Results 1 to 11 of 11
    Oct 11 2016
    Massachusets
    Question Need help finding a replacement part
    I have a 2011 A4 and on the top right of the manifold, there is a small part with a hose going into and out of it and it is making a loud ticking noise. The part number on it is 06H-906-517-H. Is this the latest revision of this part, and where can I buy a replacement for it?
    Oct 11 2016
    Massachusets
    That's not for an a4.
    Oct 30 2006
    B8 A4 Avant 6spd
    Thats a N80 purge valve, they're supposed to tick, do not replace unless you have an actual fault relating to the EVAP system / the purge valve.
    -18 718 GTS
    Oct 11 2016
    Massachusets
    Quote Originally Posted by Militant-Grunt View Post
    I originally thought it was a purge valve so I bought an n80 valve for a b8 a4 and its a different part. It's also ticking very loudly.
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    Quote Originally Posted by Hunter2011 View Post
    Its the part number you gave. lol
    Oct 11 2016
    Massachusets
    Quote Originally Posted by Spawne32 View Post
    No it's not
    Sent from my SM-G920V using Audizine mobile app
    Veteran Member Four Rings lettuce's Avatar
    Jun 19 2015
    Boston
    No it's not
    His link actually answered both your questions. No it's not the latest revision, and he gave you the link to a place where you can buy the latest revision.
    B8 A4 - Eurodyne-tuned F23L - 12.6 @ 107 on 93
    Oct 11 2016
    Massachusets
    Oh, haha, I missed that, thanks for pointing it out. Will this work in an a4 though since it says its only for a6's and a's?
    Jun 19 2015
    Boston
    Going by part numbers will generally be more accurate than the listed applications on parts seller's websites. There's always the chance that someone before you installed the wrong part in your car, but more often than not if there's a discrepancy, it's with an online parts seller just not listing all the proper applications.
    Dec 30 2016
    South Jersey
    Do you get a smell of gas on startup? I have the same ticking and am wondering if I have the same problem, no trouble codes though. Thanks for any help.
