Results 1 to 9 of 9
    Veteran Member Four Rings Tiluleshpingen's Avatar
    Nov 14 2006
    97 AS4 ,08 A5 MKVI Jetta
    Land of the Eagles
    Crank position sensor
    looking to get a new Crankshaft Position Sensor. But i am undecided between makers
    Have anyone heard anything bad or good for these sensors? Is anyone running ? Or just stick with OEM?
    BOSCH https://www.ecstuning.com/b-bosch-pa...6a906433c~bos/
    MEYLE https://www.ecstuning.com/b-meyle-pa...6a906433c~mye/
    FEBI https://www.ecstuning.com/b-febi-par...6a906433c~feb/
    GIAC-X, STASIS TS,VAST,034 MS
    Veteran Member Four Rings RocksForsSale's Avatar
    Oct 11 2014
    2020 Tacoma v6 4x4
    Allentown, Pa
    Go for the cheapest one, it's literally just a magnet right?
    Veteran Member Four Rings mikeb17's Avatar
    Oct 27 2012
    Lamborfeetes
    Washington
    It honestly take 2 minutes to replace... buy a cheap one.
    Jan 06 2009
    Pretty much the most important sensor on the car.... Buy OEM (or unbranded OEM). It's reasonably cheap and will last years and years and years...
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    Bosch was OE for my car...
    Aug 24 2014
    Newport Beach, CA
    Second for Bosch, it's the OE sensor manufacturer. $41 is cheap insurance for never having to worry about it for a long time.
    2024 M3 Comp xDrive
    Nov 14 2006
    Land of the Eagles
    Thank you all for the replies that exactly what i was thinking. Dint really want to cheap out too much and had my eye on the Bosch.. Meyle at 60 bucks wasn't making any sense.
    when ever i install in the car and get it running i will try to give some feedback after a couple thousand miles!
    Dec 30 2009
    Quote Originally Posted by Tiluleshpingen View Post
    Keep an eye out for the aluminum spacer that can be stuck to the old sensor, it spaces it out a bit so that the sensor doesn't hit the flywheel.
    2001.5 S4 Sedan
    2002 A4 Avant 1.8t - Traded in
    2001.5 A4 1.8t - Sold for $5
    2013 Q7 TDI Premium Plus (RIP, rear ended and totaled, assholes)
    2013 Q7 TDI Prestige S-Line
    2018 Q5 2.0t
    2022 e-Tron Chronos Edition
    Nov 14 2006
    Land of the Eagles
    Quote Originally Posted by Timtheguru View Post
    haa yes, thanks . when i did a thread search i saw that a few had lost it and the sensor was hitting the flywheel
