should fit...it is based on the same platform.
    Apr 11 2012
    just get a stage2 tune and you'll be faster than a rs3, if you need even more, stage3. unless you must have that 5-pot sound? might as well buy a rs3 instead then.
    May 18 2016
    PDX Metro/OR/USA
    Quote Originally Posted by will13k7 View Post
    I agree...it was more of a general question. As if you start with a better power foundation and do similar mods, you end up further ahead. However it appears that the cost just doesn't make sense.
    Apr 11 2012
    it is a gem of an engine. probably still need stage3 to get one in the 10s though, I think that's what it took for the previous TTRS.
