Results 1 to 30 of 30
    Nov 18 2016
    S6 Wastegate Actuator Vacuum Lines
    I am having issues with my driver side wategate actuator staying closed once I turn on the car. I decided to test the actuator by hooking it up to the passenger side vacuum line and it works as it should. So this tells me something is wrong with the driver-side line connection, not the actuator.
    Does anyone have any other diagrams for the vaccuum lines? #28 goes to somewhere in the front of the engine bay, behind the radiator fans, but I cant see where that line goes to or connects to?
    Im wondering if I can tee off the passenger side and just run a new hose to the driver side actuator as a temporary fix. Anyone have any experience with these vacuum lines or have any recommendations?
    Jan 31 2009
    2016 RS7-P
    From the self study guide both wastegates are controlled off the same (N75) valve.
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    more than likely it popped off the n75 valve.
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Im actually a little surprised that one wastegate works and not the other in this configuration because if the line has popped off then there would also be a leak causing the other wastegate to only hold temporarily while the pressure tapered off.
    A better guess is the line is pinched or clogged! Glad it's something simple though and nothing more serious!
    Nov 18 2016
    Quote Originally Posted by Sanjman View Post
    The malfunctioning side has very high vacuum, and pulls the actuator closed. Its not leaking more so too much vacuum. I can pop off the line and feel it suck onto my finger and stay there. I was wondering if I can cap that line off, and then tee off the other line and run to both actuators.
    This is still extremely helpful info, but I cant find this N75 valve under the hood, or a legit part number for the s6 n75 valve. Im thinking that may by the culprit all together.
    Oct 16 2012
    pa
    It's a boost control solenoid, I don't see why you' couldn't just use the one side and t off it
    Nov 18 2016
    Tee'd it off. Actuator remains open at idle and gets pulled closed when I rev it (as it should). Car runs much smoother at part throttle and no longer "chugs" along at highway speeds when trying to merge as seen here: https://www.youtube.com/watch?v=OfJEqyz2XPI
    I plugged the driver side tube that was causing the issue. My concern now is that I don't think Im getting full boost at WOT, looking at my lap timer gauge. I'm thinking one side of this N75 valve is not strong enough to hold both actuators tightly when WOT. I will keep it this way for now, but any other ideas? Part #s for this valve? I can take a video and will report back.
    Oct 16 2012
    pa
    Log requested boost vs actual boost. If you have APR you should be able to do it via the dongle if you don't have vagcom
    Nov 18 2016
    It looks like as the revs climb, the boost falls off. It shifts, gets back to full boost and repeats.
    I do not have the dongle or VCDS
    Veteran Member Four Rings MadAboutCars's Avatar
    Aug 27 2015
    MY18 Audi RS6 P, MY18 Audi SQ5,MY16 Audi S6 (sold), MY12 Audi Q7 4.2L TDI S-line (sold)
    New Zealand
    You need to get a VCDS. You may be in a partial limp mode due to DCT's (fault codes), which can cause what you are seeing. VCDS will allow you to clear the DCT's and tell you about other problems you may have.
    2018 Audi RS6 Performance - Floret Silver, Titanium styling package, 21" titanium 5 V spoke wheels, Dunlop SP Sport Maxx GT 285/30/21, Black sports seats, Carbon inlays, Sports diff, Sport exhaust, Matrix LED headlights, 360 camera, Head up display, Active lane/side assist with adaptive cruise control, Park assist, Privacy glass, Electric tailgate with foot open
    Mods: Dura-Seal exterior/interior, Audi Sport door lights
    Nov 16 2006
    Skokie, IL
    You don't NEED VCDS to clear fault codes. But you should consider getting that or the dongle if you have Apr for logging purposes. You can go to O'Reilly or AutoZone to clear DTC fault codes in a pinch. A great cheap tool is getting the ELM OBDII dongle with the Carista app
    Also from the video that seems normal you don't stay in boost through your entire pull. It's supposed to taper down and build back every shift
    Nov 18 2016
    I have a generic obd2 scanner and ability to erase codes. I did have my usual 2 pending o2 sensor codes, but forgot to clear right before the video. Im not sure if that would effect the boost, maybe I will try again.
    As for full boost, Im comparing it to this video (not my car) and how it used to be for me with the one wastegate essentially permanently closed:
    Oct 16 2012
    pa
    I would buy a new valve and new line for that bad side
    Nov 18 2016
    Quote Originally Posted by saxon View Post
    I called the local Audi dealer to request a part number for this N75 valve. The parts guy wouldn't give me the part number because Audis parts a "proprietary" and don't want me to shop around. I was quoted $130 for the part. Does anyone have any way to find a pn to see if this is a fare price? I was also quoted $66 for the lousy windshield washer pump which I can find for much much less.
    Jun 18 2011
    markham, ontario
    Quote Originally Posted by AWOL View Post
    I had a hard time finding this part as well. Couple of shops weren't sure of the PNs. Finally an Indy shop thinks they have the right PN... it comes up as a solenoid actuator and is more common in diesel engines according to my mechanic. I haven't yet gone ahead with the work... apparently the bumper and radiator needs to come off for access.
    23 BMW X3 M Competition Brookyn Grey, 17 Golf 1.8 TSI Pure White
    -Traded-in-
    19 RS3 2.5T Nardo Grey, 18 Golf R DSG Indium Grey, 13 S6 4.0T DSG Phantom Black, 11 Golf 2.0TDI DSG Candy White, 11 S4 3.0T S-tronic Ibis White, 10 Q5 3.2FSI 6A Ibis White, 01 Golf GLS 1.8T 4A Black, 06 A3 2.0T DSG 6A Brilliant Black, 04 A4 1.8TQMS 6M Ocean Blue, 00 A4 1.8TQMS 5M Light Silver, 99 Golf GL 2.0 5M Candy White
    Mar 29 2014
    Hampshire, UK
    Here is a link to the EKTA parts list, not sure if this helps you or not.
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Oct 16 2012
    pa
    What are the exact trouble codes your having? Unfortunately the generic obd2 reader won't help as much as vagcom
    Jun 18 2011
    markham, ontario
    My mechanic ordered 059906627L. This was after the first 2 orders were wrong. Can anyone confirm? I still have to go in for the appointment.
    Sent from my Nexus 6P using Audizine mobile app
    -Traded-in-
    Mar 29 2014
    Hampshire, UK
    Quote Originally Posted by GolfGL View Post
    I can't find that part listed for a 4.0TT when I search using http://www.oemepc.com/audi/
    Nov 18 2016
    All o2 sensor codes.
    P0140
    P0141
    P0160
    P0161
    P2273
    Dealer diagnosed the rear o2s as bad. In a previous thread, I bought and installed these sensors to no avail. Codes still come back after clearing. I'm wondering if there's some sort of fuse or relay that's junk.
    Either way, I don't think these codes have to do with the boost issue. This mystery N75 valve is my next focus (if we can find out part numbers, details, etc), but the car is a lot nicer to drive once I tee'd off the lines.
    Oct 16 2012
    pa
    P0140
    P0141
    P0160
    P0161
    P2273
    Did APR say the car was stage 1 or stage 2?
    Nov 18 2016
    APR V1 when I bought it. Updated it to APR V1.1 when I switched it to my name.
    Oct 16 2012
    pa
    thats the version, was it a stage 1 or a stage 2 tune?
    possibly the previous owner had downpipes on the car and didnt install the o2 sensors correctly
    Nov 18 2016
    Thats all I know.
    Im putting my tail between my legs and finally have the dealer not only diagnose, but to try and fix these codes next week.
    Nov 16 2006
    Skokie, IL
    Thats all I know.
    Why not take it to an APR shop and have them flash you back to stock for 50-75 bucks? Much cheaper than going in to the dealership for a stupid 200 dollar diagnostic +labor for doing the same.
    Also... I'm doing some digging... this is a placeholder for the parts... so bare with me as I dig... (for 2013 s6 model)
    079145461H adjust motor left (early 2013 models)
    079145461K adjust motor left (late 2013 models)
    079145462M adjust motor right (early 2013 models)
    079145462M adjust motor right (late 2013 models)
    079131055CP vacuum tube left
    079131055CQ vacuum tube right
    Dec 11 2017
    67 Chevelle, 997 C4S, Yamaha Warrior, Ducati SuperSport
    Where is the N75 valve located in the engine bay? I see the two wastegates but dont see where the lines go. I got Code 12266 while running a Stage 1 tune, but recently had the turbos replaced. Might be why?
    Dec 11 2017
    So I found a split line in the coolant line that goes in by the cap, could that result in the same code reading? Maybe not.
    Dec 11 2017
    So I checked both lines by the wastegate and both have vacuum.... not sure why then I am getting the P0299 code. Any ideas?
    Mar 26 2010
    US
    Quote Originally Posted by bja72774 View Post
    You might consider Flashing to stock and have an Audi expert check all the vacuum lines and elecrical connections to the electronic solenoid valves and sensors.
    BMW M3 Competition X-drive
