Results 1 to 36 of 36
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    Question Upgraded injectors?
    Hey guys, car currently has 95k miles on it, stock injectors/turbo, and APR Stage 1 tune.
    However, I have all the parts needed to go Stage 2+, just need to install them and get flashed. I am also planning on getting a bigger turbo over the summer (k04 probably) so am thinking about upgrading my injectors also...Any suggestions? I know S3 is a common option, but where to buy them and are there any better options?
    Will upgrade injectors cause problems for while still running Stage 1 software? I fill up with 93 only.
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
    Veteran Member Four Rings Denio24's Avatar
    Jan 23 2013
    Chicago
    I would honestly just wait till you have the k04 and the s3 injectors. I'm assuming you will be going with JHM? It is also not a bad option of testing the 2+ tune to make sure you don't have any issues.
    You will have to flash a tune when you install the s3 injectors to utilize their full potential; otherwise, you will run rich.
    The rs4 injectors have been proven to flow more, but the s3 injectors are the ones you want. 06F906036F is the part number.
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Dec 19 2012
    Europe
    Thanks for the reply! OK so things would be best if I went like this?
    APR Stage 2+ Flash -> some k04 turbo kit + S3 injectors at the same time?
    Jan 23 2013
    Chicago
    Yup exactly like that.
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by BenMTL View Post
    S3 injectors are the only option imo The RS4 injectors does not have the correct spray pattern. They are also known to have tune issue's in cold start up. Do a search on them to read the results. This si why most tuners use them and alot of the Bt users select them also
    Veteran Member Four Rings pat_do's Avatar
    Feb 19 2012
    Montreal
    Jhm or cts kit?
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    I've used S3 on k04, GTX 2863, GTX 2867. No issues. suggest water meth even with k04, also suggest buying my 2867 as my price complete is damn near what ull pay for a "k04 kit".... But I like BT.
    Nov 05 2016
    texas
    So ur gt2867 has the intake manifold? A complete kit? I might b interested?
    Sent from my SM-N900T using Audizine mobile app
    Feb 10 2012
    parts
    Napanee, ON
    Turbo kit. Send me a PM for details.
    Not looking to clutter OP thread about injectors.
    Veteran Member Four Rings RoguesGambit's Avatar
    Dec 19 2012
    Eatontown, NJ
    Forget APR, Go JHM, I'm doing that once Im back from Cali
    JHM St2 w/HPFP, JHM HFC+B7 S4 FI Catback, JHM St1 Clutch/Flywheel, S4 Recaros, JHM Shift-Trio+Cross Rod, Bi-xenon Headlights, JOM Smoked Tail Lights, Enkei PF01, Conti DWS, Solo-werks S1 Coilovers
    More to come
    Also, my story: https://www.amazon.com/Sage-Mike-Fra...7646774&sr=1-1
    Dec 19 2012
    Europe
    Question on this guys...Ultimately switched to JHM (Stage 2). Would it be possible to use the S3 injectors without the k04 turbo? Haven't received it yet....
    Would I need to reflash?
    Veteran Member Four Rings yxri's Avatar
    Dec 27 2016
    Ford Lighting
    Ohio
    Yes but the car will go into limp mode
    Dec 19 2012
    Europe
    Quote Originally Posted by yxri View Post
    Interesting....some people say it will, others say it won't (no specific tune need for just s3 injectors, even with stock ecu or some stage 1 flash it would be OK).
    Not sure who to believe at this point
    Dec 27 2016
    Ford Lighting
    Ohio
    You will need a tune for the s3 injectors. Don't believe me, try to do a Wide Open Throttle run and see for yourself. People have just not got into boost which allows them to drive the car to the tuner without throwing CEL. I wouldn't recommend if you need to drive more than that for a week.
    Oct 24 2015
    Perth, WA
    I run my car with S3 injectors, boost fuel system, no probs on a non S3 tune
    My respray thread
    Dec 19 2012
    Eatontown, NJ
    Good to know.
    Better add those to the inevitable Xmas list :P
    More to come
    Dec 27 2016
    Ford Lighting
    Ohio
    Quote Originally Posted by Okedokey View Post
    Custom tune?
    Oct 24 2015
    Perth, WA
    Custom tune?
    no just stage 2 BSR.
    My respray thread
    Dec 27 2016
    Ford Lighting
    Ohio
    Weird, Many forum members reported that the car would go into limp mode.
    Oct 24 2015
    Perth, WA
    never been in limp mode and i go wot regularly
    My respray thread
    Dec 19 2012
    Europe
    What is BSR?
    Oct 24 2015
    Perth, WA
    What is BSR?
    https://en.bsr.se/tuning-kits
    My respray thread
    May 02 2017
    Florida
    If your doing k04s you'll have to do software again an then you should replace them .
    Oct 24 2015
    Perth, WA
    Quote Originally Posted by Apollo75 View Post
    Huh?
    My respray thread
    Dec 27 2016
    Ford Lighting
    Ohio
    Huh?
    Guy must be in the wrong forum...
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    Won't the S3 injectors just spray the amount of fuel requested by the ECU dictated by the tune anyway?
    What I'm saying is, just because they can flow about 15% more than our stock injectors can doesn't mean that they do all the time. The injector is still controlled by something else.
    Or is this theory totally off?
    Oct 24 2015
    Perth, WA
    The injectors work in ms, from the ECU, and with higher pressure mods, itll still flow more fuel. You can do it this way, or tune the car properly and get better efficiency via mods to injector pulse time and pressure. Either way, they work fine (albeit rich) in a stock tune. The trick is to get the air in.
    My respray thread
    Dec 27 2016
    Ford Lighting
    Ohio
    Reading back I assumed he was going to have the ko4 on the stage 2 tune. which will distort the air flow and cause a CEL.
    Feb 10 2012
    parts
    Napanee, ON
    Quote Originally Posted by EvolutionArmory View Post
    I think your right S3 injectors on a lesser tune or turbo car will run. I believe jameslucy runs this now on his stage 2 tune on oem turbo. I logged his car last year and his injector corrections were nothing out of the ordinary.
    May 20 2017
    New Hampshire
    You are dead right about this. I had to run my K04 on a stage 2 tune for 2 weeks. Limp mode every other day. Had to take it easy and make sure I was always in the right gear to get speed with partial throttle.
    It's just we're talking about something else this time 😀
    Feb 10 2012
    parts
    Napanee, ON
    $310 usd plus shipping and fees. Best I'll do here there listed else where for a lot more.
    May 20 2017
    New Hampshire
    50% off a used part set based on condition is more than fair. The OP should snap these up. The parts are good and the seller is solid.
    Feb 10 2012
    parts
    Napanee, ON
    Ya I think they ran 1000 miles. So they're new condition and install ready.
    Thanks mate appreciate the comment.
    Dec 19 2012
    Europe
    Are those S3 injectors?
    Feb 10 2012
    parts
    Napanee, ON
    Correct sir. Part number 06F 906 036 F. Buy from a Canadian brother, clearly a better deal then classifieds. And likely a bit less shipping from Kingston area to MTL (Montreal)?
    Veteran Member Three Rings StatusQuo's Avatar
    Jun 15 2016
    Northern California
    If you run S3 injectors on a tune for stock injectors, the car can still run. What will happen is the ecm will see the car is running rich and progressively start pulling fueling via o2 correction. However, there is a limitation with this correction.
    You will run into a problem where your o2 correction is already way off optimal values on the stock injectors. Adding S3 injectors will compound the problem.
    The S3 and stock injectors behave the same. So using the stock firing angles and injection times can get the car to run.
    Ideally you want to zero out the o2 correction in your tuning so it can compensate for bad situations as needed.
    The stock ecm can correct for ±50% of fuel total.
    Sent from my ONEPLUS A5000 using Audizine mobile app
    B7 Audi A4 Quattro - Built. Not Bought.
    Upgraded HPFP | RS4 Injectors | RS4 LPFP Controller | 175 Bar PRV | 50/50 E85 | Straightpipe Exhaust | Cold Air Intake | Big Turbo | Front Mount Intercooler | -- The Maestro Community Project --
