Results 1 to 40 of 45
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    MRC Tuning's 195mph S4
    Sweet vid!
    I don't think they have a presence here on the forums
    Car's specs as posted in video link
    Tuning options for b8 b8.5 crec
    Stage1 430-450ps 530-550nm
    Stage2 470-520ps 580-610nm
    Stock 330-360ps 440-470nm
    Spec - Stage 2+
    ECU REMAP
    PULLEY
    STRONIC REMAP
    COLD AIR FEED
    MILLTEK VALVESONIC
    MRC INTAKE
    side note: i want those ceramic brakes
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Mar 21 2015
    What vid
    Senior Member Three Rings RyanJon's Avatar
    Jun 06 2013
    Aprillia SR50
    Oldham, England
    Veteran Member Three Rings EHesh14's Avatar
    Jul 16 2010
    Colorado
    Dope
    Senior Member Three Rings Low Flyer's Avatar
    Oct 25 2008
    MD
    Sounds great. Sounds crisp.
    A fair amount of euros.....
    Oct 31 2013
    Morris County, NJ
    195 huh. So smooth. Done on a dyno?
    2011 S4 P+ 6mt | AWE Touring | Roc Euro | H&R OE/Bilstein/034 RSB | APR Stage 2 DP + CPS | TSW Bathurst 19X9.5 | Michelin PSS 255/35/19
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    ^ that's what I am thinking as well
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Jun 28 2016
    US
    4 to 5 shift has that bs RPM hiccup we've seen other tuners have. WTF?
    Apr 04 2012
    MSP
    Easily the best B8 vid/film I've seen - Top Gear quality.
    Love those 20 inch peelers!
    Nov 08 2008
    Los Angeles, CA
    Great example of how classic/beautiful the B8 S4 lines have become. B8.5 and B9 look good, but I think the B8 will continue to age the most gracefully.
    Veteran Member Four Rings AudBoost's Avatar
    Apr 05 2005
    Tampa, FL
    Awesome video! And that car looks and sounds amazing.
    Not sure if there are any film tricks involved (done on a dyno or filmed going down hill) but from the video that thing is moving. 46 to 134 took about 6 seconds and 46 to 172 about 10 seconds. The final run from 66 to 195 took about 31 seconds.
    2016 S6
    Veteran Member Four Rings JD S4's Avatar
    May 07 2016
    '18 S5, '94 Integra DB8 JDM, '20 Highlander Hyrbid
    Citrus Groves, Arizona
    Wow.. Love that video and car..
    Are those 20 or 21" peelers?
    '18 S5 - BBS / EPL
    Jul 21 2004
    South Florida
    Quote Originally Posted by MrFunk View Post
    Threadjack:
    Maybe I did a crap job at searching but does anyone know what OEM 20" peelers people are using on the S4 or the S5? Or are people going aftermarket with Hartmann? I do like that look a lot and I want to keep my car OEM looking. Thanks.
    Mike
    2018 Audi S5
    Gone-
    Veteran Member Three Rings jachien's Avatar
    Nov 12 2012
    Cerritos CA
    Quote Originally Posted by bhvrdr View Post
    Threadjack:
    Mike
    Not sure of offset and fitment but the a8 and I think q7 have larger than 20" peelers.
    2013 B8.5 S5 - Dual Pulley 189mm/57mm. EPL E85 Dual Pulley/DSG flash. Autotech HPFP. APR B8 Heat Exchanger. Injen Intake. Deleted Mufflers. 034 Street Motor Mounts. 034 Driveline Mount Inserts. KW HAS + H&R F:20mm/R:25mm wheel spacers. S6 Brake Conversion
    May 07 2016
    Q7 can come with 21" peelers.. Those look like 20s
    '18 S5 - BBS / EPL
    Jul 21 2004
    South Florida
    Quote Originally Posted by jachien View Post
    Thanks for pointing me in the right direction.
    Looks like A8 in 20" is 20x9 and ET40
    http://www.audizine.com/forum/showth...-WILL-they-fit
    2018 Audi S5
    Gone-
    Senior Member Three Rings TomPaul10's Avatar
    Aug 04 2014
    albany, new york
    my god this makes me miss my S4, S3 sounds like SHIT compared to my old car. ( as if I didnt know that buying it after haha )
    Current: 16 mythos black S6 prestige
    past:
    13 S5 stage II+ awe track/ H&R
    2016 SQ5
    2016 Sepang S3 premium
    2010 Ibis White S4 P+ / A.W.E Track /
    2010 Stage II A5 / G.I.A.C. / A.W.E. / H&R /
    Nov 10 2014
    Apex, NC
    OMG they are doing 190 on the wrong side of the road
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Apr 22 2014
    Bath, UK
    Very interested in this! I'm in the UK and MRC are who did my Stage 2. Always knew they'd be shooting for more, but that's more than I expected!
    So normal stage 2 is a map and pulley which gets about 470BHP. MRC use an oversized crank pulley whereas other tuners use an undersized supercharger pulley, however they're both basically doing the same thing.
    For this stage 2+ MRC have apparently gone for a supersized crank pulley, instead of the dual pulley that people were expecting. Wonder why?
    It's not listed in the video, but I would have thought they're using a big heat exchanger to keep things cool. Also wonder what fuel they're using or any meth?
    Apr 05 2016
    Portland, OR
    There isn't anything crazy going on in the video aside from the excellent cinematography.
    If you read there FB comments it is a larger crank pulley and upgrading cooling.
    If I had to take a guess, they are still under a 200mm crank.
    I will post on their FB page to see if I can get more details.
    Geoff
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    stock, race , high torque, and the big one
    No idea on sizes & MRC keep that info close to their chest
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by xpoweruk View Post
    Get some calipers man!
    Geoff
    Feb 05 2016
    UK
    Quote Originally Posted by whiped View Post
    Not my pic sadly
    Jul 21 2004
    South Florida
    You gotta put your finger and thumb on the screen and then take them and put them up to a ruler
    2018 Audi S5
    Gone-
    Apr 04 2012
    MSP
    I think most are going with aftermarket for 20 inch peelers. The A8 CB is not the same as the S4.
    Here's a link to aftermarket rotors which come in 18, 19 & 20 http://shop.achtuning.com/Hartmann-H...eels-Audi.aspx . They come in a 20x9 ET 40 and cost $370 per wheel.
    If I needed new wheels I'd go with either the peelers or the Ti wheels in a 20 (http://shop.achtuning.com/Hartmann-H...eels-Audi.aspx)
    Jul 21 2004
    South Florida
    Got it. Thanks man!
    2018 Audi S5
    Gone-
    Jun 06 2013
    Aprillia SR50
    Oldham, England
    Quote Originally Posted by Westyfield2 View Post
    As far as I can tell this is the car they use for their development. Doug said on fb that it has meth, they also do their own high flow cats so I'd guess it's got a pair of those on it as well.
    He also said its got a few other bits and bobs they are trailing out which could be anything but is more than likely throttle body work.
    I plan to get mine in over the next couple of months for stage 2 with updates charge cooler. How do you find yours?
    Veteran Member Four Rings B18b1ex's Avatar
    Jul 02 2004
    FL
    Got it. Thanks man!
    You have always been a function over style guy! These must weigh a ton!
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    Any clue as to what valvesonic is?
    Dec 11 2015
    boston
    Quote Originally Posted by 4Rings3Liters View Post
    An electric toothbrush
    Haha jk it's an exhaust made by Milltek
    13' s4 ,ibis white ,b&O, sport diff , dsg , full nappa
    Epl stg2/dsg flash . Cts pulley . Ecs Kohlefaser Luft-Technik . Rotiform spf 19x10 all around . Enlaes decklid . Rs4 grill . Deval diffuser . Ecs diff mounts . H&R OE springs . Awe Touring .....
    Apr 11 2012
    Quote Originally Posted by mmm def View Post
    195 huh.
    Not the first time a B8 Audi S4 has gone above 190, here's 193:
    Quote Originally Posted by SwankP3RF3ct10n View Post
    Gift from Audi.
    Quote Originally Posted by A4Ultrasport View Post
    Great example of how classic/beautiful the B8 S4 lines have become... I think the B8 will continue to age the most gracefully.
    this.
    Jan 26 2015
    2017 XC90, a workbench
    CO
    Quote Originally Posted by AudBoost View Post
    Ya it looks faster than the dual pulley cars here. Not calling them liars but it seems too fast for the specs given. Maybe the new moderator could reach out to them to establish presence on the forum.
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Veteran Member Three Rings skiptowncat's Avatar
    Nov 13 2014
    Manchester, England
    Quote Originally Posted by Hofahome View Post
    They don't really go on any forums, and I couldn't see them paying to have a presence on an american forum which would only bring them minimal business.
    2015 C7.5 S6//DS1 STAGE 3//SRM INTAKES//034 X-PIPE//H&R SWAYS
    Senior Member Three Rings Mat@1975's Avatar
    Jun 14 2015
    FRANCE
    Hi !
    Don't forget that ther crack pulley is the biggest they offer. It has a S/C overdrive ratio of the order of the dual pulley set ups. So it is a dual pulley car, with a charge cooling kit, intake+cold air intake via the fog grill (if you notice : the car has a fog grill with the adaptive cruise controle hole, but without the radar !! ;o) ) Nice idea to route fresh and high speed air to the air box from this hole !. the set up has also a full miltek exhaust + sport cats. And last but not least, they run a very good quality fuel, probably their UK RON99 fuel which is likely like your AKI 94.
    I have only 480hp with only stage2 pulley and intake with crappy french fuel, so 520 hp with all this extra stuff is very credible in my opinion.
    All i can tell you is that MRC is a very reputable brand here in Europe, and i am very happy with my tune ! They really offer custom tune (more than 5-6 dyno runs on the dyno for my car) with the priority of engine safety!
    Cheers !!
    Mat
    S4 B8.5 AVANT | S-Tronic | Full ADS | Sport Diff | Glacier White
    MRC Stage 2 Tune | MRC TCU Tune | AMS/Alpha Cooler| AWE + AFE filter intake with airbox hole
    KW HAS Springs | H&R Sway bar F&R | Custom 14 mm Front and (13 R / 16 L) mm Rear Spacers | CR-15 Strut Brace
    OEM Rotors | Michelin PSS 255/35/19
    Q5 calipers | Goodridge SS Lines | 2-pieces Girodisc Rotors Front & Rear
    Nov 10 2014
    Apex, NC
    i thought DP magic was mid range.. this car seems to climb to 195 with ease .. usually that high up it takes a little longer.. the way it was pulling you would think it would get to 220 with enough road.. someone said the car had Meth.. maybe a little juice too? 40 shot?
    Present:
    Jun 14 2015
    FRANCE
    Quote Originally Posted by doug97gxe View Post
    I saw on FB that they were trying Water injection (wi) ...
    Cheers,
    Mat
    Apr 05 2016
    Portland, OR
    That was my thought too Doug.
    Once my car hits ~170 it starts slowly ticking up. I've had it up to just under 190 and it definitely climbed slower than that.
    I was thinking as someone posted earlier that this run was likely done on a dyno in which case the lack of air resistance may have allowed them to climb faster. Who knows.
    Still no response to my FB inquiry.
    Geoff
    May 07 2016
    The rate of ascension can easily be explained with a little camera trickery.. Speed it up so it doesn't take 30 seconds to watch the "needle" climb.. I think they are showing off getting to 195, not precisely how fast it is to get there..
    '18 S5 - BBS / EPL
    Veteran Member Four Rings Lensch09's Avatar
    Feb 20 2004
    2022 B9 RS5 SB, 21 Rav4 Hybrid, some golf clubs
    Santa Clara, California
    I don't know if I believe their HP figures. It's VERY possible that their correction factors are not correct.
    Every MRC car that I've researched has ran 11.8-11.9 @ 115-116 in the 1/4. Hardly 520 PS if those times are the latest revisions. I think they're more likely around 380-390 awhp on a conventional US Mustang.
    -DL
    2022 RS5 Sportback - Navarra Blue
    Previously:
    2016 Audi S4 Prestige with tons of boltons -Build Thread - http://www.audizine.com/forum/showth...016-S4-Ordered!
    2007 Audi A4 S-line Ti APR GT2871R
    1999 Audi A4 Avant (S4 replica)
    2000 Audi S4 Sedan (Stage III)
    1999.5 Audi A4 1.8TQM Sport (bolt-ons)
    Dec 10 2012
    New York
    Was it confirmed that film wasn't made on a dyno. A lot easier to get to 195 when there is no air resistance.
